Old 09-04-2014, 10:48 AM   #1737
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Originally Posted by Trouzorz View Post
Thanks for all your input!
TC can come back on despite being deliberately turned off? That sounds annoying if not outright dangerous
If you don't do the pedal dance it turns back on once you go over a certain speed, 31mph I believe.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 09-04-2014, 10:51 AM   #1738
natesparxxx
natesparxxx's Avatar
Drives: 2013 Whiteout Scion FR-S
If you just hold down the traction control button for 5 seconds it stays off no matter how fast you go
natesparxxx is offline   Reply With Quote
Old 09-04-2014, 11:03 AM   #1739
Siem Reap
Siem Reap's Avatar
Drives: DGM BRZ Limited
That video goes through the different traction control modes... VSC sport/TC off (3 second hold) /pulling the fuse and how the car reacts to the rear end breaking loose.
Siem Reap is offline   Reply With Quote
The Following User Says Thank You to Siem Reap For This Useful Post:
natesparxxx (09-04-2014)
Old 09-04-2014, 05:13 PM   #1740
sickmint79
Drives: bmw
doesn't it still come on though, thus the need for the pedal dance to make it fully go away? i've only done one track section with it off but i thought mine hopped on at one point for a bit.
sickmint79 is offline   Reply With Quote
Old 09-04-2014, 06:30 PM   #1741
DJCarbine
Thupercharged
DJCarbine's Avatar
I've seen the slip light come on during street driving as well, uneven roads and lifting one of the rear wheels causing it to free-spin will turn the slip light on and do some strange things sometimes.
This is with holding down the button to "disable" everything
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 09-06-2014, 12:46 PM   #1742
sickmint79
Drives: bmw
@DJCarbine does your overpipe rattle? have plm overpipe and front. OP is rattling when rough, easiest way to get it to rattle is 2nd gear start.
how much power are you making? have you needed to upgrade clutch? considering sprintex/innovate kit.
Old 09-06-2014, 05:21 PM   #1743
accelerated
Drives: Scion FR-S
I just traded my FRS in so I have a ton of stuff that's for sale. Click on my username and search for posts by me to take a look at what I have posted and feel free to PM me.
accelerated is offline   Reply With Quote
Old 09-06-2014, 05:32 PM   #1744
Dream20b
Y u do dis?
Link doesn't work^
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
The Following User Says Thank You to Dream20b For This Useful Post:
omfgwindmill (09-06-2014)
Old 09-06-2014, 05:33 PM   #1745
accelerated
Drives: Scion FR-S
Originally Posted by Dream20b View Post
Link doesn't work^
I think I fixed it.
EDIT: Link only works for me so I edited the previous post. Sorry for the inconvenience.
Old 09-06-2014, 05:36 PM   #1746
Siem Reap
Siem Reap's Avatar
I'd try this one.
Old 09-06-2014, 07:31 PM   #1747
Dream20b
Y u do dis?
Originally Posted by Siem Reap View Post
also doesn't work
Dat Hot Lava Doe
Siem Reap (09-06-2014)
Old 09-06-2014, 07:32 PM   #1748
Siem Reap
Siem Reap's Avatar
Oops. Disregard then.
cjd (09-08-2014)
Old 09-06-2014, 07:56 PM   #1749
DJCarbine
Thupercharged
DJCarbine's Avatar
I installed mine when I did my header, and installed the header first and worked my way back. Try completely loosening the exhaust from the rear of the overpipe, then loosen the bolts from overpipe-header and see if you can move the overpipe around for more clearance. The bolt holes allow for some movement, might be a quick fix
Not sure how much power, maybe ~270whp. Stock clutch is fine so far, innovate kit should be a lot of fun
2013 FRS
Vortech V3 11psi
The Following User Says Thank You to DJCarbine For This Useful Post:
sickmint79 (09-07-2014)
Old 09-06-2014, 11:11 PM   #1750
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Whoring out this pic
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
The Following 3 Users Say Thank You to OmarGC For This Useful Post:
Dream20b (09-07-2014), Jrryjms07 (09-07-2014), Siem Reap (09-07-2014)
Chicago Deliveries sieeegel Great Lakes 76 07-28-2012 01:26 AM
Anyone got vin# from Chicago? ebielat Scion FR-S / Toyota 86 GT86 General Forum 8 04-29-2012 10:27 PM
FR-S in chicago Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 24 03-03-2012 10:38 PM
Potenial buyers in Chicago The_Doctor BRZ First-Gen (2012+) — General Topics 17 02-28-2012 12:12 AM
Chicago Autoshow tachi1247 BRZ First-Gen (2012+) — General Topics 7 02-09-2012 11:24 PM
