JonMotoring
Old 08-27-2014, 04:25 PM   #27231
captain_jack
captain_jack's Avatar
Not to tag Alan's post but don't forget I also have a kraftwerks supercharger kit, engine oil cooler and flex fuel kit for sale.
Old 08-27-2014, 06:41 PM   #27232
EZWood
BAMF
EZWood's Avatar
Motor started knocking today. I'm waiting on a tow truck.
Old 08-27-2014, 06:43 PM   #27233
captain_jack
Well that's not good, did it throw any codes and if so what were they?
Old 08-27-2014, 07:21 PM   #27234
EZWood
BAMF
EZWood's Avatar
Ignition coil. That's it. It's a pretty nasty knock though.
Old 08-27-2014, 07:34 PM   #27235
captain_jack
Huh, what's your mileage?
Old 08-27-2014, 07:35 PM   #27236
EZWood
BAMF
EZWood's Avatar
The code was for an ignition coil. I have a little over 22000 miles.
Old 08-27-2014, 07:36 PM   #27237
captain_jack
Huh at least it's under warranty
The Following User Says Thank You to captain_jack For This Useful Post:
jeffsides (08-27-2014)
Old 08-27-2014, 07:46 PM   #27238
EZWood
BAMF
EZWood's Avatar
You're telling me.
The Following User Says Thank You to EZWood For This Useful Post:
captain_jack (08-27-2014)
Old 08-27-2014, 08:05 PM   #27239
Yruyur
Yruyur's Avatar
Been there done that. Good luck. Remember you have the free tow from scion as well.
Sent from my SCH-I545 using Tapatalk 2
The Following 2 Users Say Thank You to Yruyur For This Useful Post:
EZWood (08-27-2014), jeffsides (08-27-2014)
Old 08-27-2014, 11:49 PM   #27240
EZWood
BAMF
EZWood's Avatar
Thanks Chris. How long did it take for you to get a new longblock?
Old 08-28-2014, 12:03 AM   #27241
Yruyur
Yruyur's Avatar
I got a short block and it was less than a week. They had just done one so not a lot of time diagnosing was needed.
The Following User Says Thank You to Yruyur For This Useful Post:
EZWood (08-28-2014)
Old 08-28-2014, 03:38 AM   #27242
VenomGT
VenomGT's Avatar
Drives: Firestorm Red FRS, Viper Red Miata
Hey guys, while on the knocking subject, I know our cars can run 91 (I notice a slightly knock and retarding on heavy load) but the manual recommends 93 in states that don't have 91, I was mixing 100 and 91 to get roughly a 93 but while cruising through forums I noticed that gt86 and international manuals recommend 98 ron. Now given that that makes out to roughly about 95 on our index I was wondering if they merely recommended 93/91 to get it in the hands of most car owners that pump at a typical station and not necessarily what is optimal in a perfect world. Idk if it makes a difference engine wise but I've been filling up with 95 ethanol free at a gas station off the 101 and bell called Tom's Thumb and I have noticed fuel efficiency rise both under low and heavy acceleration and I swear that it feels a little more responsive but I was just wondering everyones take on this one.
VenomGT is offline   Reply With Quote
Old 08-28-2014, 03:49 PM   #27243
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
What are you using to monitor knock?
The ECU is ALWAYS correcting timing based on learned knock values and active knock values which depending on the amount of correction could potentially be felt physically (it would have to be pretty significant). I don't know what all is done to your car but if stock it should be practically negligible. So much so that mixing fuels is more a waste of time and money IF it's in relatively in stock form.
"Responsiveness" can be the sensation when timing is advanced so I guess the question is again, how are you monitoring knock? If you are, the answer will be right there in the numbers. All you have to do is see what corrections if any are occurring between your fueling and driving scenarios.
If you are not actually monitoring knock values then you physically knowing it's happening is practically impossible unless it's severe knock. In that case something else is wrong. The ECUs of today are way too fast at correcting such issues that even the most acute of listeners and seat of the pants observers would not be able to tell it's happening.
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
The Following 4 Users Say Thank You to AZFA20 For This Useful Post:
captain_jack (08-28-2014), J. O'Grimm (08-29-2014), kavanagh (08-28-2014), R3NIK (08-28-2014)
Old 08-28-2014, 07:13 PM   #27244
EZWood
BAMF
EZWood's Avatar
If I decide to get rid of my car I'll be selling my full exhaust, and rims &tires. The rims are 18 inch sparcos the tires are 225/40/zr18 pilot super sports. The tires are brand new, I didn't make it a mile before the car started knocking after having them installed. Exhaust is agency power. I know there's a lot of naysaying about vivid and agency power, but when we had a tuning day my car made just about the same numbers as a car with the jdl header and some other exhaust work. This is just kind of a feeler and I may not get rid of my car. I just want to get everything in line if I go that direction.
