Old 08-21-2014, 07:50 PM   #897
hattrickey
Drives: Scion FR-S
Will 255/40/17 fit with RCE Yellow springs? Or, will it rub on the spring perch?
hattrickey is offline   Reply With Quote
Old 08-21-2014, 11:30 PM   #898
BRZ37J
BRZ37J's Avatar
Drives: a fast N/A BRZ
anyone running 17x9 Mach V Awesome with 255's?
BRZ37J is offline   Reply With Quote
Old 08-22-2014, 07:29 AM   #899
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Originally Posted by Jaden View Post
That seems a little counter intuitive there...
You want MORE tire BEFORE you rebuild the rear end???? or ONCE you rebuild the rear end...
More tire= more grip, more grip = more stress on the drive train...
^^^^^^ and weaker rear end = broke stuff...
Just saying...
Jaden
I realize that it's counter-intuitive, but before. I already have tires so I'm trying to use them. I can keep my food out of the floorboard so I believe I'll be able to get away with it. Easiest fix is to upgrade axles in the meantime and keep the stock diff until mine can be upgraded.
slicktop is offline   Reply With Quote
Old 08-27-2014, 08:34 PM   #900
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
I will buy new tires for my FRS and I am considering to get 265/35 for the rears but still haven't decided for the fronts.
Which one you guys recommend? My wheels are 18x8.5 +44 and I'm on FA coil overs.
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
Old 08-28-2014, 09:24 AM   #901
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
255/35R18 DW on 18X9.5 +40
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
The Following User Says Thank You to Figo For This Useful Post:
civicdrivr (08-28-2014)
Old 08-31-2014, 11:38 PM   #902
k.houan
k.houan's Avatar
Drives: BRZZZ
Originally Posted by VacantSky View Post
17x9 +45 RPF1 on 255/40 federal 595 *sigh* ss... Cheap tires for meow, I'll be getting the rs-r next:
What's your suspension setup? Looks great man
Sent from my LG-D851 using Tapatalk
k.houan is offline   Reply With Quote
The Following User Says Thank You to k.houan For This Useful Post:
VacantSky (09-01-2014)
Old 09-01-2014, 09:00 AM   #903
VacantSky
The Angry Brit
VacantSky's Avatar
Drives: 1991 E30 318iS
Thanks man! I'm running ISC coilovers, the wheels fit with stock struts and oem springs, and also with eibach sportlines too on 235/45's, not sure the 255's would fit on a regular strut set up with the +45 RPF1s
VacantSky is offline   Reply With Quote
Old 09-01-2014, 09:10 AM   #904
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
On the +45 wheels and 245/40/17 tires mounted, it still rubs a little with 5mm spacer in the front (total of +40 offset -2.5 camber). Although you might get away with 255's if you run little or no negative camber on the stock struts. Then again, what's the point if you can't dial in some much needed camber?
Old 09-01-2014, 03:39 PM   #905
k.houan
k.houan's Avatar
Drives: BRZZZ
Originally Posted by Touge Factory View Post
17x9 RPF1's
245/40/17 RS3's
What offset are these RPF1's?
Old 09-05-2014, 08:54 PM   #906
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
The Following 3 Users Say Thank You to OmarGC For This Useful Post:
deliroast (09-05-2014), Hicklinc (02-13-2018), humanshield (09-08-2014)
Old 09-05-2014, 09:18 PM   #907
eyedeez
eyedeez's Avatar
Drives: 2014 Firestorm FR-S 6MT
Originally Posted by OmarGC View Post
MOAR!
eyedeez is offline   Reply With Quote
Old 09-05-2014, 10:06 PM   #908
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Originally Posted by eyedeez View Post
MOAR!
Instagram @JZx86
2jz swap in progress
Omar GC
Instagram: 2jzus
The Following 4 Users Say Thank You to OmarGC For This Useful Post:
Guff (09-08-2014), Hicklinc (02-13-2018), thatWESguy (09-29-2014), toby714 (09-07-2014)
Old 09-07-2014, 05:30 PM   #909
ShutterSpeed
Drives: Olive Drab/Army FRS
Soon to join this thread. Swapped my AME Tracer TM02 (18x9.5 +22) for some Gram Lights 57Xtreme in Winning Blue (18x9.5 +40) and bought some 255/35/18 Hankook Ventus V12 Evo2 yesterday. Excited to get some meat under this car.
QUALITY OVER QUANTITY
ShutterSpeed is offline   Reply With Quote
Old 09-08-2014, 01:31 AM   #910
humanshield
Drives: bucket
wheel and tire specs?
humanshield is offline   Reply With Quote
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
