View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 08-23-2014, 12:35 AM   #4425
xRavenFRSx
xRavenFRSx's Avatar
Drives: 2014 Raven FR-S
Originally Posted by extrashaky View Post
Nah, that has not been determined. People who switch over to E85 report that their crickets disappear. If ethanol content were a factor, those crickets should be singing like sonsabitches. Meanwhile I have personally used ethanol-free gas that gave me chirps and E10 that didn't. If ethanol were the culprit, we should get consistent results from these different ethanol concentrations. We don't.
I continue to be convinced it's the additive packages. Top tier gas is required to have 10% ethanol. Top tier gas also usually has some kind of additive package with detergents and drying agents to keep your injectors clean and keep the ethanol from absorbing water. When you buy ethanol-free gas, you're buying lower tier gas, which may not have the same fancy additives. I think it's the lack of those additives and NOT the lack of ethanol that gets rid of the crickets.
That would make sense with the E85 results as well. That fuel wouldn't have the same additive package as a mostly gasoline fuel. There's something in the additive packages in the top tier gas that isn't found in either the E85 or the ethanol-free fuel, and THAT is what is causing our crickets.
Find yourself a Plymouth Cricket and swap.
Thanks for the info. I didn't consider the additives. The reading I have done previously in this thread had me thinking it was ethanol. There is a lot of back and forth throughout this thread, I stopped actively reading through every page quite a bit ago.
xRavenFRSx is offline   Reply With Quote
Old 08-23-2014, 12:46 AM   #4426
litemup
Drives: around
Know that the ethanol content has been debated to death on here but there may be some validity to it. Other then the "free" fill up from the dealer when they put regular in because they say the premium is only recommended and not required (hmmm just how will my service visits go?) mine has only seen 91 Esso with no ethanol. Check for crickets after various different operating conditions and still insect free (although my wife thinks I have lost my mind standing at the front of the car listening all the time).
Put a couple tanks of something else in. You'll know, and so will she.
litemup is offline   Reply With Quote
Old 08-23-2014, 05:33 AM   #4427
dodah
Drives: na
ive joined the cricket club after 2.1k miles
dodah is offline   Reply With Quote
Old 08-23-2014, 02:51 PM   #4428
WanFeiLong
Drives: '15 WRB BRZ Prem
Crickets after 500 miles. As long as its not a detrimental issue I couldn't be bothered.
WanFeiLong is offline   Reply With Quote
Old 08-24-2014, 08:09 AM   #4429
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
At 11k now and my crickets disappeared... Wonder if it's because it's been cooler outside the past week? One thing we do know, temperature definitely does make a difference, so that's probably it
xxBrun0xx is offline   Reply With Quote
Old 08-25-2014, 09:49 AM   #4430
HunterGreene
Hail Magnet
HunterGreene's Avatar
Not a bad guess...but you aren't considering the fact that there are big differences between E0, E10 and E85 as far as the fluid dynamics are concerned. Think cavitation point, vapor pressure, etc. Add into the fact that those same dynamics change depending on engine and ambient temperature, and I would guess that's going to have a bigger effect than any minuscule additive package (which, if I recall, is less than 1% of the gas you put in your tank, and is mostly "snake oil") will have.
It has priests in it?
The Following User Says Thank You to HunterGreene For This Useful Post:
unsurety (08-25-2014)
Old 08-25-2014, 03:48 PM   #4431
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I hit that mileage in the dead of summer and my crickets were gone, this included a Saturday afternoon drive in 115 degree heat.
Optimistically you're probably out of the patch.
litemup (08-25-2014)
Old 08-25-2014, 04:19 PM   #4432
litemup
Drives: around
I'll be damned. I've still been filling up with E0 occasionally but now I'm thinking that may only prolong the issue.
Old 08-25-2014, 05:23 PM   #4433
strat61caster
I've only had access to E10 and I've never gone out of my way to get 'nicer' fuel at say Shell or 76 or whatever, just grab what's cheap or convenient. Haven't heard a peep in over a year and 20k miles.
Old 08-25-2014, 08:42 PM   #4434
Sportington
Sportington's Avatar
Drives: 2013 Aquamarine FR-S
@litemup. I filled with E0 from the Country Store - so far crickets are gone.
Previously:
2011 Mustang GT/2000 323Ci/1997 M3/1991 Sentra SE-R/1985 CRX Si/1983 GTI
Sportington is offline   Reply With Quote
Old 08-25-2014, 08:49 PM   #4435
litemup
Drives: around
I went back for the E0 a couple weeks ago for my first track day. Strictly a vanity move. It was a pleasant tank of gas.
@HunterGreene and I discussed the idea of pump break-in versus break-down a while back. I'm looking forward to confirming your results.
Old 08-25-2014, 08:52 PM   #4436
litemup
Drives: around
Ha! I just admitted my moment of weakness. I am so torn because their gas is the bomb!
Old 08-25-2014, 09:27 PM   #4437
yaguphire
Drives: white-out FR-S
Any one replace their pump recently?
yaguphire is offline   Reply With Quote
Old 08-25-2014, 09:48 PM   #4438
tanner
Drives: '10 S4/'13 BRZ/'16 GT4/E30 M3
Replaced on July 19th, one track day so far, daily driver, all good.
Mike
tanner is offline   Reply With Quote
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 10:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
