Old 04-26-2012, 12:13 PM   #1
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Some Interesting things from a Dealer event Yesterday
Just got back from a BRZ Dealer event in Oshgosh Wi. Just a few noteworthy things:
-There is a dead spot from 3750 to 4250 RPM... it is the AVCS Crossover supposedly it CAN be tuned out...ALA Dual AVCS 08 STI...we'll see..Hopefully there will be a tuning company that can 'fix' this
-The Rep said he got 33 mpg on normal highway driving
- There will be moderate Road noise
-Supposedly it does 59.2 mph in 2nd..thats good for me..with a bit taller tire..it will be perfect for a 62 mph jount
-Some other news...Toyota is saying a JUNE 1st introduction date.... As of yesterday...there is a boat 1/2 BRZs the other Half FRS's.. on its way to Long Beach ...left port on Tues...usually takes about 17 days to travel from Japan to Calif...soo Do the math.
-Seats were Relatively Firm...theres about 2.5 inchs left on the bottom, even when the seat is in its lowest position.. soo hopefully there is a lower bracket to be made somewhere..
-Seating Position is a little awkward at first...If your used to a certain seating position in your old car...most likely...its not going to be the Exact same in the BRZ...Close...and it will take some time to adjust.
-Battery is a std GRP 35....IT WILL be replaced with a lightweight Odyssey/Braille...
Me trying to get into a comfortable/effective Driving postion
about 5.5 inches of Ground Clearance...
Have about 1/2 inch of Helmet clearance in this pic...recline 1-2 clicks Fixed that..
Ok...I absolutely HATE the headrest....Gets in the way..and pushes my head down to my chest...NOT DESIGNED for a HELMET...no biggie...flip the headrest around....LOTS OF Room..
Whoever said there wasn't HID controls...Probably sat in a FR-S...which doesn't have HIDs...
PROOF
LOVED the FATTY Steering Wheel.... the Driving View is pretty good to..
Definitely some cool things going on.....Enjoy the new Info
Bill
Scooby South is offline   Reply With Quote
Old 04-26-2012, 12:59 PM   #2
MmmHamSandwich
You know you want it.
MmmHamSandwich's Avatar
Drives: '13 FR-S
Very interesting...
What do you mean by HID controls? Leveling?
Thanks for your impressions!
MmmHamSandwich is offline   Reply With Quote
Old 04-26-2012, 01:01 PM   #3
Scooby South
Conedancer
yes Leveling.. someone out there said it didn't have it....with a Switch that goes from 0-5...for the height adjustors...
Old 04-26-2012, 01:03 PM   #4
MmmHamSandwich
Drives: '13 FR-S
Height adjustable Lights....the Motors themselves...with a Switch that goes from 0-5...for the height adjustors...
Awesome, coming from retrofitted projectors that sounds appealing. I'm glad it comes with leveling. I guess that is the advantage of having this car produced in many other regions.
Old 04-26-2012, 01:04 PM   #5
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
Very interesting...
Yes.
EDIT: Beaten
Grimlock is offline   Reply With Quote
Old 04-26-2012, 01:21 PM   #6
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
-LOVED the FATTY Steering Wheel.... the Driving View is pretty good to..
Thanks for your feedback. I have to say though, your perception seems a bit strange. Are you not accustomed to a proper laid-back sports car seating position? [i.e. Porsche, Miata, Elise] Pretty much all modern hatchbacks and sedans have asinine ergonomics where you have to sit very upright and till the wheel like a bus driver. I'm guessing based on your helmets' Subaru stickers that you have a WRX et al, so yes, proper sports car ergonomics may feel strange at first, but the point is you sit in the car, not on the car. IMO, the steering wheel felt average [as in proper] in girth; thankfully it's not inflicted with elephantiasis like BMW //M wheels. I'm not sure why Toyota is going on and on about the steering wheel diameter, if it were any bigger it wouldn't fit in the car.
Just my advice: you might want to wait until a proper LiFePo4 battery is fitted and marketed for the car before spending money on a short-term solution like an AGM battery.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 04-26-2012, 01:26 PM   #7
ahausheer
Re-member
Drives: Toyota camry
AVCS Crossover:
Interesting, the torque curve does look similar to the 08 STi. All this time I thought the torque dip was due to Toyota's ACIS system, which I'm not sure is on this car. Should be easier to tune out the AVCS crossover because you cannot tune out the torque dip resulting from Toyota's ACIS cross over. So the dip is basically a cam phasing issue?
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 04-26-2012, 01:27 PM   #8
Scooby South
Conedancer
^^^ thanks...I sit VERY close to the steering wheel in a very UPRIGHT postition...I am 6'2 but my seating position sits like I am 5 ft...I am very used to having ALOT of steering control sitting so close...the Telescoping Wheel Helps that situation ALOT....And yes...All my experience is in Impreza's...have driven some others as a instructor...for 1-2 runs before...so I gues I am not as familiar with the 'sports car' driving postion as I should be.......actually just bought a DEK battery for competition..
Bill
Old 04-26-2012, 01:27 PM   #9
ubersoph
Proper seating position for racing IS upright. Better handle on the controls. Or do you see people in actual racing series sitting with a gangster lean?
ubersoph is offline   Reply With Quote
Old 04-26-2012, 01:28 PM   #10
Scooby South
Conedancer
Originally Posted by ahausheer View Post
AVCS Crossover:
yep pretty much...HKS already has new Cams for it...
Bill
Old 04-26-2012, 01:40 PM   #11
Ryephile
Hot Dog
Ryephile's Avatar
You're definitely projecting and making sweeping generalizations. I didn't say gangster lean, nor did I say anything about racing, let alone the seating position for Formula, DSR, or ALMS cars.
If you ghetto lean in a hatchback, then you're likely too far from the steering wheel for proper control. You can't ghetto lean in my Exige, because the seat posture is fixed, in a slightly reclined position. Nevertheless, the Exige's steering wheel positioning is excellent. Conversely, the posture in a Ferrari 308 is terrible; reclined seat with very distant [and canted] steering wheel.
Reclined does not equate to excessive distance from the steering wheel, especially in a car where a reclined body position is part of the design. Making generalizations doesn't help. We're talking about the BRZ, which has a low, semi-reclined seating position with a high-positioned and relatively vertically upright steering wheel. Such positioning automatically gives better control and leverage over the steering wheel, since the wheel is closer to being level with your shoulders, instead of being down by your stomach like a hatchback. Since the OP isn't accustomed to such ergonomics, he'll have to adapt.
Old 04-26-2012, 01:41 PM   #12
Metallic BRZ
Metallic BRZ's Avatar
Drives: 1992 Corvette Z07
Is the car still there? Which dealer is it? I'm in Madison and would drive up if the car were still there. I'll call the dealer to find out if you have the info.
1992 Z07 Corvette
2008 Odyssey
2013 BRZ
Metallic BRZ is offline   Reply With Quote
Old 04-26-2012, 01:50 PM   #13
Scooby South
Conedancer
The same car will be in Madison on the 3rd of May from what I am told...Talk to Shannon @ Don Miller Subaru East...he will have all the info..
Bill
Old 04-26-2012, 01:52 PM   #14
Metallic BRZ
Bill
Awesome - I appreciate the info. I'll definately be there. Good timing for me too.
1992 Z07 Corvette
2008 Odyssey
2013 BRZ
Dealer wants to do a launch event around delivering car to me HotLavaMann Scion FR-S / Toyota 86 GT86 General Forum 24 05-09-2012 02:16 AM
Sat in FR-S yesterday Arthur Scion FR-S / Toyota 86 GT86 General Forum 35 04-11-2012 12:50 AM
Interesting take on 2012 GT-R bofa Other Vehicles & General Automotive Discussions 84 08-29-2011 06:38 AM
Why ft-86 is interesting? NewCarInQ42011 Scion FR-S / Toyota 86 GT86 General Forum 69 11-26-2010 04:05 PM
