CANADA Canada
Old 09-08-2014, 03:04 PM   #5881
Jason@DSG
Jason@DSG's Avatar
Drives: 1997 Eagle Talon TSi AWD
Thanks to everyone who came out to the first DSG meet! I was REALLY happy to meet you guys and was even happier to help someone with that oil cooler (even though he was received with friendly boo's haha).
Here's some pics: https://www.facebook.com/media/set/?...9032185&type=1
Jason@DSG is offline   Reply With Quote
Old 09-08-2014, 03:31 PM   #5882
Simon99
Simon99's Avatar
Drives: 2013 BRZ Limited WRB
Originally Posted by FRS_Ken View Post
This was pointed out to me at work by someone - we were discussing the use of ethanol in gas and the for the FRS/BRZ we have been told to use Shell 91 V-Power or Petro Can 94 because no ethanol is used in them, however the following was sent to me after the conversation:
http://retail.petro-canada.ca/en/independent/2056.aspx
"Does Ultra 94 contain ethanol? Does Petro-Canada still offer an ethanol-free gasoline?
Ultra 94 contains ethanol. Due to the fact that various fuel grades are blended at the point of sale, most grades of Petro-Canada fuel may now contain up to 10% ethanol. This represents a change from the previous state, where premium fuel was ethanol-free at Petro-Canada."
Is that true? Seems to be so from thier own website.
Shell V-Power 91:
http://www.shell.ca/en/products-serv...power/faq.html
FAQ #2 "Shell V-Power premium gasoline in Canada does not contain ethanol."
Personally, I do believe that V-Power is still ethanol free although the price being the same as Petro Can 94oct and having noticed a difference running 94 (especially after fill up at CMP) I do believe that living with the cricket for that extra octane is worth it. Just my 0.02$.
Originally Posted by VesperLynn
This car has allowed car enthusiasts to come from all different walks of life, car cultures, and brands. Just as a panda is black, white, and Asian; the 86 is Toyota, Subaru, and downright fucking sexy.
Simon99 is offline   Reply With Quote
Old 09-08-2014, 03:34 PM   #5883
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
The highest grade (octane) gasoline available to us locally is Petro94, formerly Sunoco 94. Both always had some levels of ethanol in their fuels, which in itself isn't really harmful, other than the crickets which is an FR-S specific issue. The ethanol in the fuel also helps to increase the gasoline's octane rating.
Only reason I would run the Shell 91 was not purely due to the lack of ethanol, but moreso that it is not blended at the pump. This also means pure 91 going into your car, as opposed to using a pump that also services 87 octane. How much of the 87 is still in the hose when you select premium at other stations?
Here's also a good article re; the pros and cons of Ethanol.
http://www.greencarreports.com/news/...-pros-and-cons
Typically ethanol content in your gasoline will give you lower mpg's since it is a slower burning fuel and the vehicle is not tuned for high content of Ethanol, making it less efficient.
Running E85 on a tune (i.e. OFT E85) is quite different though since now the tune is optimized for this fuel's parameters, which runs cooler and more efficient (i.e. carbon footprint) than gasoline.
Here's a cost comparison if you are considering running E85 on a tune:
E85 cost is typically 12-14 cents cheaper per litre than Premium fuel (91) or 16 cents less than Petro94, or 4 cents more than regular grade fuel.
Reg: 129.9
Mid: 139.9 +10
Pre: 145.9 +16
E85: 133.9 +4
Although I have noticed pretty much the same consumption using E85, but let's assume a 1L/100km difference, comparing 91 at 9L/100 and E85 at 10L/100.
The price per km is almost exactly the same since although slightly higher consumption, the price/litre is less.
This works out to:
Premium: cost/km = 13.13 cents, cost for 500 kms = $65.66
Ethanol: cost/km = 13.39 cents, cost for 500 kms = $66.95
So pretty much a wash in cost, with better performance and safer on the engine. Downside is there is 1 station in town, so bring jugs.
Your mileage may vary, pun intended.
Slick is offline   Reply With Quote
Old 09-08-2014, 03:34 PM   #5884
dolo
dolo's Avatar
Drives: '13 10 Series FRS
Lava RB Guy was rocking these GTF2's I believe. looks like a 9 in the front and a 10 in the back. I was wrong about them being 9.5 and 10.5 respectively.
http://www.ft86club.com/forums/showp...90&postcount=1
-Evan
dolo is offline   Reply With Quote
Old 09-08-2014, 03:35 PM   #5885
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
@FRS_Ken
What does this say?
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
Old 09-08-2014, 03:36 PM   #5886
dolo
dolo's Avatar
E85 cost is typically 14 cents cheaper per litre than Premium fuel (91) or 16 cents less than Petro94, or 4 cents more than regular grade fuel.
Reg: 129.9
Mid: 139.9 +10
Pre: 145.9 +16
E85: 133.9 +4
This works out to:
Thanks for the info.
You should design/patent a jerry can holder for the trunk!
-Evan
Old 09-08-2014, 03:49 PM   #5887
Simon99
Simon99's Avatar
Originally Posted by AznKirby View Post
@FRS_Ken
What does this say?
Its a fridge magnet
Old 09-08-2014, 05:02 PM   #5888
normancw
normancw's Avatar
Drives: 128i
On Andre's advice, I got 3 of these 20L gas cans. Three of them fit perfectly in the trunk with leaving room for a toolbox.
http://www.canadiantire.ca/en/pdp/20...l#.VA4VEmTt_Yk
Unfortunately, the only gas station that has E85 is still too far from my house, but I will using the cans to bring Petro94 to Calabogie.
I think I use about 30 litres/100km at Calabogie
normancw is offline   Reply With Quote
Old 09-08-2014, 05:26 PM   #5889
HeadBanger
HeadBanger's Avatar
Drives: '14 Subaru BRZ
@brz2013 an I through the tunnel was great.
Did you take the 13 to the 40 Pat? If so, did you like the tunnel under the Dorval Airport? I love that tunnel. They've just shortened it though which kind of sucks.
We should invade another meet in MTL before the season is over and just go through all the tunnels in the city lol
Life's too short to drive a boring car
HeadBanger is offline   Reply With Quote
Old 09-08-2014, 05:29 PM   #5890
Milo
Drives: 2014 Subaru Brz
I would be down just going through all the tunnels lol.. Even though I still have a stock exhaust, you guys can make the noise loll, I just like flying through those tunnels
I could always go down in my gt4 which is pretty loud, but sadly for me she started blowing smoke, this weekend, :-(
I was having too much fun going through the rally stages
Milo is offline   Reply With Quote
Old 09-08-2014, 07:13 PM   #5891
pushrod
Benched 86lb
pushrod's Avatar
Drives: Ultramarine FR-S
My fairly-accurate estimate for mileage while on track was 11.7 US mpg, which I believe is about 20 L / 100km. Reminds me of vehicles that I've owned that did worse than that on the street.
pushrod is offline   Reply With Quote
Old 09-08-2014, 07:34 PM   #5892
Ft86Chris
Winter ***e engaged
Ft86Chris's Avatar
Drives: Ashpalt 2014 Frs Manual
Hey folks,
I'm the new guy to the forum.
Picked up a Asphalt FRS a couple weeks ago, Love the car, Don't see to many in the area, I've seen a few, but not many,
Any meets happen? And does anyone have an ECUTEK tuner that good help me get a tune on my stock frs?
Chris
Ft86Chris is offline   Reply With Quote
Old 09-08-2014, 07:54 PM   #5893
Pbrown
Drives: 2013 Scion FRS Raven
Originally Posted by Ft86Chris View Post
Hey folks,
Chris
Welcome aboard Chris. Was that you I was talking to last week on Hawthorne? Most on here use OFT for their tune. Ecutek , I would try Lachute performance. Next meet is Friday night at Merivale and Hunt Club. 8:30 ish
Pbrown is offline   Reply With Quote
Old 09-08-2014, 08:30 PM   #5894
FRS_Ken
((•||=(86)=||•))
FRS_Ken's Avatar
Drives: '13 FR-S Ultramarine 6AT; '13 Yaris
On sale at Canadian Tire (Barrhaven) this instance:
Low profile 2ton jack looks pretty nice too :
https://www.dropbox.com/sc/h7usu36kg...1xjeHWn1LBHjSa
Cusco Suspension Braces | Eibach F & R sway bars | aFe/Takeda Intake | GReddy EVO3 | D2 RS Sport Coil-overs | TSW Interlagos | Centric Front Discs | Hawk HP+ (F) / HPS (R) | Goodrich SS brake lines | TSW & OZ Racing wheels | Continental & Hankook tires | JDP CF Front Lip | Rexspeed CF ground-effects kit | APR CF parts | Winjet headlights & fog lights | Valenti Smoked Reverse | TOM's LED taillights | CF interior upgrades | LED upgrades | and much more
FRS_Ken is offline   Reply With Quote
