Old 08-23-2014, 09:29 PM   #1
norcalpb
norcalpb's Avatar
What happened to my rear camber?
Hey guys, I just installed koni struts/rce tarmac springs/hvt top hats on my 2013 BRZ. Everything feels great, but I have a discrepancy with the rear camber.
I got an alignment with stock suspension on 8/20/14 as part of my car coming back from the body shop (hit a tire) here are the after results. Pretty good, toe was just slightly off.
And here are the results from today after installing the new suspension
As you can camber is -1.5 on one side and -2.3 on the other. Is this due to an installation error? Or is this level of difference acceptable? I was jumping on the back right control arm to get the strut out, maybe I damaged it? I might switch the rear struts (if thats even possible) to see if that helps.
Thanks in advance!
Steve
Old 08-23-2014, 10:07 PM   #2
Ganthrithor
Ganthrithor's Avatar
Drives: '13 BRZ, '06 997, Other Things(TM)
Hahaha, I just spent five minutes staring at the first picture going, "Huh? It's identical side-for-side," before realizing there was another photo.
Don't you generally need to have things re-aligned any time you make any suspension changes?
Ganthrithor is offline   Reply With Quote
Old 08-23-2014, 10:10 PM   #3
cnk
Drives: '13 DGM BRZ Limited
There is some wiggle room in all the components when reinstalling. I'm betting that's where most of your discrepancy is coming from.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Old 08-23-2014, 10:14 PM   #4
norcalpb
norcalpb's Avatar
Thanks for the replies,
I got 2 alignments in the last 3 days
The wiggle room sounds like it may be causing the problem, but the "before" had 1.5/2.5f
1.6/2.3r,
So the whole right side of the car had excessive camber and toe. Maybe it just wasn't settled haha.
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 02:10 PM
SPC rear camber arm question Chopstick Northern California 6 06-10-2014 12:18 AM
WTB rear Camber kit ethanzhang Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 02-21-2014 10:26 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 04:40 PM
