#5307 | |
Add lightness!
Drives: 17' WRX
#5308 |
That Guy
Drives: 2013 asphalt FRS MT
OH MY GOD!!!
Someone on the manufacturing side of these kits actually posted, and then answered questions! This is a VAST improvement in communications already. Can you tell us what is different about the 210+? There's been some talk about it being a coating added to the rotors, but that doesn't seem right to me. As I understood it, the max sustainable rpm of the 210+ is increased, which to me means the critical speed of the shafts must be increased. That requires either reduced weight or a stiffer material. Or both. So, can you shed some light on to this for us? Oh, and welcome to the board. |
#5309 |
Drives: GT 86
It is a coating on the rotors which completely seals the rotors enabling them to be more efficient by pumping more air from what I've heard.
#5310 | |
Super 86
Drives: Red 86 GTS
Also excellent Sprintex has finally joined us
230rwhp/184ftlb on 98RON/93AKI
Build thread Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can |
| The Following User Says Thank You to Khorne For This Useful Post: | Calum (09-10-2014) |
#5311 |
Bearings and oil cooling could be an issue too.
| The Following User Says Thank You to s2d4 For This Useful Post: | newcscsl (09-08-2016) |
#5312 |
Super 86
Drives: Red 86 GTS
Possibly, that being said Mark has said to me and a few others that we should be able to just swap the rotors into the 210 housing.
#5313 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
I think the big question here is this:
At what pulley size does the 210 leave off and a 210+ be considered? |
#5314 |
Drives: 2014 FT86
I've been lurking for a little while, rescuing folks who needed parts
. PR was Innovate's deal, so we just kept quiet and let them run with it. We have no hard feelings towards them. It's just a good time to pipe up and say "Hi".We're looking at two standard pulleys, 75mm(non-ic) and the 69mm (ic). CARB approval depends on the tune, which the last I heard is still in Bill's corner. The systems just arrived here recently, so I'm still getting up to speed on the details. We have a whole lot of nice new things coming about. Yes, the +plus upgrade is a conformable coating on the rotors. I don't have any data on the conformable coating in-hand, so I can't answer many questions about it. It does allow for better breathing from the same unit, providing a "zero tolerance" of sorts between the rotors themselves and the housing. I have no idea what the new max rpm is, but can find out. Bearings and seals do more to determine allowable speed than the rotors themselves. Reducing operating temperatures does let you spin the blower at a more sustained RPM. There's only so much the 210 can do even with the conformable coating, that's why there's the 335 option. The 335 will also have the conformable rotor option when it comes available. We don't sell a "huge rush of top end power" like a turbo or a centrifugal blower; We sell a huge rush to GET TO the top end! The 210 system was aimed at those who love to drive their cars. Racers will make much better use of the 335, IMO. Conformable rotors are a nice added bonus to both. I've said this a lot, that supply chain management is the 1,000lb gorilla in the room and it's true. I'm just happy to have added staff and more help in growing the company now .
| The Following 14 Users Say Thank You to SprintexUSA For This Useful Post: | Calum (09-11-2014), Captain Caveman (09-10-2014), CK_Bladesmith (09-10-2014), clayrush (09-12-2014), Dustin (09-10-2014), gonzo (10-13-2014), industrial (09-11-2014), J.C. (09-10-2014), kbogarto (09-10-2014), Khorne (09-10-2014), Lawnik (09-10-2014), Raven604 (09-10-2014), tahdizzle (09-10-2014), whataboutbob (09-11-2014) |
#5315 |
Drives: e92m
Will the 335 kit require an additional upgrades that aren't already included?
#5316 |
Drives: gt86
Will the stock engine be able to handle the upgraded system or are engine upgrades needed also?
#5317 |
Drives: GT 86
#5318 |
Drives: 2013 SWP BRZ
@SprintexUSA - will there be any kind of warranty setup for those who have the crappy batch of bolts and would like the new ones? I had a few break on me but had a ton of extra from when I purchased the intercooler...but would be sweet if I could get my hands on the new bolts so I don't have to worry about it again. I have to pull the elbow off the rear of my charger to get to something back there and it would be a good time to swap out some of the bolts that are in the hard to reach areas, especially in the back.
#5319 |
Drives: 2013 Ultramarine FR-S
I haven't checked into this thread for a long time, but someone posted up a dyno of the 335 on a built motor with 10.5CR. I believe it is the same guy who blew his stock motor when he bolted on the 335. Just thought I would share.
| The Following User Says Thank You to Freeman For This Useful Post: | whataboutbob (09-11-2014) |
#5320 |
Add lightness!
Drives: 17' WRX
Good lord. Dat low end torque.
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
