Old 09-11-2014, 05:27 PM   #113
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by AL008 View Post
@shiv please correct me if I'm wrong but there seems like there is next to no changes in this release for stage 2 UEL other than timing pulled in upper end, knock correction table changed and also MAF table?
Those are pretty big changes
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
AL008 (09-11-2014)
Old 09-11-2014, 05:39 PM   #114
Shady195
Drives: '13 10 Series FRS #1203
So those of you running a Stage 1 OFT tune (or any for that matter) I've heard a lot say that the Intake growl is much more pronounced.. which WOW it is but wondering if anyone elese almost thing it sounds like a bit of a rattle after about 4500RPMs, it could be other things in the car but it sounds like its comming right from the intake.. IDK
No other weird noises, seems to be running very smooth and really changes the cars character. I know it seems silly, and I know a few HP's on the dyno graph doesnt mean much but its amazing how much the tunes change the cars feel
I feel a bit bad even posting this because I don't own an OpenFlash tablet (I may end up buying one however for its simplicity and logging) but I just want to say great work Shiv , the work your team is doing for this community is fantastic.
Shady195 is offline   Reply With Quote
The Following User Says Thank You to Shady195 For This Useful Post:
TJ3000 (09-12-2014)
Old 09-11-2014, 05:44 PM   #115
Shiv@Openflash
Drives: 2013 FRS
Thanks for the kind words. We are always happy to have new customers
Old 09-11-2014, 06:25 PM   #116
AL008
Drives: Celica 04
Would there be any power differences with these changes? I was under assumption that if you pulled timing from upper end, you're going to be losing some power?
Thanks.
AL008 is offline   Reply With Quote
Old 09-11-2014, 06:35 PM   #117
Shiv@Openflash
Drives: 2013 FRS
Thanks.
I believe it is added back in through the knock correction table to compensate.
AL008 (09-11-2014)
Old 09-11-2014, 06:45 PM   #118
steve99
Drives: FT86
Thanks.
he new map made a bit more power few hp, as the new maf scaling allowed tigher control of the afr i believe its running a bit leaner than previous mapping with better knock resistance , it was running quite rich top end in 1.5, so leaning it out has probably made the power even though he advancecmay be slightly less.
If your prepared to run united 100 octane in OZ then you will likely be able to run close to the 93 usa mapping i believe its only the base timing b table changed between the maps. so just copy that from a 93 map into your G map.
else i have a table/map i have done afew small mods to thats sort of midway between 91/93 topend and a tiny bit pulled 1600-4000. with some temp compensation i get virtually no knock on 100 ron.
AL008 (09-11-2014)
Old 09-11-2014, 07:08 PM   #119
GT86meMR2
GT86meMR2's Avatar
Drives: MR Spyder/GT86
Is it just Australian 98ron that isn't as good as USA 93 or are you talking about all the 98Ron in the EU because some tuners here say our 98Ron in Belgium is actually a bit better than the USA 93.
GT86
Current Mods: Ace Header with 350 OP-Berk Frontpipe-Miltek Resonated Catback-OFT-k&n drop in filter
GT86meMR2 is offline   Reply With Quote
Old 09-11-2014, 08:05 PM   #120
steve99
Drives: FT86
Only talking about 98 ron in Australia i have no knowledge of EU fuels. G rom is used in Australia, Europe, South Africa pretty hard to account for all fuels Shiv is just being safe. If you have good fuel then make up a 93 map and test that.
Old 09-11-2014, 09:33 PM   #121
Stealthy
Drives: 2014 WRB Bravo Romeo Zulu
Got my oft yesterday and flashed v2.06 stage 1 93 oct today.
All I can say is the smile i have when driving is much bigger. This is how the car should have come out of the box.
Stealthy is offline   Reply With Quote
The Following 4 Users Say Thank You to Stealthy For This Useful Post:
flippy (09-12-2014), JB86'd (09-11-2014), lucid215 (09-13-2014), Shiv@Openflash (09-12-2014)
Old 09-12-2014, 07:36 AM   #122
Shady195
It's amazing to think what just the Stage 1 on the car given to a reviewer might say..Its not so much faster but it just feels more alive.. The VVT change seems to really help the feeling that the car is not falling on its face with the torque dip.
Old 09-12-2014, 09:31 AM   #123
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
It's been a long time since I've gotten excited about a tune, but this one has me smiling again. Probably the single best tune since I invested in OFT over a year ago. My BRZ has been revived
Sent from OmegaROM S5
2URGSE
JPxM0Dz is offline   Reply With Quote
The Following User Says Thank You to JPxM0Dz For This Useful Post:
Old 09-12-2014, 01:01 PM   #124
Stealthy
Definitely! The car just feels so much smoother to drive without much hesitation in the dip range. This is also my first major mod to the car and it's worth every penny.
The Following User Says Thank You to Stealthy For This Useful Post:
Old 09-12-2014, 01:19 PM   #125
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Will be doing stage 2 uel tune on Saturday, can't wait.
Question though. One station I fill up at only has 92. What happens if I have the 93 tune and use 92? Is there a significant benefit to the 93 over the 91 tune?
I can either only go to the 93 station, or go with 91 tune and be fine either way if 92 on a 93 tune is a no no
B-R-Z is offline   Reply With Quote
Old 09-12-2014, 01:32 PM   #126
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
Rule of thumb:
Octane > Tune Specific = usually OK
Octane < Tune Specific = ALWAYS bad!
CamryDS is offline   Reply With Quote
OFT Tune for OFH+Phantom ESC with 1.5 Dump Pack [Beta] Shiv@Openflash Forced Induction 226 03-12-2019 09:26 PM
iOS 8 beta 1 not working on BRZ USB Kids Heart Off-Topic Lounge [WARNING: NO POLITICS] 4 04-13-2015 08:17 PM
v2.01 Phantom ESC 1.5+OFH (BETA)... now supports USDM 6AT Shiv@Openflash Forced Induction 3 07-26-2014 12:23 PM
OFT 1.42 vs 1.5x Beta Who notices a Difference? Cross Software Tuning 11 03-21-2014 03:17 PM
Anyone want to beta-test some door speaker spacers? phenryiv1 Electronics | Audio | NAV | Infotainment 63 08-20-2012 09:02 PM
