Old 09-02-2014, 04:13 PM   #253
CSG Mike
CSG Mike's Avatar
Originally Posted by 7thgear View Post
well, I do get the blinking traction light on an overly dusty and "tight" autocross.
180* hairpins will almost universally cause the light to go on
and after reading the previous few posts I've started to wonder if I too feel like the car "bogs", just a little, in those situations.
I really should try to disable it... lol , with the proximity of light posts and curbs the possibility of icemode is a little freaky to me, much scarier than just sliding off into the grass on a track.
Try it... I'd bet you won't ever look back. That's been the case with nearly everyone I know that's tried it.
Old 09-02-2014, 04:22 PM   #254
noob and expert
Drives: None :(
Ok starting to get confused is ebd the electronic system that splits the bias front and rear or the system that brakes individual wheels?
For me, there is no glide in pulse and glide :p
??? is offline   Reply With Quote
Old 09-02-2014, 05:54 PM   #255
ddeflyer
EBD == Electronic Brake force Distribution; ie. electronic and computer controlled bias. I believe I've read it can actually distribute to all four wheels independently and is part of the traction control and ABS systems on our car.
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next!
ddeflyer is offline   Reply With Quote
Old 09-02-2014, 05:56 PM   #256
ddeflyer
Trail braking is more important to me, since the only time the e-diff kicks in is over high speed (120+mph) corners where it actually destabilizes the car. The E-diff, to me, is unpredictable, because the computer is interpreting my input into what it thinks i want, instead of giving me what I actually want. This may vary, as I know the diff will be open in some cases, and am giving the car input to accommodate that.
Simple answer is yes, I'd rather lose EBD and not have the e-diff, since neither are things I want. It's the same reason I find the C7 vette unpredictable with the e-diff.
There are a couple of places at Thunderhill where I get the e-diff coming on, the lowest speed (and most noticeable) is a ~180 degree hairpin. None of those places are near 120Mph. The hairpin is more like 30Mph or something (it is a second gear turn).
Old 09-02-2014, 05:59 PM   #257
CSG Mike
CSG Mike's Avatar
I usually don't have problems with the e-diff at all on stock suspension; it only happens on the stuff with high spring rates (and minimal droop)
Old 09-03-2014, 09:00 AM   #258
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
so what causes the hopping on the inside? bone stock suspension at the moment. this was on a 50ish mph hard right with banking. on this road
I assumed it was cradle bushings being pushed to their limit and then the tire breaking free and basically getting axle wrap/wheel hop due to a sloppy stock bushing
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 09-03-2014, 09:34 AM   #259
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Originally Posted by Roadcone View Post
on this road
Those are great roads up there!
dradernh is offline   Reply With Quote
Old 09-03-2014, 01:51 PM   #260
CSG Mike
CSG Mike's Avatar
The exact cause can be a lot of things, but generally it involves breaking traction with a combination of insufficient contact and too much throttle input.
Old 09-03-2014, 03:16 PM   #261
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
I tried the Pedal Dance for the first time this weekend.
After 2 years of track days with this car, I would only disable the nannies via the 5-sec press.
Now I find the rear of the car much more stable on hard braking hairpins or transitions.
Will keep using it on the track as I see no downsides (other than the process).
Slick is offline   Reply With Quote
Old 09-03-2014, 03:40 PM   #262
CSG Mike
CSG Mike's Avatar
I'm glad you like it!
Old 09-03-2014, 05:58 PM   #263
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
This was asked in another thread:
Originally Posted by dradernh View Post
Will ice mode in this car stop if after inducing it the driver releases a slight amount of brake pressure, or maybe a bit more? If not, what do you do to get the braking back?
To which you responded:
I don't know, but I'll do some testing when I get the chance!
Keep bugging me.
Well, I didn't hold up my end of the bargain. I never bugged you about it. What are the odds that you remembered and had a chance to test this?
BatStig is offline   Reply With Quote
Old 09-03-2014, 06:31 PM   #264
CSG Mike
CSG Mike's Avatar
Gotta fully release the brake to get out of ice mode, but the pedal goes back to normal immediately when you fully release
Old 09-04-2014, 08:48 AM   #265
BatStig
Some say.....
BatStig's Avatar
You're a good man.
Old 09-04-2014, 09:24 AM   #266
dradernh
So, since you're already not getting any braking effect due to the ice mode, you can jump right off and ease right back on in one continuous movement, and if the condition causing ice mode in the first place is no longer present, you now have braking force. This is good to know. Thanks!
Where to buy "heel/toe" shaped gas pedal? dookie11 Scion FR-S / Toyota 86 GT86 General Forum 56 01-22-2019 11:24 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
Dyno testing and "drivetrain loss" serialk11r Other Vehicles & General Automotive Discussions 5 11-03-2011 08:55 AM
