Old 08-27-2014, 08:56 PM   #15
FR-S Matt
Staying under 70 mph also helps gas mileage a lot. For a manual, 70 mph is just a hair under 3k.
Old 08-27-2014, 09:05 PM   #16
s2kbobby
s2kbobby's Avatar
Drives: 2013 BRZ WRBlue
Originally Posted by troek View Post
i just do whatever i have to that lets me barely press the gas pedal. on the highway, i can easily get 400 gallons out of a tank.
WOW!! I think my tank is only about ten gallons. . . . .
s2kbobby is offline   Reply With Quote
Old 08-27-2014, 09:09 PM   #17
troek
troek's Avatar
Drives: 2012 Toyota 86
haha fixed, and i believe we all have around 12 gallon tanks.
troek is offline   Reply With Quote
Old 08-27-2014, 09:58 PM   #18
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
I usually keep it around 3k rpm. Anything less than 2k is too low and you will get shitty mileage. 100% city and i am getting around 25mpg.
Muaddib is offline   Reply With Quote
Old 08-27-2014, 10:13 PM   #19
FirestormFRS
A gasoline internal combustion engine is always most efficient at wide open throttle.
Now let the flames begin!
FirestormFRS is offline   Reply With Quote
Old 08-27-2014, 10:21 PM   #20
DC2R
Drives: 2014 Scion FR-S
I've been trying to get it yup to above 40 and then just through it into sixth. It's that bad for mpg?
Sent from my GT-N5110 using Tapatalk
DC2R is offline   Reply With Quote
Old 08-27-2014, 10:21 PM   #21
radroach
Drives: car
This is very true when you're at 3500-4000 RPM at the bottom of the torque dip and cruising you'll get 25-30 mpg.
Old 08-28-2014, 12:06 AM   #22
ThatManAnt
Drives: Whiteout FR-S 6spd
Well good cause im driving it like you guys say i should, just wondered about the topic.
ThatManAnt is offline   Reply With Quote
Old 08-28-2014, 12:52 AM   #23
mashal
DADA
mashal's Avatar
Drives: 2013
Get turbo, forget MPG
mashal is offline   Reply With Quote
The Following User Says Thank You to mashal For This Useful Post:
Marco_86 (08-30-2014)
Old 08-28-2014, 02:54 PM   #24
Eurasianman
Chief
Eurasianman's Avatar
Drives: 2013 DGM BRZ Premium 6MT
I normally only go into 6th gear if I am going 40 MPH or more and am cruising. Car seems to be fine. And an a 3 hour car trip, averaging around 75 MPH, I got about 34 MPG. This is with a manual transmission and everything is stock.
Eurasianman is offline   Reply With Quote
Old 08-28-2014, 05:32 PM   #25
CruiseZen
CruiseZen's Avatar
Drives: 2014 Ultramarine 6MT FR-S Monogram
Originally Posted by nguyen_er View Post
So let's say I'm going like 40 mph. Should I stay in 6th at 1800 rpm or 5th at 2300 rpm?
Depends upon whether you are going uphill or downhill. Downhill in 6th gear at 40 mph is no problem. Going uphill you should be in 5th or if its a steep hill, in 4th.
Borla axleback exhaust * mud guards * Michelin Pilot Super Sport tires * Opti-Coat * BRZ trunk lid liner * Rexpeed Wide Mirrors (heated)
CruiseZen is offline   Reply With Quote
The Following User Says Thank You to CruiseZen For This Useful Post:
nguyen_er (08-28-2014)
Old 08-29-2014, 02:40 PM   #26
DC2R
What if we have no hills? Everything is flat here
Sent from my SM-N900T using Tapatalk
Old 08-29-2014, 03:26 PM   #27
HerrFunf
Drives: 2014 FR-S
Originally Posted by Kaotic Lazagna View Post
I shift around 3k rpm with light throttle input. If you can withstand going (legally) slow on the freeway, keep your throttle at 17% unless you dip below 50 mph. I've gotten 41 mpg on a tank before, and am averaging 36 mpg.
Thats really good. Where did the EPA come up with a 30mpg highway rating on our cars.. I average 30mpg in mixed driving in my MT and get about 36mpg on long highway trips if I keep it under 75mph.
The bang for the buck of this car is absolutely extraordinary!
HerrFunf is offline   Reply With Quote
The Following User Says Thank You to HerrFunf For This Useful Post:
Kaotic Lazagna (08-29-2014)
Old 08-29-2014, 03:31 PM   #28
nguyen_er
nguyen_er's Avatar
Drives: 2013 Raven FR-S
I live in Kansas. Everything is like a girl with a cups. Flat.
nguyen_er is offline   Reply With Quote
The Following User Says Thank You to nguyen_er For This Useful Post:
DC2R (08-29-2014)
