Old 09-05-2014, 02:07 PM   #1
J.C.
Drives: '13 Raven FR-S
BRZ headlight conversion on FR-S
Hey guys I'm going to be installing the brz headlights onto my FR-S pretty soon. One problem I have is that one of the headlights I received is missing the 8-pin connector and the wiring harness was also cut off from the bottom (see attached picture).
My question is what would be the most ideal solution to fixing the wiring? I was thinking of buying a new wiring harness on ebay but I'm also willing to solder on new wiring with extensions. Doesn't seem too difficult and I believe I would need 10 or 12 gauge wiring?
I already ordered two 6 pin connectors from an early 2000 MR2 so I just need to figure this issue out.
Size:  249.0 KBName:  ImageUploadedByTapatalk1409936810.713750.jpg
J.C. is offline   Reply With Quote
Old 09-05-2014, 02:21 PM   #2
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
- Return the headlights for one that isn't damaged.
- Cut your FRS light harness and solder that in
How are you going to wire all the HID stuff?
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 09-05-2014, 02:35 PM   #3
J.C.
Seems like cutting my harness and soldering it would be a quick fix. I was wondering about the HIDs too. I want the boomerang to stay on so I'm assuming I'd have to splice it too.
GT86 Headlight Conversion Noz Cosmetic Modification (Interior/Exterior/Lighting) 12 07-23-2014 12:35 AM
FR-S to BRZ Headlight Conversion? tdoggy57 Cosmetic Modification (Interior/Exterior/Lighting) 7 01-30-2013 03:28 PM
Headlight conversion? Noz Cosmetic Modification (Interior/Exterior/Lighting) 14 01-09-2013 04:18 AM
JDM Headlight Conversion, anyone do it yet? HATED1 Cosmetic Modification (Interior/Exterior/Lighting) 0 10-11-2012 10:51 PM
