Old 07-12-2014, 05:51 PM   #43
kodyo
Drives: Scion FR-S
Originally Posted by DC2R View Post
Thanks. Rattle is definitely coming from that area
Sent from my SM-N900T using Tapatalk
There's also a little box held in by a bent over metal leg you can see from the trunk. If you grab that leg with pliers and bend it more to make it grip better, that may help. Go through the other rear deck clicking threads if you want a better explanation and pictures. A lot of those threads go through multiple fixes.
Edit: http://www.ft86club.com/forums/showp...&postcount=459
That should help
kodyo is offline   Reply With Quote
The Following User Says Thank You to kodyo For This Useful Post:
DC2R (07-13-2014)
Old 09-11-2014, 12:33 AM   #44
USN.Spence
Drives: 2013 Galaxy Blue BRZ
So what exactly is this crack/pop? I occasionally hear a like squeak/pop when I accelerate or go over a bump, and I thought it was my suspension.. ?
USN.Spence is offline   Reply With Quote
Old 09-11-2014, 05:50 PM   #45
kodyo
Drives: Scion FR-S
Basically that. The rear deck (trunk area) will squeak/crackle on bumps & various other load changes that cause flexion.
Find all of the welded seems in the trunk area and spray a lubricant between the various panels. Then use a piece of plastic (or a screw driver if you dare), and GENTLY apply some force between the panels until they creak and stop. Don't put more than a few pounds of force at the end, the goal here is not to yield material.
The Following 2 Users Say Thank You to kodyo For This Useful Post:
Mikepage (09-12-2014), USN.Spence (09-12-2014)
Old 09-11-2014, 05:56 PM   #46
johnnyfast11
Drives: none yet
search for a thread that I've contributed several pictures on. it fixes all of them poppings. i recal there's more than 15-20 places that could happen. sooner or later. so do them all.
johnnyfast11 is offline   Reply With Quote
The Following User Says Thank You to johnnyfast11 For This Useful Post:
Old 09-12-2014, 01:11 AM   #47
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
DIY - Fix your Rear Deck "popping/clicking/tapping/ticking" noise.
My DIY is not enough complete for you?
o= FR-S =o
Mikepage is offline   Reply With Quote
The Following User Says Thank You to Mikepage For This Useful Post:
FyeaFRS (09-12-2014)
Old 09-12-2014, 05:57 PM   #48
johnnyfast11
Drives: none yet
your DIY = S E X
Old 09-12-2014, 10:59 PM   #49
cywinr
Drives: DGM BRZ MT
I've taken everything apart three times. I even took the spare tire out and did the bottom of the trunk, side walls, everything I could ever take apart and there is still a lot of noise. I'm getting obsessive... snap crackle and pop are irritating me even over my loud-ass greddy EVO3...
I think I'm doomed.
cywinr is offline   Reply With Quote
Old 10-08-2014, 02:52 PM   #50
snidd111
snidd111's Avatar
Drives: Scion FR-S
I think I'm doomed.
Did you check the center break light? That really did matter when I added a small sub to the trunk. Wish I had taken a picture. It wasn't hitting the glass but the main body just snaps onto the bottom mount. Not very secure.
snidd111 is offline   Reply With Quote
Old 10-19-2015, 04:52 PM   #51
djdnz
1337
Drives: 2013 BRZ WRB S/C
1 : Remove your Rear Deck like this :
http://www.ft86club.com/forums/showthread.php?t=10002
2 : "Crack" each spot weld carefully with a flat screw driver on each side, he probably miss some pictures but take your time and don't forget any spots if you don't want to remove the rear deck twice. You just need to push the screw driver into the crack and twist it carefully and slowly, you are supposed to heard a little cracking and you need to twist until the cracking sound stop.
***Important : When I say "CRACK", it's not crack enough like to break spot weld, but to only crack, you just need to squeeze and turn the screw driver a little bit and slowly.
Now, i never heard any cracking noise from the rear deck anymore.....finally!!!
Enjoy
Mike
Wow I am so happy I found this post!!!!!!
I have an early 2013 BRZ which was affected by the TSB so I originally took my car into the dealership about 1.5-2 years ago, and they did the fix to the lower portion of deck as described in the TSB. At the time I was only having a few loud pop noises. When they did the TSB, the noises I had were fixed and life was great.
But about 3 months later, I started to get more noises, and then more, and then it got to the point that I could not drive without having my backseats closed and music on because the car sounded like a popcorn machine. It was absolutely driving me crazy and I was starting to really dislike the car.
I took the plunge, took out the rear deck with much cursing - followed your guide and "cracked" every single one of the spot welds on the rear deck panel, as well as the ones going to the strut mount and then drenched them in WD40 Specialist Lithium Grease. At first I was nervous about the cracking, but as soon as you do one you understand what that means - it was very easy. Anyways I've driven for two days since doing the fix now and I havent heard a single creak, pop or rattle. The car smells a little funny, but I still have to clean it up a little and let it air out a bit more. I am so thankful for this guide, you're the best!!
djdnz is offline   Reply With Quote
The Following User Says Thank You to djdnz For This Useful Post:
Mikepage (10-19-2015)
Old 10-19-2015, 04:55 PM   #52
Mikepage
Mikepage's Avatar
Great to hear, thanks men!
o= FR-S =o
Old 04-05-2017, 10:27 AM   #53
fazlook
Drives: FRS
Who is in Ottawa to check if there is a noise on my car
fazlook is offline   Reply With Quote
Old 10-21-2020, 01:53 PM   #54
Biggumzzz
Drives: Toyota 86 2014 GTS
Photos are gone any way to fix that?
Biggumzzz is offline   Reply With Quote
Old 10-21-2020, 02:34 PM   #55
jeffchap
jeffchap's Avatar
Drives: 2013 Scion FR-S Raven 6MT
Doubtful, 3 and a half year old post. Just drive it, it'll go away eventually. I think mine took 6 months or so to finally quit popping. Hasn't done it in 5 years now.
Sent from my moto g(8) power using Tapatalk
Stay squatchy, my friends
jeffchap is offline   Reply With Quote
Rear Deck "popping/clicking/tapping/ticking" noise. Sigh-on-Rice Issues | Warranty | Recalls / TSB 637 04-28-2020 04:55 AM
Subaru TSB 12-140-12 for Rear Deck Popping sparks Issues | Warranty | Recalls / TSB 31 07-17-2013 11:11 AM
GTS rear left popping/clicking sound and fix. sigmaoctantis AUSTRALIA 11 05-19-2013 06:58 AM
Ticking/Clicking Noise front - passenger side PoRco Scion FR-S / Toyota 86 GT86 General Forum 9 05-06-2013 05:55 PM
Rear deck popping/clicking DriftEightSix AUSTRALIA 6 02-01-2013 01:59 AM
