#99 |
Drives: '14 FRS White
megan
#100 |
Drives: Scion FR-S 2013 Raven
Whiteline differential insert bushings review
Does we really got an real advantage running diff brace/bushing/mount finally?
I mean I have see the difference with the subframe bushing, yes ok fine, same thing with the transmission insert... But with the diff brace I just don't remember how the car was before... Maybe this is why am thinking it's useless after long term running this setup? I have read my first post again and maybe I have a different opinion after long term use :S
o= FR-S =o |
#101 | |
The top transmission mount on the other hand is garbage! |
#102 | |
Yes you are probably right... Do you track your car often?
o= FR-S =o Last edited by Mikepage; 08-15-2014 at 10:18 AM. |
#103 |
Drives: GTS 86
#104 | |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
#105 |
Drives: none yet
your rear end will tighten up like your gf/wife has a rejuvinated vajayjay! ha jk. no seriously. its that good. the "thunk" you hear will eventually phase out. Dont let it bother you. It is always been there, its just that the soft bushings hides the noise transfer into the frame. And you will get an instand "Go" from your wheels when you tap that gas pedal. And since you track a lil, you will get the most benefit. best mod so far. car is really alive. enjoy my friend. |
#106 |
You all make me feel like Mmm I will probably keep it installed finally
o= FR-S =o |
#107 |
Drives: Subaru BRZ
I have pretty much the whole setup different brands (listed below), I have a loud whine, loud clunk and major vibrations on de acceleration.
If I am in a high gear and let it de accelerate through the gear it is like going through a bass frequency test, rattles everywhere. Parts I have: Beatrush Rear Frame Stopper Beatrush Rear Dif. Mount Stopper Cusco Rear Differential Brace Whiteline trans insert Perrin Rear Shifter Bushing STI engine mounts Now the beatrush parts are pretty hardcore metal inserts and that maybe the reason for my heavy NVH, but whatever brand you have or material used I believe that the combination of the subframe inserts attaching the subframe to chassis and the diff inserts and brace firmly attaching the diff to the subframe almost making each separate component as one with the chassis there is no way to get around NVH, Unless changing one of the mods back to OEM to allow some dampening. I have finally come to a point where I need to get rid of the beatrush parts and am looking towards whiteline. Question is anyone with a similar setup as mine, but with the polyurethane subframe and diff bushings get mad vibrations de accelerating though 3rd-5th gear? |
#108 |
I will say Whiteline is just perfect.
o= FR-S =o |
#109 | |
Beatrush Rear Dif. Mount Stopper Cusco Rear Differential Brace Replace these with polyurethane mounts and you should be good. What's good for a track car is usually not so nice for a street setup. Good thing you went with the group N engine mounts. With my setup I have no whine or vibration. It took me a while to find a happy medium. As of right now im running TWM Short shifter TWM rear stay Twm Carrier bushings Mtech springs White Line transmission stay bushing Whiteline rear subframe bushings front and back Whiteline differential bushings rear only |
#110 | |
You have just keep the rear diff insert finally?
o= FR-S =o |
#111 |
Drives: 2013 Ultramarine FR-S
So what would be the difference between Diff Cradle Mount and the Outrigger Insert(which seems to be covered in this review)
#112 |
Diff cradle mount will replace the bushing completely. Outrigger insert like the title say, will be an insert to full the empty space into the OEM bushings.
Then if your OEM bushings are in good condition, probably, because the car is pretty new, then just go with the inserts...
o= FR-S =o Last edited by Mikepage; 09-02-2014 at 01:52 PM. |
| DIY - Whiteline Rear Crossmember Mount Insert Bushings | F1point4 | DIY (Do-It-Yourself) Guides | 91 | 01-17-2021 02:23 AM |
| Whiteline crossmember bushing insert review | Mikepage | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 27 | 11-09-2016 03:30 PM |
| Rear Shifter/Transmission Mount Insert Bushings | TheseColorsDontRun | Mid-Atlantic | 7 | 08-30-2013 10:29 AM |
| Whiteline diff bushings and trans mount insert. | Simmons | Transmission and Driveline | 7 | 06-09-2013 08:45 PM |
| WhiteLine Positive Shift and Rear Subframe Bushings Review @ Pure Automotive | Pure Automotive | Mid-Atlantic | 5 | 01-16-2013 05:15 PM |
