Old 09-08-2014, 11:14 AM   #1
MrAnthonyC
Antagonist
MrAnthonyC's Avatar
Drives: 2014 Scion Fr-S (Firestorm)(stock)
Question Teach me how to drive!
Hello guys.. so after getting this car, I have really been interested in improving my driving. My two main concerns right now are fuel efficient driving and maximium acceleration. Yes, I know those two don't go together but I am interested in improving in both aspects.
For fuel efficiency, how do you guys find you can keep your MPG up? I am getting about 24-25 mpg right now with street and hwy driving. I know that is about right for this car but i'm curious on methods of maybe getting that up. I use 93 octane gas btw, not sure if that affects it.
For accelerating, how do you create the most acceleration in the car? I believe it has to do with shifting gears at certain RPM, right? I am a novice obviously...
Thanks guys!
MrAnthonyC is offline   Reply With Quote
Old 09-08-2014, 11:20 AM   #2
JM9ISM
Drives: 2014 BRZ WRB LTD
My eco mode is to shift around 2500 rpm, but I can''t resist to drive slow in this car.
JM9ISM is offline   Reply With Quote
The Following User Says Thank You to JM9ISM For This Useful Post:
MrAnthonyC (09-08-2014)
Old 09-08-2014, 11:23 AM   #3
rs999
rs999's Avatar
Drives: VW MK6 GTI | 13 Mustang GT
I use cruise control and 6th gear as much as possible and shift around 3000 RPM.
SOLD FR-S Build | MK6 GTI Build | I might be getting another FR-S
rs999 is offline   Reply With Quote
The Following User Says Thank You to rs999 For This Useful Post:
Old 09-08-2014, 11:25 AM   #4
DarkSunrise
DarkSunrise's Avatar
For fuel efficiency:
1) When accelerating, be light on the throttle and upshift at 2500-3000 RPM.
2) When cruising, upshift to the highest gear that will keep you above 2000 RPM.
3) Note: if you encounter an incline, downshift to avoid lugging your engine.
For maximum acceleration:
1) Downshift into the lowest possible gear that will keep you below 7400 RPM, press the throttle fully, and upshift when the tach hits 7400 RPM.
2) Note: make sure you understand the gearing in the car. If you exceed 7400 RPM on your downshift, there is a good chance you will damage your engine.
2022 BRZ Build
2013 FR-S Build
The Following 5 Users Say Thank You to DarkSunrise For This Useful Post:
dhuang (09-08-2014), lantsalot (09-09-2014), MrAnthonyC (09-08-2014), strat61caster (09-08-2014), TJ3000 (09-08-2014)
Old 09-08-2014, 11:35 AM   #5
MrAnthonyC
Antagonist
MrAnthonyC's Avatar
a-fucking-greed. (agreed)
It's just so tempting to zip around in this car!
Old 09-08-2014, 11:41 AM   #6
MrAnthonyC
Antagonist
MrAnthonyC's Avatar
Is there any noticeable lag on the tach? Hypothetically, if I was fully depressing the throttle and trying to shift at precisely 7400 rpm, would I shift a moment before the needle hit it, or is the tachometer pretty much exact? I'm a computer guy..i'm used to things lagging behind..
Old 09-08-2014, 11:42 AM   #7
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
Good tips. I'd recommend most people to start upshifting at ~7000 if they're trying to learn. Chances are, they can't shift quickly nor smoothly enough if they begin the upshift at the redline.
Jyn is offline   Reply With Quote
The Following User Says Thank You to Jyn For This Useful Post:
Old 09-08-2014, 11:46 AM   #8
DarkSunrise
In my 6MT, I haven't noticed any lag on the tach. I can upshift right at 7400 RPM.
@Jyn raises a good point though. If you're still new at this, you may want to practice upshifting at 7000 RPM until you get the hang of it.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
Old 09-08-2014, 12:45 PM   #9
Majik
Majik's Avatar
Drives: '14 Subaru BRZ SWP Limited
Follow this advice to a T and you should get everything you asked for. Also be careful, Long Island drivers suck.
Majik is offline   Reply With Quote
The Following User Says Thank You to Majik For This Useful Post:
MrAnthonyC (09-09-2014)
Old 09-08-2014, 07:27 PM   #10
Ubersuber
Drives: BRZ Pearl White
You need not worry about overrevving this engine while accelerating up through the gears as the engine is electronically rev limited to 7,400 rpm, and as a bonus it seems the rev limiter is a soft limiter: the engine doesn't so much cut out as refuse to rev any higher. This is a bonus if you unintentionally hit the limiter before you actually shift. The trick is to shift just before the limiter cuts in as hitting the limiter will slow your acceleration runs. Generally I reach for the shifter as the tach passes through 7,000 rpm or so and then by the time the red light begins to flash indicating the rev limiter is about to cut in I can complete my shift.
Do NOT downshift at too high a speed for the gear selected. If you do so you may wreck your engine. There is no protection built in to the car to prevent you from making this mistake (unlike an automatic which usually just beeps at you if you paddle shift down to too low a gear). I'm pretty sure this engine will hold together at 8,000 rpm, maybe only once and I'm only pretty sure. Engines blow up when they are overrevved with the intake valve open on a cylinder. It's the inertia of the piston and connecting rod that breaks the rod or sometimes it's the inertia of the valve and spring that crashes the valve heads into the rising piston, referred to as valve float.
Should you ever sense that you've just selected too low a gear as you let in the clutch pedal shove that left foot to the floor immediately and hope you didn't reach the full rpm for that road speed in that gear. You do get some warning even from an engine that likes to rev this much but it is only a split second before the engine is actually driven to excess rpm by the wheels travelling too fast for the gear you thought you wanted. This is a very rev happy engine whatever the press may say about the noise and torque dips etc. It loves to rev and sounds great while doing it. It isn't a lot noisier at 7,000 rpm than it is at 5,000 rpm.
Learn to shift up aggressively before you learn to downshift aggressively.
Here's the calculated speeds in each gear:
http://www.ft86club.com/forums/showthread.php?t=6325
The spread is a little unusual in that you normally expect a mathematical progression. Why Subaru chose to make fourth closer to fifth and fifth closer to sixth than is ideal is puzzling which then makes the spread from 2 nd to 3rd look odd. This may account for the impression that second gear isn't quite tall enough, or first gear isn't short enough depending on whether 0-60 means anything to you or not. Normally you expect the speed differences as you shift up the box to become wider in nominal numbers: 22/24/26/28/30 would be within the expected range and a progression would be even more logical.
Also, the steps are 22 mph/26 mph/22 mph /22 mph/ and fifth to sixth is not relevant to the discussion because it will be an "overdrive" deliberately selected for fuel economy, this engine won't pull redline in sixth and that is now very usual.
Ubersuber is offline   Reply With Quote
The Following 2 Users Say Thank You to Ubersuber For This Useful Post:
dhuang (09-09-2014), MrAnthonyC (09-09-2014)
Old 09-08-2014, 10:31 PM   #11
dnieves
Drives: FR-S 10 Series
Hyper miling tips:
http://ecomodder.com/forum/EM-hyperm...ecodriving.php
dnieves is offline   Reply With Quote
Old 09-09-2014, 01:27 AM   #12
schmearcampain
Drives: 2014 Argento FRS 6MT
24-25? I usually get 30 and I shift at 3500 for the most part.
schmearcampain is offline   Reply With Quote
Old 09-09-2014, 02:21 AM   #13
Mim
Mim's Avatar
Drives: MY11 Maxima 350st, MY15 BRZ
Kinda left of field I know, but I belive the FRS still does not come equiped with the JDM underbody panels? I was wondering how much of an impact they might have on economy if you were to introduce them into the equasion along with lowering the car sligtly.
Still reading through it but found this thread really entertaining and kinda related to your query on improving economy, but from the physical mod rather than driver side of the coin - http://www.ft86club.com/forums/showt...nderbody+panel
Mim is offline   Reply With Quote
Old 09-09-2014, 02:27 AM   #14
noodlebaka
Drives: '13 FRS
Learn to drive better? Whatever you do, do it smoothly. Your passengers will thank you.
noodlebaka is offline   Reply With Quote
uberstupid
If Game of thrones can teach you something, it's that Winter is comming and..... Walla Walla Off-Topic Lounge [WARNING: NO POLITICS] 6 12-23-2013 02:39 AM
TGIF[R-S]: Can You Drive a Rear-Wheel Drive Sports Car All Year Long? No5ki Scion FR-S / Toyota 86 GT86 General Forum 27 01-06-2013 08:30 PM
