Old 09-09-2014, 12:38 AM   #57
steve99
Drives: FT86
Originally Posted by solidONE View Post
Where is U0155 located in the defs? I could not locate it under 'diagnostic trouble codes' folder.
when I was having dramas with the D00G rom Tdd added it to the standard romraider defs for me .
Shiv said he is going to disable U0155 in the latest 2.06 release so no doubt he will need the updated defs to do they should be out later today and the 2.06 tunes should have that code disabled anyway
Old 09-09-2014, 03:23 AM   #58
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I guess I'll just have to transfer all the modified tables to v2.06 then.
Old 09-09-2014, 03:36 AM   #59
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
FWIW, it's easy to disable the U0155 code without the toggled defined in the XML. Using a hex editor, just hex search for "01C15500" and replace it with "00C15500". That 01 to 00 will disable the code. This applies to all ROM types. This sequence will be located around the 0x110000 address or there abouts
Shiv@Openflash is offline   Reply With Quote
Old 09-09-2014, 10:45 AM   #60
janvier
Drives: white Toyota GT86
where's the link to the v2.06 files, please? i only see v2.05 Beta Off-The-Shelf (OTS) Maps and XML files on your website
janvier is offline   Reply With Quote
Old 09-09-2014, 11:01 AM   #61
lucid215
Originally Posted by Shiv@Openflash View Post
I'm going to be pushing back the release date of the v2.06 maps until tomorrow
Cheers,
shiv
he posted that yesterday so they will be up today. give the guy some time to work on it
lucid215 is offline   Reply With Quote
Old 09-09-2014, 11:09 AM   #62
janvier
sorry, i have missed that, thought it was posted yesterday..
Old 09-09-2014, 11:30 AM   #63
lucid215
it happens haha
Old 09-09-2014, 03:55 PM   #64
elBarto
elBarto's Avatar
Drives: Toyota GT86
This should answer it
Hi guys,
Looks like the proposed map released date also coincided with a new firmware release (v1.29) and a new OF Manager software version (v1.10.4) that should be available for download later tonight. So to keep to many updates from happening all at once, I'm going to be pushing back the release date of the v2.06 maps until tomorrow
Also remember that Shiv lives in San Francisco wich is a (minus) 9h difference with Belgium.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
Old 09-09-2014, 04:06 PM   #65
Shiv@Openflash
Drives: 2013 FRS
Usdm maps are done. Just working on all the other ones now. Yikes, I forgot how many different Cal IDs we support. Very time consuming to update them all
Old 09-09-2014, 05:27 PM   #66
GT86meMR2
GT86meMR2's Avatar
Drives: MR Spyder/GT86
Looks like we are all waiting for the EU map :p I'm curious how the stage 2 93/98 uel map feels with my jdl header and berk frontpipe :p
GT86meMR2 is offline   Reply With Quote
Old 09-09-2014, 06:37 PM   #67
DEK186
DEK186's Avatar
Drives: 86 GT MT Velocity Orange
So since the G roms are still using the A01G base, is there a need to change out our RR definition files for V2?
DEK186 is offline   Reply With Quote
Old 09-09-2014, 06:39 PM   #68
Shiv@Openflash
Drives: 2013 FRS
Correct. The old v1.x definition are fine if you are running A01G based ROMs. You will know if you are using a non-compatible definition file since all the tables will look clearly wrong.
Old 09-09-2014, 08:05 PM   #69
aristo
aristo's Avatar
Drives: BRZ SWP 14
Does anyone have a recommendation for an overpipe to use with the open flash header?
Is replacing the overpipe along with the header even worth it at all? It looks a little more difficult to handle
aristo is offline   Reply With Quote
Old 09-09-2014, 08:29 PM   #70
lucid215
im running the invidia overpipe and they are not that hard to change
OFT Tune for OFH+Phantom ESC with 1.5 Dump Pack [Beta] Shiv@Openflash Forced Induction 226 03-12-2019 09:26 PM
iOS 8 beta 1 not working on BRZ USB Kids Heart Off-Topic Lounge [WARNING: NO POLITICS] 4 04-13-2015 08:17 PM
v2.01 Phantom ESC 1.5+OFH (BETA)... now supports USDM 6AT Shiv@Openflash Forced Induction 3 07-26-2014 12:23 PM
OFT 1.42 vs 1.5x Beta Who notices a Difference? Cross Software Tuning 11 03-21-2014 03:17 PM
Anyone want to beta-test some door speaker spacers? phenryiv1 Electronics | Audio | NAV | Infotainment 63 08-20-2012 09:02 PM
