Old 04-26-2012, 11:48 AM   #1
SpeedR
First86 / boat thief
Drives: MKIV Supra
FR-S Gear Ratio Comparison
____AT ___MT __# differenc _% difference
1 _3.626 __3.538 __0.088 ____2%
2 _2.188 __2.06 ___0.128 ____6%
3 _1.541 __1.404 __0.137 ____10%
4 _1.213 __1 ______0.213 ____21%
5 _1 ______0.713 __0.287 ____40%
6 _0.767 __0.582 __0.185 ____32%
R _3.437 __3.168 __0.269 ____8%
Did they make the AT ratios higher so it would not be significantly faster than the MT cars?
SpeedR is offline   Reply With Quote
Old 04-26-2012, 12:13 PM   #2
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
pretty sure the final drive on the auto is much longer than the MT.
Ranatsu is offline   Reply With Quote
Old 04-26-2012, 12:27 PM   #3
cossey
Drives: Reanult Megane R26
Final drives are the same.
I think it has been mentioned here that all Toyota AT have 4th as 1:1 and all manuals have 5th as 1:1 so the auto will be much longer geared unless they shorten the final drive.
as the manual runs a 4.1:1 final drive then it would be difficult for the auto to be much shorter.
the long gearing of the auto is one of the main reasons (along with the less than sonorous engine) that the BRZ got such a savaging by EVO.
cossey is offline   Reply With Quote
Old 04-26-2012, 12:36 PM   #4
SVTSHC
(ノಥ益ಥ)ノ
SVTSHC's Avatar
Drives: 2015 Series Blue BRZ
After seeing those ratio's I understood why the AT got better fuel mileage than the MT. It's weird seeing a six speed with only one overdriven gear though. Usually the 1 to 1 hits in fourth, and fifth/sixth are overdriven.
"Sweet Subaru, sweet Subaru, send your BRZ unto me, for the roads of the unworthy must be baptized in speed and glory." ~Zaku
SVTSHC is offline   Reply With Quote
Old 04-26-2012, 12:53 PM   #5
the_3d_man
Drives: 2007 Legacy GT
I think you got it backwards... but yeah... it's a bit dissapointing that the gears are so much taller on the autos.
the_3d_man is offline   Reply With Quote
Old 04-26-2012, 01:05 PM   #6
Saibot
Saibot's Avatar
Drives: 01 Toyota Corolla / Porsche 911 C2
you got your mt and at mixed up.
they made closer gear ratios on mt on purpose for faster acceleraton iirc..
most mts have closer gears than their ats though.
Saibot is offline   Reply With Quote
Old 04-26-2012, 01:11 PM   #7
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
yeah the auto would be much faster than the manual is they had the same ratios, you just cant beat the autos lightning fast shift times
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 04-26-2012, 01:31 PM   #8
Saibot
Saibot's Avatar
Here's a question: I want to do a 6th gear swap. Would other cars with AZ6 trannys qualify as donors (ie S2K or miata)?? Or is there some minor difference tht would prevent it from happening?
Old 04-26-2012, 01:42 PM   #9
carbonBLUE
Reverse Burnouts
yes, in theory the AZ6 transmissions can exchange parts
the parts are different but the parts should align just the same...
i personally want shorter gear ratios in the auto, but at the same time i dont, i will be going supercharged and the longer ratios would be fine, i dont want to be shifting too much
(wont forget you)
2011 Infiniti G37x
Old 04-26-2012, 03:49 PM   #10
serialk11r
Drives: '06 AM V8V Coupe
The problem is no other AZ6s have 6th gears that are any shorter...the S2000 has 0.762 instead of 0.767, that's hardly worth the swap. Dropping the 6th gear about 15% would be a nice compromise between power for hills and higher speeds and fuel economy I think.
If you're hardcore about saving gas, you can pulse and glide it, but it's obviously 10 times easier to just have a longer gear.
Maybe in a future model...
Old 04-26-2012, 03:53 PM   #11
AJ PwR
AJ PwR's Avatar
Drives: R35 R56 CZ4A ZC6
Send a message via ICQ to AJ PwR Send a message via AIM to AJ PwR Send a message via MSN to AJ PwR
IMO, cars with AT are normally heavier and have more drivetrain loss than MT so with higher ratios, it will compensate the difference but I don`t think the AT can be any quicker than the MT.
AJ PwR is offline   Reply With Quote
Old 04-30-2012, 08:04 PM   #12
matt30
Drives: 2004 Subaru WRX
The OP reversed the labels.
matt30 is offline   Reply With Quote
Old 05-01-2012, 12:47 PM   #13
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
Quite a few 6-speeds have 5th 1:1, though often times they will have a much taller final drive to make use of it, like the V160 in the Supra, which had a 1:1 5th, but used a 3.13:1 or 3.27:1 final drive.
With the 4.1 final drive and the ratios the way they are in the TL70 (6MT), it will be a very close ratio overall setup.
That's what you really need to be comparing when you're looking at other models, overall ratio. Just looking at the transmission doesn't tell you much, you need to include final drive. Obviously on the Zx6 they're all 4.1 in North America, so there's no need there, I'm just saying.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 05-01-2012, 02:54 PM   #14
3MI Racing
Pro Subie Engine Nerd
3MI Racing's Avatar
Drives: empty spot for an FR-S/BRZ
See post 31 for an updated graph!!
3MI Racing is offline   Reply With Quote
The Following 2 Users Say Thank You to 3MI Racing For This Useful Post:
RaceR (10-09-2012), SpeedR (05-02-2012)
Official BRZ MPG Numbers. Big Gear Ratio Differences? aLiskov Engine, Exhaust, Transmission 56 01-16-2021 04:41 PM
FR-S to BRZ Ratio MannyO New England 11 03-08-2012 02:23 AM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 01:21 PM
86,BRZ MT gear ratio Yobiwan Engine, Exhaust, Transmission 1 01-26-2012 02:40 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
