Old 08-24-2014, 02:19 PM   #43
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by Rosticles View Post
Do the four the support rods clear the plastic bumper without modification? Do the side supports clear fog lights, washer reservoir, or possible coolers?
The four support rods will clear without modification. As far as possible coolers and fog lights go, I can't say for sure since our test car didn't have those installed.
Sincerely,
Zach
DeliciousTuning is offline
Old 08-24-2014, 02:21 PM   #44
DeliciousTuning
Originally Posted by Creole View Post
Any word on the street version?
At the moment you can choose from either a 5" (What I have) or 3" version. We are working on an even more street friendly version that will be more of purely a lip protector type deal, although we don't believe that would benefit much in the aero department by itself the same way the 3" or 5" splitters would.
Sincerely,
Zach
Old 08-24-2014, 02:28 PM   #45
DeliciousTuning
Originally Posted by plucas View Post
You say the wind tunnel is the only way to get such numbers but that is completely false and misinformation. One big misconception of wind tunnels are they reproduce what the car will see on the road or track. This is false because wind tunnels only simulate the conditions on the road or track. Simulations inherently deviate from reality and it is often hard to quantify all the sources of error. Wind tunnels idealize temperature change, wind boundary layer, wakes of other car just to name a few.
Sources of these inaccuracies include; the rolling road systems, wall effect (tunnel sections), tires (shape from deformation), cornering conditions (steer and yaw), sting interference, wheel lift, and model is not actually moving (relative motion isn’t the same). Wind tunnel data is precise but saddled with inaccuracies. Road data is free from the inaccuracies but are not precisely measured. Anyone who will quote you extremely accurate numbers from a wind tunnel is trying to sell you something.
Also on CFD analysis, I would be careful saying what it can and cannot do unless you really know. CFD can in fact account for “flex” (deflection) in the system. Some programs need to be coupled with another program to do this, but saying it doesn’t is completely false.
Also, this "other" splitter which is solely mounted to the bumper cover is again false. It mounts to a structural support in the rear. Yes the street system deflects at high rates of speed, but for the street (sub 100 MPH) this is perfect. If it is hit on a curb, or going up a driveway, the splitter will deform instead of cracking like a carbon fiber piece. Even though the splitter is deforming, the forces transfer through the car, they don't just vanish because the bumper cover moves. Instead of going directly to the chassis, it travels through the bumper into the radiator support, which is structural. On top of that, if the user purchases the race upgrade, this directly connects the front lip of the splitter with the chassis. Actually the same mounting points were chosen by Wasp. So when you say it isn't pulling the chassis to the ground, this is false for both the street front splitter, and the race upgrade which is then chassis mounted at the front and the rear.
Please do not spread false information about other people's products or false information to the general public about CFD and wind tunnels.
I apologize if it was interpreted that way. Obviously, both CFD and wind tunnel testing have certain pros, and definitely certain cons. I think we both know that the only true way to get results isn't by numbers themselves, but by taking two identical cars with the same driver, on the same day, and simply comparing times between no splitter, splitter, etc. Obviously time would need to be allowed between laps so that tire temps could be controlled between the two tests.
In addition, to those of you thinking of the 5" version for the street, I wouldn't recommend it. While it is very effective and can really be felt at highway speeds, it extends so far even on a vehicle with a mild drop (I'm -1.2" in front) that it is difficult not to scrape in many instances. The 5" version is really only recommended for track scenarios. For street guys, I'd recommend the 3" unit.
I do believe that the version we offer and the version you offer are two different products for two different crowds, and each have their merits. I was unaware that CFD could account for flex, so I do appreciate the education on that account.
I also look forward to seeing the race version in action, I've been hearing good things about it from the guys over at Driveway Labs.
Sincerely,
Zach
Old 08-24-2014, 04:44 PM   #46
Creole
Creole's Avatar
Drives: Monogram FRS
Sincerely,
Zach
Do they have any pictures of the 3" lip installed on a FRS/BRZ?
Build Thread:
Creoles Creation
Creole is offline
Old 08-24-2014, 05:43 PM   #47
ft86me
ft86me's Avatar
Drives: 2013 FRS
i'm assuming this would be best without a front lip and the use of the factory crash beam?
ft86me is offline
Old 09-03-2014, 03:28 PM   #48
final gear
Drives: Lava FR-S
APR carbon honeycomb splitter.
final gear is offline
Old 10-30-2014, 10:52 AM   #49
WatchmaN
WatchmaN's Avatar
Drives: the girls crazy
Pissing match lol
Vortech SC(314hp/226tq), Perrin pully, Tanabe strut tower bar, Perrin exhaust, LP Tune, hsd coilovers, DTC-60 fr, hp+rear),track rubber RS3 and Continental :-), Forester oem oil cooler,Custom brake cooling kit. Driveway lab rear diffuser, Wasp front spliter, TRD canard/fenders.
WatchmaN is offline
Old 11-09-2014, 03:51 AM   #50
umpadupa
umpadupa's Avatar
Drives: 94 civic hatch, Whiteout frs
Does it fit with intercooler?
umpadupa is offline
Old 12-15-2014, 01:45 PM   #51
aznflightfreak23
aznflightfreak23's Avatar
Drives: 2014 Subaru BRZ Limited Manual
What the update about this splitter? Highly interested
aznflightfreak23 is offline
Old 12-15-2014, 03:14 PM   #52
WatchmaN
WatchmaN's Avatar
got mine but not installed yet since track day's are over up here for winter
WatchmaN is offline
Old 12-15-2014, 04:59 PM   #53
WoOosOn
WoOosOn's Avatar
Drives: S2000 AP1, BRZ SWP
Had this splitter installed a couple months back. Works well with my Voltex S1 wing. Use to have just the wing and it had a lot of understeer. The car is a lot more balanced now. Looks great! I have it installed under my STi rep lip.
I have more pictures of install. I'll post later
Size:  133.2 KBName:  ImageUploadedByTapatalk1418680689.542519.jpg
WoOosOn is offline
The Following 4 Users Say Thank You to WoOosOn For This Useful Post:
fx35s (12-17-2014), limitedblkwrx (05-12-2015), Rosticles (12-15-2014), toby714 (12-15-2014)
Old 12-15-2014, 07:30 PM   #54
Creole
Creole's Avatar
Attachment 98255Attachment 98256
What size splitter is that?
Build Thread:
Creoles Creation
Creole is offline
Old 12-15-2014, 07:32 PM   #55
Creole
Creole's Avatar
Sincerely,
Zach
Any pictures of the 3" installed on one of our cars yet?
Build Thread:
Creoles Creation
Creole is offline
Old 12-15-2014, 07:49 PM   #56
WoOosOn
WoOosOn's Avatar
This is the 5" track splitter. It looks smaller in the picture because of the extra lip I have on.
WoOosOn is offline
The Following User Says Thank You to WoOosOn For This Useful Post:
Creole (12-15-2014)
Just Added APR front splitter and side splitter Pekingduck Cosmetic Modification (Interior/Exterior/Lighting) 42 08-31-2016 10:22 AM
Finally got my OFT mounted The Racers Line Software Tuning 14 05-24-2014 01:40 AM
Build-thread White Wasp FR-S by Mit_Peid mit_peid Member's Car Journals 7 01-05-2014 07:47 PM
where can i get my front spoiler mounted? VoiD Mid-Atlantic 1 09-18-2013 11:08 PM
Stock Tires mounted? feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-19-2012 04:02 PM
