Old 07-14-2014, 03:49 PM   #155
FyeaFRS
Drives: 1992 Nissan Skyline GTS-t Type-M
So it seems the final word on these is that you can get a square setup, 18x7.5 +35, but will still have to have a staggered tire size. Sounds like if they were +45 there wouldn't be a problem.
So 18x7.5 +35 wheels with 215/40R18 in front and 225/40R18 in back tires with no rubbing.
Now, I plan on running the trd springs which is a ~1"drop. Will they work with the above setup, or will I have to stagger the wheel size 7/7.5 for the drop fitment?
Also looks like $970 shipped from that one site, anyone seen them cheaper? Think my dealer would match that price $242.50/wheel?
FyeaFRS is offline   Reply With Quote
Old 08-11-2014, 01:52 AM   #156
LALFAN
Drives: FR-S RS 1.0
I'm curious about these questions too if anyone has any additional input.
If we go staggered setup, as apparently recommended by Toyota/TRD, can we rotate the tires side-to-side at least? Or that will depend on the tires?
LALFAN is offline   Reply With Quote
Old 08-11-2014, 08:35 AM   #157
FyeaFRS
I'm just going with what the setup comes as. Got the springs on and it's low enough that I don't really care about having 7.5 all around, would rather just not with the hassle.
Old 08-27-2014, 12:48 AM   #158
LALFAN
Drives: FR-S RS 1.0
Anyone have any input on going going 18x7 (215/40 R18) all around? This would seem to make most sense from a tire rotation standpoint.
Old 08-29-2014, 04:02 AM   #159
JM9ISM
Drives: 2014 BRZ WRB LTD
Just a quick heads up for you guys that looking for 7.5 all around with 225/40/R18
IT ACTUALLY WORKS!
which means no rubbing at all. I'm running 225/40/R18 with 7.5 TRD wheels and H&R lowering spring, so now I can rotate them!
JM9ISM is offline   Reply With Quote
The Following 8 Users Say Thank You to JM9ISM For This Useful Post:
botbs (09-13-2014), ericmpena (08-30-2014), FyeaFRS (08-29-2014), Mikko (08-29-2014), nosi9frs (08-29-2014), Quentin (08-29-2014), raven1231 (08-29-2014), tennisfreak (08-29-2014)
Old 08-29-2014, 09:56 AM   #160
Mikko
Drives: 2015 WRB BRZ
IT ACTUALLY WORKS!
Wow, those wheels look much better than I expected. Really nice!
Mikko is offline   Reply With Quote
The Following User Says Thank You to Mikko For This Useful Post:
JM9ISM (08-29-2014)
Old 08-29-2014, 10:41 AM   #161
FyeaFRS
IT ACTUALLY WORKS!
What's the drop on those springs?
Old 08-29-2014, 12:27 PM   #162
JM9ISM
H&R Sport Springs
Front 1.0inch rear 1.2inch
Old 08-29-2014, 12:41 PM   #163
trinxified
Drives: Subaru BRZ Aozora Edition
H&R Sport Springs
Are you also pretty flush to the fender? No spacers right?
trinxified is offline   Reply With Quote
Old 08-29-2014, 11:39 PM   #164
Scuba86
Drives: 2014 FR-S Monogram Raven
IT ACTUALLY WORKS!
So if I were to run all 7.5 and 225/40/18 with no lowering springs it would still be good?
Scuba86 is offline   Reply With Quote
Old 08-30-2014, 01:05 AM   #165
LALFAN
Drives: FR-S RS 1.0
It would appear that we're getting conflicting reports of rubbing with 7.5" square, both with first hand experience and photo proof. (see quote below and photos)
1. Would there be any reason why this would work on the the Suburu but not the Scion?
2. Does the offset look weird, like they stick out further in the front vs. the back or is that just the angle of the photo?
3. What tires? I'm trying to do research and find decent all season tires for the TRD whee, but I'm not having much luck yet.
Thanks!
Originally Posted by Speeeddemon99 View Post
Yes I notice the rubbing on very sharp turns. Lock to lock. Was bad with regular turning. But to avoid a future headache I put 215/40/18 on fronts. No rubbing whatsoever.
Originally Posted by nosi9frs View Post
Did you notice rubbing issues with 225/40R18's up front? You should be fine running those
Old 08-30-2014, 03:59 PM   #166
Speeeddemon99
Drives: 2014 Raven FR-S monogram
Thanks!
Don't know anything bout it working on the Subaru
You don't notice offset. Well at least I don't
My all season tires are on my stock rims. I have Mich pilot super sport on my TRD rims
Speeeddemon99 is offline   Reply With Quote
The Following User Says Thank You to Speeeddemon99 For This Useful Post:
LALFAN (08-30-2014)
Old 08-30-2014, 05:44 PM   #167
LALFAN
Drives: FR-S RS 1.0
Thanks for the information.
Correct me if I'm wrong, but you're on 18x7.5 square, but you had to go from 225/40R18 in the front to 215/40R18 in the front because you noticed rubbing?
Toyota recommended...
Front
Wheel: 18"x7.0"
Tire: 215/40R18
Rear
Wheel: 18"x7.5"
Tire: 225/40R18
Speeeddemon99 has...
Front
Wheel: 18"x7.5"
Tire: 215/40R18
Rear
Wheel: 18"x7.5"
Tire: 225/40R18
JM9ISM has...
Front
Wheel: 18"x7.5"
Tire: 225/40R18
Rear
Wheel: 18"x7.5"
Tire: 225/40R18
Does this look right everyone?
I wonder why it rubs for one car but not another car? Anyone have any additional information or insight to help us all out?
The Following User Says Thank You to LALFAN For This Useful Post:
FyeaFRS (10-10-2014)
Old 08-30-2014, 06:15 PM   #168
dchan8
Drives: Toyota Celica
possibly the brand of tire installed. each manufacturer varies a bit even though the tire size is the same "size"
dchan8 is offline   Reply With Quote
Forgestar F14 wheels and Enkei wheels: <<RPF1 18x9.5/NT03+M 18x9.5 In Stock>> b2autodesigns Wheels and Tires 850 09-10-2017 08:29 AM
Team Dynamics Pro Race 1.3 Wheels (Track wheels) CHEAP!!!! Evasive Motorsports Wheels and Tires 4 07-29-2013 08:46 PM
Discount Tire installed my wheels and tires...and damaged my wheels...advice needed! stratodyne Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-17-2013 02:21 PM
Wheels, Wheels, Wheels | Island Import Performance IslandImportPerformance Wheels and Tires 4 07-31-2012 10:08 PM
