Old 09-10-2014, 04:10 PM   #29
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
P.S. I'm tired and cranky
Td-d is offline   Reply With Quote
The Following User Says Thank You to Td-d For This Useful Post:
JB86'd (09-10-2014)
Old 09-10-2014, 04:30 PM   #30
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by Td-d View Post
Guys - I know Ecutek is awesome and all, but this scaling has been on the IAT activation tables used on Subarus for time immemorial. Maybe I'm just used to reading it, but -100% makes sense to me - 100% of the compensation is removed, in other words no compensation is applied. 0 means none of the compensation is removed.
Tomato / tomato.
They both make sense if you know how to read them Even if the scaling isn't changed, at least some might now realise. I didn't look into the RR definition to see whether it was made clear.
.: Stealth 86 :.
Kodename 47 DJ:
The Following 3 Users Say Thank You to Kodename47 For This Useful Post:
JB86'd (09-10-2014), steve99 (09-10-2014), Td-d (09-11-2014)
Old 09-10-2014, 06:20 PM   #31
steve99
Drives: FT86
Yes had it round the wrong way corrected my stuffups thanks guys.
Old 09-10-2014, 06:24 PM   #32
steve99
Drives: FT86
Interesting their is no timing compensation applied for Engine Coolant temperature.
Might be a good failsafe to pull a bunch of timing if the coolant gets too hot at least you would feel the car loose power and know something was up.
Old 09-10-2014, 07:06 PM   #33
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Hey @steve99 I'm curious if you've done any changes to the tip in retard and tip in enrichment tables. From the looks of my 3rd-4th-5th logs it really look like the amount of knock correction applied by the computer is effected by both temperatures AND tip in knock.
The tune that I'm on in these logs on the first post already has a bit of tip in retard and enrichment added. I'm thinking maybe the tip in retard needs to be increased in relation to the IAT as well.
Old 09-10-2014, 09:20 PM   #34
steve99
Drives: FT86
Have not adjusted tip in retard or enrichment. by running our 100Ron fuel and a couple of tweeks to temp and Knock correction timing I have almost zero knock now. Just waiting for the hot weather to return to check at high temps.
solidONE (09-10-2014)
Old 09-10-2014, 10:15 PM   #35
R2
Has someone been able to confirm that you can put positive numbers in the IAT compensation table and have a resulting advance in timing? I'm hoping there is no absolute value computation in the formula which would result in less timing regardless of sign.
With cooler temperatures arriving now that it is fall, I am playing around with increases in base timing. I'm hoping to see a knock free increase in timing develop below 10C. I can see this is likely a tough balance given MAF loads increase with cooler denser air as well.
R2 is offline   Reply With Quote
Old 09-10-2014, 10:52 PM   #36
solidONE
solidONE's Avatar
Haven 't had a chance to test if it will add advance yet. It's still hot like the devil's butt crack around these parts.
Old 09-10-2014, 11:05 PM   #37
R2
I wish, take a look at my forecast, it's colder than a nun's **** here this week. http://weather.gc.ca/city/pages/sk-32_metric_e.html
Looks like I'll have that answer soon.
The Following User Says Thank You to R2 For This Useful Post:
Old 09-11-2014, 01:22 AM   #38
steve99
Drives: FT86
I accidently put a positive value in the table iat vs temp and it did not upset anything, unfortunatly it was winter and iat did not get to the trigger temp so i carnt tell you if it worked but it certianlty did not cause any problem.
Old 09-11-2014, 06:07 AM   #39
Td-d
It is odd, all the other roms start pulling timing heavily beyond 230F.
steve99 (09-11-2014)
Old 09-11-2014, 06:16 AM   #40
steve99
Drives: FT86
thanks
might check out a wrx rom and see what they do seems like a worthwhile addition.
Old 09-11-2014, 06:19 AM   #41
Td-d
The figures are not constrained, no - so positive values should work as well.
Old 09-11-2014, 06:20 AM   #42
Td-d
thanks
Most of the roms I've seen pull 2.11 degrees in the top cell.
Knock Correction vs Knock Correction Learn values? swift996 Software Tuning 19 11-03-2015 10:09 PM
FR-S Rod knock pozer Issues | Warranty | Recalls / TSB 95 11-03-2015 09:39 AM
FS: BNIB Prosport Guages (Water Temp / Exhaust Gas Temp) AtlasMick Interior Parts (Incl. Lighting) 2 03-31-2015 05:47 PM
Tip in knock? bmsi30 Issues | Warranty | Recalls / TSB 17 08-25-2014 04:12 PM
STRI DSD SLM II Gauges (boost/oil temp/oil press/water temp/egt) BNIB ziptiedae86 Interior Parts (Incl. Lighting) 0 10-29-2013 11:50 PM
