#15 |
Drives: 2013 Whiteout Scion FR-S
Not yet. (Knock on glass)
If a cop pulls up next to me I pretty much have to leave in 3rd gear to keep quiet. Sent from my iPhone using Tapatalk |
#16 |
Drives: Raven FR-S 6M
P0420 is typical for catless systems but P0172 is telling you that you are running too rich. I wouldn't ignore this.
- Faulty front heated oxygen sensor - Ignition misfiring - Faulty fuel injectors - Exhaust gas leaks - Incorrect fuel pressure - Faulty Mass Air Flow (MAF) sensor
“The World is Flat”
[||•]=(86)=[•||] |
#17 |
Drives: '18 STi
Don't worry, it'll take about 20 or so miles for your ECU to relearn everything. While "completing" the 20 or so miles, try to just keep at a constant and consistent speed- it'll definitely help with your ECU relearning everything faster. This process is basically the same with the OFT, when a new map is flashed.
#18 | |
Drives: FT86
i would bet your uni-chip is playing up , check all the connections to the sensors, check its got a solid ground and +12v supply its best to run a direct groun and separate fused 12v supply, others have had similar issues due dodgy ground or 12v supply. or the unichip itself is stuffed remove unichip if problems gone its the unichip or installation/connections the ECU learns in a few minutes if its been going on more than that you have a problem. . |
#19 |
P0420 is the O2 sensor. Your car is probably running extremely rich when that CEL goes off. You need a real tune.
#20 |
Drives: SWP BRZ
yeah like others mentioned, i think it's with Unichip, i would get OFT or ECUTEK
#21 |
Drives: 2013 Scion FR-S Raven 6MT
I get a P0172 periodically, and I can usually tell right before it happens because my car starts bogging from a stop. Take your MAF sensor out and spray it off with MAF cleaner. That fixes it for me for a few weeks.
Sent from my RM-820_nam_att_100 using Tapatalk
Stay squatchy, my friends
#22 |
Drives: 2013 GBS BRZ Limited
Unichip for this car is kind of like trying to play WOW on a TRS-80
#23 | |
Drives: MY00 Impreza 2.5RS
Does your unichip show system "ready" status? I have a scangauge and it lets me know if the system is "ready" or "not ready" after clearing codes. P0420 is a bitch to get rid of with aftermarket exhausts. The extra flow of the exhaust fouls the O2 sensor which needs to operate at a certain temperature to work. I run an O2 sensor spacer and the code still shows up but doesn't show up as often. Since the computer shows the 02 sensor failing it might make the car run more rich to "protect" the engine thus making you pull the other code. Running too rich chokes the engine and power, so that might be why it feels slower. With a very high flowing exhaust I would look into some open source tuning. With open source you could even delete the P0420 code from the ECU so it doesn't show up again. |
#24 |
P0420 needs the rear O2 sensor deleted most of the time. Highway driving throws this code the most. Someone who city drives all the time may not see it. Deleting the rear O2 will cause you to instantly fail inspection due to the evap sensor failing the test. Its good to have two Ecutek roms:
Rom 1 is your regular tune with multiple maps with the O2 deleted Rom 2 is your same tune, but with the O2 sensor back on, simply for inspection. Hope this helps. |
#25 | |
Drives: asphalt fr-s
I'll probably be looking at OFT to replace the Unichip in the medium-term. |
#26 |
Drives: FT86
P0420 is cat efficiency code triggered of second 02 sensor. Happens all the time with catless headers, if you had a flash tuning device you can just disable the P0420 code, no problem
Its the primary 02 sensor that does the feedback for AFR correction/monitoring. Its likely the P0172 is due to the MAF sensor as others have suggested although unless your running an oiled filter and you over oiled it you should not need to be cleaning your maf sensor. It likely he unichip is not programmed correctly or connection to maf is faulty or the unit itself is faulty or does not have a solid earth or 12v connection. |
#27 |
Okay this just happened.
I was leaving a car meet and that all popped up. I've never seen the traction light solid there. So I pull over and I have these codes P0172 B03AF P0D0F B044C Then I clear the codes with the flux and The tach starts "dancing" and jumping. While I'm in neutral and not touching the gas. Then this pops up I'm so confused what's happening. I haven't had time to take the unichip off but I'm starting to get worried Sent from my iPhone using Tapatalk |
#28 | |
BAMF
| OFT - First E85 tank in my car. Acting weird. | SloS14 | Software Tuning | 37 | 06-01-2014 10:37 PM |
| Weird Idea. Or Not... | FlamingRectumSyndrome | Scion FR-S / Toyota 86 GT86 General Forum | 18 | 04-25-2014 09:43 AM |
| Power Windows acting funny | sufu05 | Electronics | Audio | NAV | Infotainment | 5 | 12-03-2013 11:58 PM |
| Forum acting wierd for anyone else | MemphisR | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 05-16-2013 11:30 AM |
| is it weird? | slidethis | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 01-14-2013 01:07 AM |
