Old 09-01-2014, 09:48 PM   #1023
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Originally Posted by @Art_Mighty View Post
Is the Oil Cooler thermostatically controlled?
^^^^ this... Really hope so..
Old 09-01-2014, 10:46 PM   #1024
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Plates are generic so you could always make it thermostatic if it doesn't ship that way
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 09-02-2014, 02:24 PM   #1025
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Looks like the Mocal thermostatic plate to me.
Old 09-02-2014, 03:00 PM   #1026
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by AVOturboworld View Post
A sneak peek of the oil cooler kit:
You saw it here first!
Hard to tell from pics but where does this get its air from? Where does the air exit out after being heated by the fins?
Old 09-02-2014, 03:16 PM   #1027
AVOturboworld
The duct goes to the front grill to directly get air.
Old 09-02-2014, 03:54 PM   #1028
AVOturboworld
Here is a photo of it mounted on the AVO car:
The Following User Says Thank You to AVOturboworld For This Useful Post:
SkAsphalt (09-03-2014)
Old 09-02-2014, 04:19 PM   #1029
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
Here is a photo of it mounted on the AVO turbo BRZ:
That looks really nice!
Sent from my iPad using Tapatalk HD
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
Old 09-03-2014, 03:57 AM   #1030
j-spec
Drives: 2013 White BRZ
Quick question. What's the difference in the automatic kits and manual kits??? Can I buy a automatic kit and use it on my manual???
Thanks
j-spec is offline   Reply With Quote
Old 09-03-2014, 04:15 AM   #1031
protpibe
protpibe's Avatar
Thanks
As far as I know, the difference is the oil scavenging pump. The auto doesn't have an empty plate at the back of the passenger side cam where the oil pump mounts.
The Following User Says Thank You to protpibe For This Useful Post:
Draco_PR23 (09-05-2014)
Old 09-05-2014, 08:40 PM   #1032
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
I just realized these might be the directions for the manual transmission. I looked at evasivemotorsports.com for the automatic transmission directions but couldn't find them. Anybody know where to look?
Old 09-05-2014, 09:50 PM   #1033
AVOturboworld
The AVO oil cooler kit for the Subaru BRZ, Scion FR-S, and Toyota GT86 is a highly engineered solution to your cooling needs. Designed for maximum efficiency and reliability, it's been tested thoroughly at the track in the toughest of conditions. Careful thought and engineering went into not just the oil cooler itself, but the placement of it to maximize the cooling efficiency. An air duct is included that routes the air from the front grill opening to ensure air flow at speed. The duct is designed to work with the AVO turbocharger kit piping as well!
We use a thermostatic plate designed to activate at 85~90 degrees Celcius (185° F ~ 190° F), this is to ensure proper oil temperatures during winter conditions. Once installed at the track, we saw constant oil temperatures exactly matching the water temperature even with extensive lapping.
Oil cooler details:
1. Thermostatically controlled to activate at 85~90 degrees Celcius (185° F ~ 190° F).
2. AN -10 Braided Steel Lines with a swivel incorporated into the fittings for ease of install.
3. Oil cooler size. H 125mm x L 290mm x W 50mm
4. 16 Row Cooling Unit
5. Steel mounting brackets with rubber vibration isolator.
6. Will fit with AVO turbo kits and N/A cars.
7. Air duct will fit with the standard bumpers on the BRZ, FR-S, and GT86.
8. Comes with all necessary hardware.
9. Will fit with OEM foglights.
The Following 3 Users Say Thank You to AVOturboworld For This Useful Post:
@Art_Mighty (09-05-2014), CxG (06-25-2016), mwjcyber (09-06-2014)
Old 09-06-2014, 12:45 AM   #1034
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
Did you asked Paul? I might have it, just need to look for it
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
The Following User Says Thank You to Draco_PR23 For This Useful Post:
@Art_Mighty (09-06-2014)
Old 09-06-2014, 12:54 AM   #1035
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@protpibe hooked me up with the link the first time. I can PM paul but I know he monitors this thread
The Following User Says Thank You to @Art_Mighty For This Useful Post:
Draco_PR23 (09-06-2014)
Old 09-08-2014, 03:05 PM   #1036
AVOturboworld
Send me a pm with an email address, and I can send a pdf of the install instructions.
avo, avoturboworld
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 01:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 05:26 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
