Old 08-21-2014, 10:12 AM   #1821
ZionsWrath
Thanks
ZionsWrath's Avatar
My set of tires has like 2 - 2.5 hours of track time on them. I have to replace one of the tires due to an accident. Will this have any ill effects? If it would make a difference is there anything I can do like shave 1mm of tread to fix it? I'm no pro so I'm probably overthinking it and won't make a difference for me.
Old 08-21-2014, 12:37 PM   #1822
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Originally Posted by ddeflyer View Post
The gyro is a measure of degrees per second of rotation. If it takes you one second to go around a 90 degree turn you would have a value of 90.
can you extrapolate this a bit further
I'm trying to grasph how to read the gyro readings and apply them in self analysis.
I assume a lower number means faster rotation? I suppose this needs to be correlated with throttle and brake application to rule out oversteer?
in essense, what is the general idea to keep in mind when analysis the gyro reading?
Old 08-21-2014, 01:08 PM   #1823
ddeflyer
I am still pretty new at the analysis myself so I don't know how much I can really tell you.
That said a higher number is a faster rotation over the measured time frame. If you take the area under the curve of the gyro reading, you get the amount of rotation (change in cars direction) that occurred. Like so many channels, you can only really tell what is going on by looking at other channels in conjunction with it and seeing what is happening to the car along with what the driver wants to achieve. For example, a rapid excursion of the gyro value could mean that the driver almost lost it, or they could be popping the car into a four wheel slide to get a thrust angle towards corner exit (ie. diamonding the corner).
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next!
ddeflyer is offline   Reply With Quote
Old 08-21-2014, 01:29 PM   #1824
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
How worn are the other three - can you measure the tread depth on them and compare those to the tread depth on a new tire? It's a total guess, but I'd estimate that if they're within 3/32nds or so that you should be fine.
dradernh is offline   Reply With Quote
Old 08-22-2014, 12:10 AM   #1825
BRZ NA
Drives: WR blue
What kind of lap timer do u guys use?
BRZ NA is offline   Reply With Quote
Old 08-22-2014, 12:29 AM   #1826
CSG Mike
CSG Mike's Avatar
AIM Solo DL is popular, and what we use in the BRZ.
Let us know if you want one; a lot of NorCal guys use it too.
CSG Mike is online now   Reply With Quote
Old 08-22-2014, 02:34 AM   #1827
ddeflyer
AIM Solo DL is awesome. I tried a bunch of things with my phone and such, nothing really gave me the quality of data that I wanted until I got the Solo DL.
Old 08-22-2014, 05:50 AM   #1828
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
because
The Following 2 Users Say Thank You to Captain Snooze For This Useful Post:
CSG Mike (08-22-2014), wparsons (08-22-2014)
Old 08-22-2014, 11:53 AM   #1829
BRZ NA
Drives: WR blue
How much? $300?
Old 08-22-2014, 11:57 AM   #1830
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
How much? $300?
the DL is more than that, but mike can get you a good price,
its worth the money long term and you could use it across different platforms.
Old 08-22-2014, 02:12 PM   #1831
Model Citizen
Lacking brains
Drives: frz
[ame="https://www.youtube.com/watch?v=sdPWnQXdMJE&list"]spin thompson - YouTube[/ame]
this was fun,
lol an unsettled car, takeoffs that were driving terrible and lift off oversteer
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
The Following User Says Thank You to Model Citizen For This Useful Post:
7thgear (08-22-2014)
Old 08-22-2014, 03:11 PM   #1832
dp1
driving smoother faster
Drives: Sold
Originally Posted by Model Citizen View Post
this was fun,
It looks like you stayed tight and your left wheels ran right over that nasty dip in the pavement at the very end of the white line...very easy to unsettle the car by running over it. I discovered the hole during my first time on track, first warm up lap, and stayed away from it since
dp1 is offline   Reply With Quote
Old 08-22-2014, 03:35 PM   #1833
Model Citizen
Lacking brains
Drives: frz
no looks like, the dip is exactly what happened.
have done a handful of days there, ended up behind an ariel atom the previous lap through that section, took it tight like his line,
not to self: you are not driving an atom, nor are you on slicks
Old 08-22-2014, 05:19 PM   #1834
ddeflyer
this was fun,
For a moment I got scared watching that wall get closer!
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
