Old 08-22-2014, 01:40 PM   #2157
Tenchi
Tenchi's Avatar
Drives: Silver Ignition 6MT 10 series FR-S
Originally Posted by Tylub View Post
here you go
Nooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooo
Tenchi is offline
Old 08-22-2014, 01:41 PM   #2158
Trettiosjuan
Drives: GT86
Originally Posted by tahdizzle View Post
I am not speaking about build quality...
Air flow and harmonics are affected. So is it reasonable to say the dyno graph has changed since the new design?
Build quality is for Audi. For me quality is consistency in product performance which includes air flow and harmonics. As geometry and bends are identical, air flow can only be affected by pipe joint execution.
I don't believe the dyno graph has changed more than the variance that would have existed within the original batch. In the engineering world, everything varies, the question is if the variation is relevant.
I don't think so, other mods after the headers should affect the graph much more than a few weld seams ever can...
Trettiosjuan is offline
The Following User Says Thank You to Trettiosjuan For This Useful Post:
kodyo (08-22-2014)
Old 08-22-2014, 01:45 PM   #2159
STV3
Señor Member
STV3's Avatar
Mooonnnnicaaaaaaaaaaa!!!!
STV3 is offline
The Following User Says Thank You to STV3 For This Useful Post:
drewbot (09-02-2014)
Old 08-22-2014, 01:46 PM   #2160
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
All of this is speculation until there is a new dyno. Wich I'll have to spend $$ to do. Which defeats the purpose of my purchase of this particular header to begin with.
-Jack Burton
tahdizzle is offline
Old 08-22-2014, 02:03 PM   #2161
DarkestBuddha
Drives: BRZ limited GBS
DarkestBuddha is offline
Old 08-22-2014, 02:06 PM   #2162
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
The weld did not break, the metal broke on the outside of it which is something that is out of our control as metal is not uniform in strength usually. It's under warranty and will be covered. Already working on the email Tylub sent in.
FT-86 SpeedFactory is offline
The Following 2 Users Say Thank You to FT-86 SpeedFactory For This Useful Post:
chas3wba0 (09-03-2014), Tylub (08-22-2014)
Old 08-22-2014, 02:10 PM   #2163
FT-86 SpeedFactory
So you agree that the flow can be different? and you are assuming that it is an improvement.
The entire reason I chose an ft86 UEL header was ability to remove the torque dip w/o a tune.
That being said. There has not been any data showing information on the new headers; from FT86 or a 3rd party.
I did give them the benefit of the doubt, but after installing the header I am not convinced it has the same graph.
That being said. when I originally purchased the header, I did so based on the information given.
When a retailer shows you data on a product and you purchase the product based on that data. Then the seller changes the product and assures you that its the same product w/o any data to reinforce their claims. It is due diligence to be skeptical.
I don't have the blind faith you have.
Please send the header back for a full refund. I'll even supply an UPS label for you. Shoot me an order number and I will make it happen.
Or we can always just cut it in a few spots, add some more welds if you would like and send it back. Totally your call.
We created a header that no one else would. We provided the data on a stock car with no other parts and no tune. We then had independent dynos done by clients to prove the gain. We did all this which no other MFG has done and time and time again we have to keep proving ourselves while others get away with it. The muti-weld unit was 3D scanned, and then used to create bends that reduced weld time, and created less turbulence in the flow since each weld is technically not smooth on the inside, therefor a better product.
We're a small company in Iowa, doing our absolute best to make quality parts, and make sure everyone is happy. We're not here to give false claims or screw around, this is our lively hood.
The Following 15 Users Say Thank You to FT-86 SpeedFactory For This Useful Post:
akahenry (08-22-2014), brianhj (08-23-2014), chas3wba0 (08-25-2014), craigpitts7 (08-23-2014), hattrickey (08-22-2014), husker741 (08-22-2014), JaguarXJ6 (10-28-2014), kodyo (08-22-2014), Pwolf (08-22-2014), sato (08-22-2014), SCharged (08-22-2014), Sypher (09-15-2014), Trettiosjuan (08-22-2014), TrogDor the Burninator (08-22-2014), unsurety (09-20-2014)
Old 08-22-2014, 02:11 PM   #2164
vroom4
Its in the heat effected zone of the weld,the failure is a direct result of the weld and design of the header. Or at least it would be in normal product design? But in small batches of engineered products, theory is kind of out the window, its more just failure rate which proves the design of the product.
vroom4 is offline
The Following User Says Thank You to vroom4 For This Useful Post:
Old 08-22-2014, 02:12 PM   #2165
tahdizzle
So elite I'm 1338
I'll spend the $$ and supply information to customers. Thanks for the offer though.
-Jack Burton
Old 08-22-2014, 02:34 PM   #2166
Tylub
Tylub's Avatar
Drives: Raven Black FR-S
Thanks for the quick response @FT-86 SpeedFactory sending it in today
instagram @Tylub
Mods: Tomei UELs, Tomei OP, Perrin Catted FP, ARK DT-S, Perrin LW Crank Pulley, Enkei RPF1, RSR Sporti, Supertek Intake Tube, Perrin CAI, Stoptech SS lines/brakes/slotted rotors, Cusco MCB brace/Strut Bar
Tylub is offline
Old 08-22-2014, 02:38 PM   #2167
Trettiosjuan
Drives: GT86
So you are still experiencing a dip then? Can you provide more information? Is your doubt reasonable?
Until then, I can only comment that automotive products change all the time during their production life without informing the customer. If a company is open with this, it is not helpfull if customers start questioning every decision and spread discontent based on, yes, speculation based on their own interpretations.
I for one am happy with the openness of the manufacturer so far. Cherish that and give benefit of the doubt that they know what service and product they provide. And how to make it...
The Following 2 Users Say Thank You to Trettiosjuan For This Useful Post:
chas3wba0 (08-25-2014), STV3 (08-22-2014)
Old 08-22-2014, 04:13 PM   #2168
tahdizzle
So elite I'm 1338
.... really? Have I not been saying I need to take it to the dyno, and that there has not been a Dyno of the new header design provided by ft86sf?
Once I have time to get it on a dyno, I'll be sure to provide you all with the graphs.
-Jack Burton
Old 08-22-2014, 04:46 PM   #2169
Trettiosjuan
Drives: GT86
Yes you keep repeating yourself, talking about "new design" but that is your interpretation, ok? And no anecdotal evidence either from the butt dyno, just others that need to prove themselves because you say so?!?
No, you provide graphs and document it all, who knows perhaps there actually is a problem we as customers *should* actually worry about... But until then I intend not to lose any sleep on this.
Old 08-22-2014, 05:01 PM   #2170
tahdizzle
So elite I'm 1338
Hey, if you can feel it then its obviously measurable.
Local shop, $60 for 3 runs. Once I find time I'll do the runs and post graphs.
Hopefully its in my head, however, it needs to be tested.
-Jack Burton
catted uel header, ft86speedfactory header, is my order ready yet?
Invidia Catless and Catted Front Pipe - ** FT-86 SpeedFactory ** FT-86 SpeedFactory Engine, Exhaust, Transmission 107 03-29-2016 10:48 AM
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 12:32 PM
P&l EL catted and coated header. wootwoot Engine, Exhaust, Bolt-Ons 8 10-11-2013 12:50 AM
Catted UEL Header Cjymiller Engine, Exhaust, Transmission 20 05-24-2013 12:01 PM
***Invidia Catted and Catless Front Pipes*** - FT-86 SpeedFactory RELEASE SALE FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 12 10-24-2012 10:12 PM
