09-07-2014, 05:53 PM | #1877 |
Fat on Corn Syrup
The Following User Says Thank You to kavanagh For This Useful Post: | AZP Installs (09-07-2014) |
09-07-2014, 09:55 PM | #1878 | |
-Mike Paisan Maintaining, Modifying and Educating TriState Enthusiasts since 2001. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs "Race Tested, Enthusiast Approved!" |
09-09-2014, 11:13 AM | #1879 |
Thanks
Im about to do an oil change should i switch to 5-30 or stickwith 0-20
09-09-2014, 11:21 AM | #1880 | |
Fat on Corn Syrup
Since I'm NA, I stay at 0-20, even though I'm in AZ where it's hot as Hades. |
09-09-2014, 11:29 AM | #1881 | |
Fat on Corn Syrup
People are just doing the muffler delete to more easily hear the engine. Even without full exhaust, you'll have to tune down in order to stay legal. The only reason I can see for a full exhaust, especially the header, may be in throttle response or to increase area under the curve. So that's +2 on header and +1 on cat remove/replace - 3 points that might be used in suspension, tires or aero which I imagine will contribute to quicker times more-so than area under the curve. But I'm just armchair mechanic-ing now.... |
09-09-2014, 11:30 AM | #1882 |
If you've got an oil cooler, you may want to go with a 30 weight to make up for the pressure drop across the cooler. Or so I've read...
I recently bought a Perrin oil cooler and will be switching to a 30 weight when I install it. This would only apply to air-oil coolers.
2022 BRZ Build 2013 FR-S Build |
The Following User Says Thank You to DarkSunrise For This Useful Post: | kavanagh (09-09-2014) |
09-09-2014, 11:34 AM | #1883 | |
Fat on Corn Syrup
I like the idea of keeping the system more 'closed' like in the coolant-oil type, but really want whichever will cool the most efficiently for high ambient temps in an NA car. |
09-09-2014, 11:47 AM | #1884 | |
1) From what I've seen, air-oil coolers are more effective in keeping oil temps cool. Perrin claimed they were seeing the ECU pulling timing above 212 F. On NA setups, Perrin's oil cooler seems to keep peak oil temps between 220-240 on the track. The typical water-oil coolers (Cusco, Forester XT) seemed to be in the 240-250 range. 2) An air-oil cooler adds additional oil capacity, typically 0.5-1q extra. 3) I didn't want to introduce heat to the coolant, even relatively small amounts. With a water-oil cooler, cold coolant coming out of the radiator would be first used to cool the oil, then cool the engine block. Given we know what detonation does to the DI seals on this engine, I didn't want anything to warm up the coolant before it got to the block. 4) This reason is minor, but my license plate is center-mounted on the grill, similar to this: With the Perrin oil cooler (especially the way it's mounted 1" off the floor), I can effectively block off air to the oil cooler for daily driving just by having a front license plate. This will also keep rocks/stones from hitting the cooler. When I go to the track, I can pull the license plate off to get air flowing.
09-09-2014, 12:18 PM | #1885 | |
Mike |
09-09-2014, 12:34 PM | #1886 | |
Fat on Corn Syrup
Correct. To stay 'safe' for a possible after race Dyno, guys are tuning to about 189 to allow for Dyno variances and not get a Disqualification. With the points accrual for the season you can drop your two lowest scores, but you can't drop a DQ - it will be held against you no matter how many races you miss. |
09-09-2014, 12:39 PM | #1887 | |
At 189whp they would need to have no fuel, no driver and they would still be way over. My stock car dynos at 168whp and tips the scales at just over 2700 without me in it. Mike |
09-09-2014, 01:17 PM | #1888 | |
Fat on Corn Syrup
Which means they can run up to 198.9 hp, so they tune down to 189 or so just in case a 9hp dyno variance kicks them over. They placed in the top 3 at the East Coast Nationals two weekends ago. Edit: at your weight assuming you weigh 150 lbs, bringing minimum race weight to 2850, you could run bang on at 200 hp to the wheels. but you must never ever dyno even 1/10th hp over that. |
09-11-2014, 10:09 AM | #1889 |
Drives: Toyota GT86. N/A for life
I have a set of 16x7 STI rims and was wanting to know what would be the better option for regarding tyre width.
I am looking at running the Advan 050 R/Spec tyre and was either looking at 225/45 or 215/45. Cheers |
09-11-2014, 11:21 PM | #1890 | |
Drives: 2013 BRZ Limited WRB
So I'm new to tracking but I am interested in getting a data logging box of some sort. I've looked at VBox and AIM particularly, but I was wondering if any of you had suggestions for the noob that I am. I'd love something that could also support a camera (is GoPro an option?) and overlays in video export if that's possible. I don't mind ''used'' at all, since from what I've seen they all start at around 600$. I'm setting a budget of 750$ for everything, but the lower the better !
Similar Threads | ||||
Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) -- General Topics | 11 | 05-31-2012 07:48 AM |
Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) -- General Topics | 20 | 01-10-2012 09:54 AM |
