#57 | |
No, I follow the break in procedure. Good guess though, bro.
#58 |
~100k.
| The Following User Says Thank You to s2d4 For This Useful Post: | strat61caster (08-24-2014) |
#59 |
Drives: Asphalt FRS
*Find the engagement point, practice letting out just at the engagement point.
*While on the hill, right foot on brake, left foot on clutch, let clutch out just before the engagement point. (don't panic) *Lift foot off brake and add gas SLOWLY but not so slow that you don't give enough gas and simultaneously let go of the clutch SLOWLY but not so slow you are riding the clutch (no more than 1.5 seconds) this is a guideline, by no means is it exact science Keep practicing and good luck! |
#60 | |
Drives: '13 FRS
#61 | |
Drives: Toyota GT86 Coupe Red (UK)
You'll wear the clutch more in one spirited get away than 10 minutes of hill holding (spread over weeks, not all at once!) Very much the same as your brakes. Driving down a long, long hill, like out of the mountains and riding the brake the whole way down, you will start to smell your brake pads burning. Better to select a low gear and use engine braking. Tying in other discussions from on here it comes down to how costly a clutch is in your area for your car. Different cars vary on how hard the gear box and engine are to separate. Most can be done in place, some need dropped out. The GT86 being RWD should be fairly simple. The actual parts are cheap. 4WD are the worst as the front drive shafts and prop shaft have to come out. I think the show I watched with the Impreza replacement they said it would be a 4-6 hour job, so in the UK around 240 pounds + parts + sales tax, or about 500 pounds, circa $850
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
#62 | |
Drives: '06 AM V8V Coupe
Either way clutches are robust but why would you not use the brake? Your car has a brake, that's a much better way to hold your car on a hill...I can take off on the steepest SF hills using less than 1500rpm and no handbrake, and I could do that easily with under 1000 miles of city driving. |
| The Following User Says Thank You to serialk11r For This Useful Post: | strat61caster (08-24-2014) |
#63 |
Depends on your spirited get away.
#64 |
Drives: 2013 GBS BRZ Limited
This entire discussion about hill starts comes down to "how quick are you?".
If you are fast enough moving your foot from the brake to the gas, and you know right where your clutch engagement point is, then the handbrake is not required and just complicates the issue. For those that say that "using the handbrake on a hill is required by law"...... HOW MUCH OF A HILL is required for the law to kick in???? See how that works? Sounds hard to enforce. Is there a degree of incline mentioned in the laws? Since almost ANY start is on SOME kind of incline, then do you need to ALWAYS use the handbrake even if the incline is on 5%?? At what angle do the police start issuing tickets? Do they have an inclinometer with them so they can measure the hill before issuing the ticket? Bottom line - If you are good with the MT, you dont need a handbrake for a hill start unless it is a really steep hill, or the jackass behind you pulled right up to your bumper. So learn BOTH the handbrake method and the non-handbrake method and hope to never NEED the handbrake method. |
#65 |
None. If you are stationary for any length of time you should secure the car in neutral with the handbrake on.
| The Following User Says Thank You to paulca For This Useful Post: | strat61caster (08-24-2014) |
#66 | |
"stationary for any length of time" literally means "ANY time you stop". You dont honestly think you could ticket someone for that do you? |
#67 |
Press in clutch. Shift into 1st. Rev to 7400. Sidestep clutch. Hang on.
It's like making love; once you learn, you never forget. |
#68 |
#69 | |
You would also fail a driving test if you sat for any length period without the handbrake on. How long is lengthy? My instructor explained it to me as; if you are "pausing" and can see you will be moving off almost immediately, stay in gear, if the pause looks like it will become a wait, handbrake and neutral. Handbrake always when starting off on a hill. You don't want to be pulling up to a stop, immediately handbrake/neutral only to almost as immediately put it into 1st and drop the handbrake again. It requires some sense and self determination. It's not a comedy sketch. Planning and anticipation is assessed even on a learner test. I do want to point out that I am more than capable of doing several techniques of hill start not involving the handbrake, but as I have OCD about rolling back (or forward when reversing) and the handbrake method is the easiest, so I tend to use the handbrake method 99% of the time. Anyway, it's another control that has many uses, to ignore it is limiting your driving skill and ability. It's there, use it when it's appropriate. Like entering a hairpin bend, brake hard, turn in, clutch down, WHACK the handbrake one sharp tug (better be ready!), while rotating: 1st, throttle, clutch... WOOOOOHOOOOO! (3 penalty points for dangerous driving but 20 points for style).
| The Following User Says Thank You to paulca For This Useful Post: | stugray (08-24-2014) |
#70 | |
The odd "track day style" power band getaway is always worth doing now and again.
| The Following 2 Users Say Thank You to paulca For This Useful Post: | brianhj (08-29-2014), serialk11r (08-24-2014) |
| Teaching wife to drive stick? | Nm86 | Scion FR-S / Toyota 86 GT86 General Forum | 58 | 03-26-2014 11:41 AM |
| Stevens Creek Scion salesman can't drive stick | chas3wba0 | Northern California | 10 | 11-01-2013 06:51 PM |
| Fact: Girls find it hot when a guy knows how to drive stick? | shishand | Off-Topic Lounge [WARNING: NO POLITICS] | 86 | 10-20-2012 03:51 PM |
| To Drive a stick or cruise an Auto? | MrFRsLa | Scion FR-S / Toyota 86 GT86 General Forum | 54 | 04-30-2012 07:50 PM |
| AutoGuide.com: Parents Push Teens To Drive Stick to Avoid Distracted Driving | poormans_LFA | Other Vehicles & General Automotive Discussions | 15 | 01-25-2012 10:02 AM |
