Old 08-22-2014, 06:37 PM   #2171
kodyo
Drives: Scion FR-S
Originally Posted by Trettiosjuan View Post
Build quality is for Audi. For me quality is consistency in product performance which includes air flow and harmonics. As geometry and bends are identical, air flow can only be affected by pipe joint execution.
I don't believe the dyno graph has changed more than the variance that would have existed within the original batch. In the engineering world, everything varies, the question is if the variation is relevant.
I don't think so, other mods after the headers should affect the graph much more than a few weld seams ever can...
I'm honestly surprised that the people on here are so caught up on replacing a weld with a bend. I'm with you on betting my lunch money that the variations due to the tolerances per the drawing are likely to have more of an affect than a weld. People state harmonics and flow like they have even the faintest idea what that entails.
kodyo is offline
Old 08-22-2014, 08:46 PM   #2172
hattrickey
Drives: Scion FR-S
Originally Posted by tahdizzle View Post
.... really? Have I not been saying I need to take it to the dyno, and that there has not been a Dyno of the new header design provided by ft86sf?
Once I have time to get it on a dyno, I'll be sure to provide you all with the graphs.
Dude, I don't know what you're smoking but if you look back just a couple pages, you will see my dyno graph of the NEW header design. I'll make it easy for you and post it right here.
The bottom torque line is my baseline run without a tune. You can CLEARLY see that it eliminates almost all of the torque dip. There was a very small drop from 4300 - 5000 rpm but I couldn't feel it when I was driving.
Stop whining and enjoy the high quality product @FT-86 SpeedFactory has provided.
hattrickey is offline
Old 08-22-2014, 10:49 PM   #2173
Luis_GT
Here's a dyno of my setup
A couple of factors came into play here, compared to my last dyno. There was a depression today, so weather could have been a big factor, and I now have the latest ECU update from the dealer, so tunning could be slightly different from last time.
Here's the old sheet
Both on 91 octane... Dip was slightly improved, not a lot, but it's something... Peak, only gained 1WHP, but my AFR very rich now compared to my last dyno.
Luis_GT is offline
Old 08-22-2014, 11:14 PM   #2174
SCharged
Drives: asphalt fr-s
What does the butt dyno say?? Cause thats all that really counts..
Sent from my SGH-I747M using Tapatalk
SCharged is offline
Old 08-22-2014, 11:21 PM   #2175
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Poop
Andrew025 is offline
Old 08-22-2014, 11:39 PM   #2176
Luis_GT
Power feels linear now, doen't really feel faster
Luis_GT is offline
Old 08-22-2014, 11:41 PM   #2177
Luis_GT
I dynoed a basically stock FR-S after mine, only had Greddy sp elite axle back and drop in filter on 93 octane and did 167 on the dyno... I was butthurt.
Luis_GT is offline
Old 08-23-2014, 12:39 AM   #2178
Trettiosjuan
Drives: GT86
I see a large difference in the dip, it's basically gone! But the new graph is low. Indeed weather will influence and when I got the latest OE engine software my car felt sluggish and down on power for almost two weeks. Should improve with time and better conditions...
Trettiosjuan is offline
Old 08-23-2014, 12:50 AM   #2179
Luis_GT
I updated mine 2 weeks ago... thinking of reseting it by disconnecting the battery, see if it does anything... I never did reset the ECU after flashing it.
Luis_GT is offline
Old 08-23-2014, 12:54 AM   #2180
Kronos
Kronos's Avatar
Drives: Asphalt FR-S MT
Is resetting the ecu between flashing usually recommended ?
I think I've flashes about 5 times so far
Kronos is offline
Old 08-23-2014, 02:30 AM   #2181
Luis_GT
tunes, I don't think so, but stock ecu has to learn the car first.
Luis_GT is offline
Old 08-23-2014, 04:48 AM   #2182
Trettiosjuan
Drives: GT86
After a reflash or a remap, before starting the car but with ignition on, one can fully press and release the accelerator pedal 10-20 times. Then start without touching the pedal and let idle a few minutes. This should calibrate the (electronic) accelerator and make learning quicker.
Looked up your build Luis_GT, looks like you have many engine mods already (full exhaust and intake and blocks) to which the OE ecu couldn't possibly adapt to properly and take advantage of, sounds to me it's time for a tune...
Old 09-02-2014, 10:49 AM   #2183
Luis_GT
Well... this thread died...
Luis_GT is offline
Old 09-02-2014, 02:44 PM   #2184
SCharged
So did header production... pumping out 2 a week lately
SCharged is offline
catted uel header, ft86speedfactory header, is my order ready yet?
Invidia Catless and Catted Front Pipe - ** FT-86 SpeedFactory ** FT-86 SpeedFactory Engine, Exhaust, Transmission 107 03-29-2016 10:48 AM
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 12:32 PM
P&l EL catted and coated header. wootwoot Engine, Exhaust, Bolt-Ons 8 10-11-2013 12:50 AM
Catted UEL Header Cjymiller Engine, Exhaust, Transmission 20 05-24-2013 12:01 PM
***Invidia Catted and Catless Front Pipes*** - FT-86 SpeedFactory RELEASE SALE FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 12 10-24-2012 10:12 PM
