Old 09-01-2014, 03:16 PM   #1
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
AVO turbo kit plus upgrades
Just finishing up my new build, so this setup is for sale. Hoping for a local sale/pick up first. Location is md, 21060
Avo kit, ceramic coated (zero shaft play on turbo)
Avo upgraded 8psi wastegate
Avo 50/50 blow off valve upgrade
K&N drop in air filter
DW 700cc injectors (adapter harnesses not included)
Omni 3 bar map sensor
Avo boost solenoid (plug and play for evap plug)
(Oil pump and return line not pictured, need to pull it off my stock motor still this week)
Also have a spec 2+ clutch that can be bundled in. Properly broken in, never slipped
$3500 for the kit, $3600 with the clutch
$200 for the clutch by itself
300whp @10.5 psi on 93 octane
400whp @18 psi on e85
The Following User Says Thank You to spitfire481 For This Useful Post:
SkAsphalt (09-02-2014)
Old 09-01-2014, 09:00 PM   #2
coolaron
What's the mileage with the kit & clutch?
coolaron is offline   Reply With Quote
Old 09-01-2014, 10:46 PM   #3
Red FRS
Red FRS's Avatar
Drives: 2014 Subaru BRZ
Would you sell map sensor?
Molded rb v1 BRZ on WCI LP1
instagram.com/seantejani
Red FRS is offline   Reply With Quote
Old 09-01-2014, 11:41 PM   #4
spitfire481
Drives: 2JZ FRS
Right around 10k. Never been tracked, only street
Old 09-02-2014, 07:28 AM   #5
peebking
Drives: BRZ limited
where u locate?
peebking is offline   Reply With Quote
Old 09-02-2014, 11:39 AM   #6
spitfire481
Drives: 2JZ FRS
Originally Posted by peebking View Post
where u locate?
Maryland, 21060
Old 09-02-2014, 01:10 PM   #7
j-spec
Drives: 2013 White BRZ
are you willing to ship?
j-spec is offline   Reply With Quote
Old 09-02-2014, 01:13 PM   #8
spitfire481
Drives: 2JZ FRS
Not currently. Going to give it a week or two for a local sale first. Then I'll try to work on shipping.
Old 09-04-2014, 06:15 PM   #9
spitfire481
Drives: 2JZ FRS
Up
Old 09-08-2014, 04:53 PM   #10
spitfire481
Drives: 2JZ FRS
Up
Old 09-12-2014, 12:34 PM   #11
spitfire481
Drives: 2JZ FRS
everything is off the car and ready to go! accepting offers for local pickup
Old 09-17-2014, 10:22 AM   #12
sashrafi
Drives: 14' Brz
PM'd.
sashrafi is offline   Reply With Quote
Old 09-30-2014, 05:49 PM   #13
spitfire481
Drives: 2JZ FRS
up
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 10-05-2014, 03:00 PM   #14
spitfire481
Drives: 2JZ FRS
Still here
MoTeC
Build Thread
@spitfire481
BRZ choice upgrades meekhotglass Exterior Parts (Aero, Lighting, Etc.) 5 01-26-2016 11:08 PM
upgrades to my frs marine12 Engine, Exhaust, Transmission 9 04-10-2014 08:06 AM
Need Transmission Upgrades for Turbo? Admired Forced Induction 26 11-10-2013 03:48 PM
All Possible Car Upgrades? pwnisher Scion FR-S / Toyota 86 GT86 General Forum 31 07-23-2013 01:27 PM
GPS Map Upgrades? Enemies Electronics | Audio | NAV | Infotainment 0 04-20-2013 05:18 PM
