CANADA Canada
Old 09-08-2014, 08:31 AM   #5867
dolo
dolo's Avatar
Drives: '13 10 Series FRS
Anyone needs one of these? Special FT86 Club Ottawa pricing in effect !
http://www.dsgperformance.com/Mishim...-PlateBRZ-FR-S
-Evan
dolo is offline   Reply With Quote
Old 09-08-2014, 10:02 AM   #5868
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
That was quite the doorprize! Didn't realize it was a FRS/BRZ specific kit.
Slick is offline   Reply With Quote
Old 09-08-2014, 10:22 AM   #5869
dolo
dolo's Avatar
Yeah I can't get over it, best door prize I have ever seen.
-Evan
Old 09-08-2014, 10:23 AM   #5870
dolo
dolo's Avatar
-Evan
Old 09-08-2014, 10:43 AM   #5871
Slick
Slick's Avatar
DP, stop gloating! LOL
Old 09-08-2014, 11:47 AM   #5872
Pbrown
Drives: 2013 Scion FRS Raven
oil cooler
Hi Evan . My car budget is blown for the year ( just ordered weathertek floor liners for both of our cars) however, if you haven't sold it by next spring I will definitely be interested. Wouldn't it help your turbo build though?
Pbrown is offline   Reply With Quote
Old 09-08-2014, 11:47 AM   #5873
jvincent
jvincent's Avatar
@dolo, nice prize.
On the topic of oil coolers, this seems to be another topic that is hotly debated, pun intended.
I can see if you are going FI that adding an oil cooler is probably a good idea because of the increased power/temperatures and since you are outside of the warranty space anyways the risk of an oil line leaking causing a failure is offset by the benefit of the cooler.
But for us NA guys I'm still not clear on the benefit. @Slick, I don't believe you run one and @AznKirby can vouch for how hard you drive.
That said, I'm thinking a Forester style cooler/warmer might be a good addition, even if it only lowers the temps by a few degrees. The version where they connect into the throttle body looks promising since it is a much simpler mod than the other route.
Old 09-08-2014, 11:55 AM   #5874
Slick
Slick's Avatar
I think an oil cooler should be on the list for someone tracking regularly, sometimes I think I'm flirting with danger in not running one yet. I tried to log data at the last track day but didn't do it right, but will try again to look at oil temps this weekend. I also don't use high $ oils, just the standard Toyota-spec synth. But at 54K now, other than a leaking cam cover the engine is still running strong (thank you Subaru for resolving STi engine issues).
Norm was running that OEM cooler on his car. It is a pretty clean install and also has the benefit of warming the oil on winter use as it goes in sync with coolant temps.
Old 09-08-2014, 11:59 AM   #5875
jvincent
jvincent's Avatar
I am considering the same cooler, just a different routing for the engine coolant than the other install, so it will also head the oil in winter.
Nobody has posted any data from the track for that particular setup, but even if it lowers the temp by a few degrees it's better than a kick in the head.
Old 09-08-2014, 11:59 AM   #5876
brz2013
brz2013's Avatar
Drives: 2013 wrb brz
I wish we had a vid of me and @HeadBanger ripping in the tunnels...sounded awesome
brz2013 is offline   Reply With Quote
The Following User Says Thank You to brz2013 For This Useful Post:
KingGeo (09-08-2014)
Old 09-08-2014, 12:06 PM   #5877
dolo
dolo's Avatar
PTuning uses some fancy laminar oil cooler to keep the front more open for the intercooler and water rad. I will scoop that one if/when I get their kit.
The gf is on board for me spending a few extra grand and going from the Jackson SC kit to the PTuning kit. Just need to save some more pennies, a lot more pennies..... lol
-Evan
Old 09-08-2014, 12:49 PM   #5878
UMB FR-S
UMB FR-S's Avatar
Drives: Ultramarine Blue FR-S
I'm going to look into the usefulness of the cooler and I might pick it up from you as I plan on going supercharger
-- Kenny
"I don't always use heel/toe, but when I do it's because racecar."
UMB FR-S is offline   Reply With Quote
Old 09-08-2014, 02:56 PM   #5879
FRS_Ken
((•||=(86)=||•))
FRS_Ken's Avatar
Drives: '13 FR-S Ultramarine 6AT; '13 Yaris
This was pointed out to me at work by someone - we were discussing the use of ethanol in gas and the for the FRS/BRZ we have been told to use Shell 91 V-Power or Petro Can 94 because no ethanol is used in them, however the following was sent to me after the conversation:
http://retail.petro-canada.ca/en/independent/2056.aspx
"Does Ultra 94 contain ethanol? Does Petro-Canada still offer an ethanol-free gasoline?
Ultra 94 contains ethanol. Due to the fact that various fuel grades are blended at the point of sale, most grades of Petro-Canada fuel may now contain up to 10% ethanol. This represents a change from the previous state, where premium fuel was ethanol-free at Petro-Canada."
Is that true? Seems to be so from thier own website.
Shell V-Power 91:
http://www.shell.ca/en/products-serv...power/faq.html
FAQ #2 "Shell V-Power premium gasoline in Canada does not contain ethanol."
Cusco Suspension Braces | Eibach F & R sway bars | aFe/Takeda Intake | GReddy EVO3 | D2 RS Sport Coil-overs | TSW Interlagos | Centric Front Discs | Hawk HP+ (F) / HPS (R) | Goodrich SS brake lines | TSW & OZ Racing wheels | Continental & Hankook tires | JDP CF Front Lip | Rexspeed CF ground-effects kit | APR CF parts | Winjet headlights & fog lights | Valenti Smoked Reverse | TOM's LED taillights | CF interior upgrades | LED upgrades | and much more
FRS_Ken is offline   Reply With Quote
The Following User Says Thank You to FRS_Ken For This Useful Post:
dolo (09-08-2014)
Old 09-08-2014, 02:59 PM   #5880
Trac Toy
Trac Toy's Avatar
The factory unit from the forester is relatively easy install, but just be aware that it functions less as a cooler and more of a stabilizer. It reduces the temp spikes but over a 25-30 min session oil temps still climb to the 230 mark. I'll check my logs and get you guys an accurate number.
It's certainly worth having in my opinion for the ease of install and lower cost of installation.
.o0+Eric+0o.
2016 Chrysler 200S 3.6
2013 FRS 6MT
Trac Toy is offline   Reply With Quote
