Old 08-26-2014, 11:26 PM   #1
Jman1759
Builder
Drives: 2014 BRZ - World Rally Blue
BRZ antenna shave?
I am not happy with the slight color difference of the shark fin antenna. Also, I am not a fan of the available options for antennas. I am considering having the roof vinyl wrapped, so thinking about removing the antenna altogether.
Has anyone relocated the antenna? Possibly moved it to the back of the headliner, top of the rear window?
Jman1759 is offline   Reply With Quote
Old 08-27-2014, 12:39 AM   #2
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
One of the carbon replacement roofs has an option without the antenna hole...
Old 08-27-2014, 02:56 AM   #3
kcco-whiteout
Drives: Pony
Working on a solution to this myself this weekend on my FRS. You might be able to do it on a BRZ. Should retain all radio functionality and may be able to get better reception than stock and plug the hole with any antenna that will fit or fill it and paint over it. If everything goes to plan then I'm gonna make a diy.
kcco-whiteout is offline   Reply With Quote
The Following 2 Users Say Thank You to kcco-whiteout For This Useful Post:
illicitstylz (08-27-2014), Jman1759 (08-27-2014)
Old 08-27-2014, 09:17 AM   #4
dubbrand
You could just repaint your sharkfin with the correct color so it matches
dubbrand is offline   Reply With Quote
Old 08-27-2014, 04:04 PM   #5
Jman1759
Builder
I had one and resold it. My local shop would not install it due to liability reasons and I didn't have the balls to do it myself... Just being honest!
Old 08-27-2014, 04:05 PM   #6
Jman1759
Builder
It is the exact same color code. Apparently the different light angles effect it...
Shave the Front Emblem? Acree Cosmetic Modification (Interior/Exterior/Lighting) 37 01-24-2021 03:26 PM
Antenna Shave ? SmsAlSuwaidi Cosmetic Modification (Interior/Exterior/Lighting) 9 10-09-2013 07:35 PM
BRZ Pearl White Beat-Sonic Antenna and Perrin 2" Shorty Antenna ericmpena Exterior Parts (Aero, Lighting, Etc.) 3 08-08-2013 04:38 PM
Rear emblem shave? shawnperolis Cosmetic Modification (Interior/Exterior/Lighting) 5 04-10-2013 11:06 AM
How can i shave weight? fernan2 BRZ First-Gen (2012+) — General Topics 15 11-01-2011 10:31 AM
