Old 04-25-2012, 03:42 AM   #29
Dimman
Kuruma Otaku
Dimman's Avatar
Originally Posted by serialk11r View Post
Yea, but that supports my point because the TRD 3S-GE has basically no low end torque at all. By 4000rpm you're already down to 160Nm which is pathetic, and I bet that the FA20 at idle is better than that TRD engine at 2000rpm.
Not saying I'd care though The top end is like a freaking Ferrari 458 cut in half.
I can't even find my own damn post that had the graph...
But the low end penalty must always be paid for ridiculous top end power. (Hybrid-free, as nature intended, btw... heh...)
Something, something, no replacement for displacement... except a compact electric motor?
Because titanium.
Old 04-25-2012, 04:07 AM   #30
serialk11r
Drives: '06 AM V8V Coupe
I spent several minutes finding it heh.
http://trdparts.jp/english/parts_engine-3s-ge.html
13.5 compression, that would definitely help at high rpm where the fuel doesn't have as much time to burn.
No replacement for displacement heh, I guess TRD proved that one wrong. A compact electric motor easily adds like 100Nm to the very bottom end, and it slowly tapers off but the gas engine comes alive as the rpms climb anyways. Cams and stuff can be done certainly, but I wonder how the intake tuning is done on these Subaru boxers since their configuration doesn't give options for shortening the intake runners. (I have no idea if they actually need to be shorter, but ITB trumpets are always short looking).
One day when I have a real job and a car, oh god so much money is going to go into my random ass ideas.
Old 04-25-2012, 05:47 AM   #31
KeepGuessing
Drives: e30 150 deville etc etc
1: There is no replacement for displacement.
2. The short rods hampering the rev range only come into play when the rest of the engine dynamics can be accessed...
You can't look at a "estimated rod length" and stroke and say This engine can't make XXXXrpm reliably..Just doesn't work like that...
As it sits power production from fueling becomes an issue due to piston in cylinder speeds
we don't know the type of rod angles we're dealing with if it's working off of ej or fb architecture.....we don't know what kind of sideloads it'll have or if the pistons can deal with that type of constant G's due to lack of material etc etc etc
KeepGuessing is offline   Reply With Quote
Old 04-25-2012, 06:37 AM   #32
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
This is the problem with newer NA engines. It costs tons of money for only minor gains.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 04-25-2012, 07:27 AM   #33
serialk11r
Of course, that's why I said we need to wait for more detailed specs. HomemadeWRX/3MI Racing already has rod specs apparently (but probably can't say), and may have offset already. However I'm just pointing out a few things about the engine that generally aren't good. The engine is very wide already so it can't really grow to accomodate longer rods or a more sophisticated valvetrain (no hope of variable lift or anything). At the same time we have a latest generation combustion chamber and fuel delivery design, which is nice.
I do believe in low levels of boost though.
Old 04-25-2012, 09:26 AM   #34
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
That's why if you buy this car you have to be happy with the stock output or close to it or else you will beat yourself up in the long run. I would love to drive it just to see how it feels in comparison to my RSX acceleration wise since that is the main part of my RSX I dislike.
SUB-FT86 is offline   Reply With Quote
Old 04-25-2012, 10:32 AM   #35
KeepGuessing
Was this sarcasm right? I can't tell.
The car has variable valve lift..
Old 04-25-2012, 10:42 AM   #36
ChristosG
Drives: 2013 Scion FR-S Hot Lava 6MT
As a fellow RSX driver I think we'll be more than satisfied with the acceleration. Even though the RSX is rated at 139 lb-ft of torque, you don't get all of that to the wheels and not even until 5-6K RPM. With the FR-S we'll get around 145 at the wheels and at low RPM so it should be a huge difference. Especially for me since mine is not a Type S.
ChristosG is offline   Reply With Quote
Old 04-25-2012, 11:08 AM   #37
SUB-FT86
86 Member
I have a base model too and the torque comes on earlier than the type S but it still feels kind of gutless still.
Old 04-25-2012, 11:10 AM   #38
SUB-FT86
86 Member
I think he meant a dual system similar to the Vtec in a Type S.
Old 04-25-2012, 03:09 PM   #39
Dimman
Kuruma Otaku
Dimman's Avatar
Please explain the variable valve lift on the FA20.
Because titanium.
Old 04-25-2012, 03:30 PM   #40
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
I look forward to his response with amused eyes.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 04-25-2012, 04:31 PM   #41
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
It has variable valve timing, not lift...
Subie is offline   Reply With Quote
Old 04-25-2012, 05:15 PM   #42
KeepGuessing
Oh i'm sorry I thought he was saying it didn't have variable valve timing....my apologies there bud.
What kind of gains without Turbo Surge101 Engine, Exhaust, Transmission 18 01-25-2012 09:23 PM
Dealer Trade in ......what to expect ? Sall Scion FR-S / Toyota 86 GT86 General Forum 42 01-17-2012 01:34 PM
Estimated HP gains - bolt on mods and reflash? ahausheer Engine, Exhaust, Transmission 207 01-14-2012 06:14 AM
