#897 | |
Mr. Cranky Pants
Drives: 2013 Argento FR-S
That's an impressive trap speed. Several MPH faster than I expected. |
#898 | |
So elite I'm 1338
Drives: WRB Subaru BRZ
that 60' is about average.... Quick side of average though. There is a guy that ran high 13s NA due to having a 1.6 60'.
-Jack Burton |
#899 | |
Drives: lexus
I am on the stock engine. My mods are gutted headers, perrin overpipe, isis front pipe, q300 catback, flexfuel, and tuned by HRI tuning |
| The Following User Says Thank You to 4032pauln For This Useful Post: | CSG Mike (09-03-2014) |
#900 |
Drives: Toyota
Ah..ya, I thought/meant 0-60mph times. Didn't know it was 60'. What do I know lol? I'm not a drag racer and I haven't been on one of those tracks in 20 years lol.
#901 |
60' is usually reaction time and how well you and your car pull out of the hole... no pun intended.
#902 |
Drives: Toyota
Ah..thx for your specs.
Catless fp too? So basically no cats at all? So you were running e85 or a mixture of it? What are you dynoing at? |
#903 |
Drives: 2013
60' is the time it takes for your car to travel 60 feet. Your reaction time isn't determined by this. When the light turns green, that doesn't mean your time has started ticking, it starts when you trip the beams.
In hind site, you can sit at a green bulb for 5 seconds and still run your same (or close) time as if you tried to leave right at the drop of the green. |
| The Following 3 Users Say Thank You to Carolina Dyno For This Useful Post: |
#904 |
Drives: Toyota
#905 | |
#906 | |
Drives: lexus
yeah I was running e85 but it did help me a tiny bit the drag strip. I was able to hit 13.4 at 105 trap on pump gas. On virtual dyno i am making 308hp. In reference, the carb tune made 212 hp on the virtual dyno. But you cant really take much from it since its not on a real dyno |
#907 | |
Drives: 2013 Black FR-S
Carb tune is hella conservative |
#908 | |
Drives: Toyota
I have a couple Qs: - was this on a totally stock car (stock headers/fp/exh)? - will your tune work on both a stock catted header setup and also a aftermarket uncatted header? (Unlike the JR CARB tune, which only works with oem header/fp because of VE sensitivity). - if yes, to the above question, how and why can your tune work with both aftermarket uncatted and also oem catted? Is it because your SD tune isn't affected by changing oem headers to aftermarket uncatted headers, because SD tunes don't get affected by VE changes made from changing exh setups? - if no, then is a separate tune needed (similar to the JR CARB tune) for each setup (one tune for oem catted header, and a different tune for aftermarket uncatted header)? - does your OTS e-tune work with this JRSC setup- using 91oct, aftermarket uncatted header, and stock everything else (stock op/fp/catback exh)? If I got the JRSC, I would want just an aftermarket uncatted header with a corresponding tune, and keep everything else stock (op/fp/catback), to keep things quiet and sleeper (and non ricey lol)....while still being able to make a little extra power from the uncatted headers and new tune. Also wanting to keep at least one cat (the fp cat), to keep the nasty smells down. My goal/desire would be: - JRSC, tune, JDL or Tomei uncatted header, stock oem op/fp/exh: for the majority of the time - JRSC, and swap to JR CARB tune, oem header: for smog day Thx. |
#909 |
Drives: 2013 High AT
@DeliciousTuning
From what I hear the guys at Delicious have never done an AT JRSC tune before. Can you shed some light on this? If not, would it require a lot of effort on your part? I know the CARB tune is pretty good out of the box but I don't plan on having any CATs in my setup so I would like to know how a custom (remote) tune would work out for me from Delicious? |
#910 | |
PhoneFlash by EcuTeK
1. Yes this was a totally stock car, same car, same day, no changes accept for the tune. 2. Yes, our tune will work with both a stock exhaust and aftermarket exhaust systems, including headers. 3. We are using purely VE tables / speed density to tune the vehicle along with a combination of EcuTeK custom tables we have developed for proper fueling in almost any scenario. These tunes are usually based on stock exhaust system which offer more back pressure and in turn restrict the amount of ignition advance, and cam advance you can run. But the tune will just be a little soft when you open up the exhaust, but still function and run properly. 4. Now if you do change parts, we always offer custom remote tuning tweaks on the tune to see if we can get a little more out of the tune. We would work on the cam angles, timing and potentially the fuel a bit to lean it out if needed. 5. Yes 6. I would think with a slight tweak to the tune we would get a little more power out of the vehicle wiht an aftermarket header on the vehicle, though hard to say until it is done. Hope that answers your questions, Cheers, William Knose Delicious Tuning |
| The Following User Says Thank You to DeliciousTuning For This Useful Post: | Yui-Chan (09-05-2014) |
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 05:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 10:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 04:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 05:14 PM |
