Old 09-06-2014, 10:16 PM   #15
MyEvilMonkeys
Drives: 2013 Scion FRS
Yea, I had same issue. Forum search kinda sucks but this was my post a few months back... http://www.ft86club.com/forums/showthread.php?t=64048
FA500 Coils/Swift/Radial Upgd, Cusco R.LCA, SPC R.Toe Arms, TqSol. R.SubFrame Bushings, MTEC Shift Springs, Perrin Shift Bushing/Trans Mount, Greddy SP Exhaust & Intake, RPF1 18x9.5 +38, 255/35-18 SDrives, Raceseng Ashiko Knob/Lockout
MyEvilMonkeys is offline   Reply With Quote
Old 09-07-2014, 02:08 PM   #16
Dezoris
Dezoris's Avatar
Thanks!
Old 09-09-2014, 12:04 AM   #17
MINOCIN
MINOCIN's Avatar
Drives: Asphalt 2013 FR-S
My car occasionally makes the same noise too, so I decided to check the strut nuts as well. I tried to wiggle the bar and it felt tight. I then checked the nuts with my fingers and they were not crazy loose. Finally, I set my torque wrench to 12 ft/lb and started with the driver side nuts and sure enough they were loose. Unfortunately, one of the bolts snapped on the third quarter turn
I checked the rest of the bolts and they all felt similarly loose, but I didn't perform more than one quarter turn on each because I was afraid of snapping another bolt.
Now that I'm missing one bolt I wonder if the noise will occur more often? In the mean time, I need to look for stronger bolts.
GFR - aka my build thread
"They don't think it be like it is, but it do." -Oscar Gamble
MINOCIN is offline   Reply With Quote
Old 09-12-2014, 11:14 AM   #18
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
It seems like you and I had the same crazy journey! Hopefully this knowledge gets spread and more people don't have to deal with months of worry.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
Old 09-12-2014, 04:33 PM   #19
Hanakuso
The fix to your issue seems strange to me. IIRC, those bolts were on very fit from factory when I loosened them
Hanakuso is offline   Reply With Quote
Old 05-18-2015, 03:34 PM   #20
Superhatch
AIM4APX
Superhatch's Avatar
My only thought was that lowering the car might have caused the bars to work a little harder, or interact with the frame in a different way which might have actually taken some stress off them? I'm not 100% sure about the root cause of why they loosened up, but I am 100% sure that tightening the nuts solved my issue.
Old 05-18-2015, 06:29 PM   #21
sittinSideways
sittinSideways's Avatar
Drives: '13 Firestorm FRS
Thank you so much for the write up!
sittinSideways is offline   Reply With Quote
Old 07-13-2016, 10:05 PM   #22
636
636's Avatar
Drives: '23 CWP BRZ
bringing it back from the dead. my car just started producing this same noise. I tightened those bolts..noise is still there.
636 is offline   Reply With Quote
Suspension clunk/thump going over bumps SloS14 Issues | Warranty | Recalls / TSB 31 11-19-2015 07:05 PM
rear suspension clunk Gen Issues | Warranty | Recalls / TSB 67 04-03-2015 08:52 PM
STI Pillowball Trailing and Lateral Links For Rear Suspension Do They Clunk? krayzie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 03-06-2014 12:47 PM
Sonoma Trackday Video (spinout included) orthojoe Tracking / Autocross / HPDE / Drifting 47 06-08-2013 12:29 AM
Clunk sound from rear suspension. j-tan Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 02-05-2013 12:39 PM
