Old 08-20-2014, 09:52 AM   #15
STV3
Señor Member
STV3's Avatar
Good point.
I wil say this then, parting from your post.
CM FX350 (8 puck)/400 (six puck):
Minimal chatter (skipping/hopping feeling when taking off from a stop)
A LOT of gear rattle (what you hear when the car is idling and the clutch pedal is not pressed in )
Exedy Twin Disk (2 full faces and spacers):
A lot of chatter
Mild Gear rattle
Exedy Stage two (8 puck) fixed:
Minimal chatter
Minimal gear rattle
Yeah my other car has an ACT sprung 6 puck and the gear noise is ridiculously loud. Sounds like a knocking rod loud, but that is just normal for SRT-4's with a light weight fly wheel.
Also get some chatter on that clutch every once in a while if I don't take off smoothly.
OP, I agree with adjusting your clutch pedal. Give it a shot and also maybe try bleeding your clutch line.
STV3 is offline   Reply With Quote
Old 08-20-2014, 10:40 AM   #16
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
I have the Stage 1 as well. It does chatter quite a bit.
FrX is offline   Reply With Quote
Old 08-20-2014, 11:21 AM   #17
qtwre
Drives: White FR-S
Originally Posted by romin View Post
Second after running on the track and heating everything up the following sequence blocks the car from going into gear:
1) Put the car in neutral
2) Let out the clutch
3) Depress the clutch
4) Try to put the car back into gear
When it's cold this sequence works OK.
If I shut the car off it immediately goes into gear.
Rolling forward with the clutch in also allows it to go into gear but I can feel things aligning as I push it into gear.
Any ideas on what's causing this and possible work arounds?
I just called Exedy technical support about this. He said the first thing he would try is pedal adjustment. Otherwise, it sounds like the disc is hanging up on the input shaft due to a lack of lubrication between the shaft and the disc.
He said on their test vehicle they initially had the same problem with getting into gear after a bit of break-in. They cleaned up the shaft and the spline, lubricated and reinstalled then it was fine.
They include a little packet of grease for this reason. In my case I can't say for sure if it was used because my mechanic did the installation, but I would hope he did. I'll be trying the pedal adjustment today and hopefully solve the problem.
qtwre is offline   Reply With Quote
Old 08-20-2014, 09:36 PM   #18
qtwre
Drives: White FR-S
Me again. I was with my mechanic trying to fix the issue. I found that when he put push in the clutch pedal and attempt to put it into first without any brake on, the car would move ever so slightly. I could see the wheels turn a degree or two. So the clutch is definitely not disengaging completely.
He tried adjusting the pedal plunger in both directions and neither helped, unfortunately. So I at least know where the problem is but I don't yet kow how to fix it. It seems like the slave doesn't have the pressure to fully depress the pressure plate. Either that or maybe the clutch disc has too much meat on it and it will eventually wear down and correct the issue.
It seems strange that it's a hit or miss problem. Does anyone sell a braided clutch line? That might help get that extra bit of fluid to the slave.
Old 08-20-2014, 11:47 PM   #19
mike the snake
Maybe bleeding the system might get you the necessary travel to get the clutch to disengage completely. Air in the line will cause your problems with getting into gear.
Old 08-21-2014, 09:58 AM   #20
qtwre
Drives: White FR-S
I thought about that but how likely is that to happen? These cars are still fairly new. Clutch fluid doesn't ever boil like brake fluid, does it? Our systems aren't shared.
One thing it may be is that I'm not out of the break-in period yet and I don't think the OP is either. I suppose it's possible that by the 750 miles they recommend, it could fix itself. I wouldn't expect this to be a normal part of break-in though.
Old 08-21-2014, 10:03 AM   #21
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Locking out of gears, the clutch instructions call for this, might be something to consider:
"Lack of lubrication/dry splines will cause failure to disengage gears and also cause clutch drag.
Never over lubricate / grease the spline of your clutch disc as grease will splatter during rotation of the engine and clutch."
Source: http://www.exedyusa.com/multimedia/s...structions.pdf
I am fairly certain your issue is right there in my above post. The splines need more lube. The bad news is that to do so, trans needs to come down.
Old 08-21-2014, 10:19 AM   #22
qtwre
Drives: White FR-S
Could be, but my mechanic says he definitely lubed it. He said he just used a thin coat on the shaft and the inside splines. They don't exactly specify how much to use. Is 'clutch drag' the terms for trouble engaging gears? I don't have a problem with disengaging.
Old 08-21-2014, 10:25 AM   #23
wparsons
wparsons's Avatar
This! The quote from exedy directly said that this is likely the issue, why bother messing with other things before attempting this?
flickr
Old 08-21-2014, 10:29 AM   #24
qtwre
Drives: White FR-S
Because this is the most expensive option for someone who doesn't have the facilities to drop the tranny himself.
I can't speak for the OP, but in my case this problem came up after a few weeks with the clutch. I wonder if there was too little grease and it became contaminated with filings and dust. It seems like a bad design to require lubrication that will eventually become full of dust (and therefore stop lubricating.)
Old 08-21-2014, 10:30 AM   #25
Sportsguy83
Drives: Limited BRZ
To support the theory, local @marcoaferrer had the issue getting locked out of gear almost everytime, put a very minute amount of grease on the splines (paranoid of getting too much there and getting it on clutch), and his issue improve incredibly better, now he gels locked out maybe 5% of the time. So it's an encouraging result. @jamesm had the same issue on his ACT clutch, put lube in splines and all smooth after that.
Old 08-21-2014, 10:48 AM   #26
marcoaferrer
marcoaferrer's Avatar
Drives: Whiteout FR-S
Exedy has an oddly specific procedure for greasing the splines. They stress the importance of this in several documents.
This is a direct copy/paste from Exedys FAQ doc.
http://www.exedy-racing.com/racing/e...yfaq.html#ac13
__________________________________________________ ____
Do I need to apply grease to the spline of the disc?
Yes, it is required.
However, depending on the method of application and the amount, applied grease may disperse, causing judder and bad disengagement.
Precautions
  • (1) Apply grease evenly to the spline tooth surface of both the main shaft side and the disc side using a brush or similar.
  • (2) After the application, insert the disc into the main shaft, and slide it to see if it will move smoothly.
  • (3) Wipe off the grease straying out from the disc and the main shaft using a rag or something.
<Caution>
Be careful not to deposit any grease or any other oil on the friction surface (flywheel, P PLATE, IM PLATE, disc). It may cause judder, slip, etc.
__________________________________________________ _________________
Im planning to perform this after break in is complete. I am even contemplating buying the grease that the specifically supply with the kit.
marcoaferrer is offline   Reply With Quote
Old 08-21-2014, 11:08 AM   #27
qtwre
Drives: White FR-S
Good call. Since driving around after my mechanic playing with the clutch pedal, it hasn't locked me out. It's just somewhat tougher than it should be from a stop. I can deal with that for now and I'm curious to see what happens to the problem as break-in continues.
At first my world was crumbling when I thought there was something wrong with my transmission. I can deal with this.
Old 08-21-2014, 11:15 AM   #28
marcoaferrer
Another local experienced being locked out after 1000 miles. So I want it to get to that point before I get under the car again. Just as another margin of safety. Also I noticed that if the car isnt warmed up its not likely to happen. Might be due to the difference in the rate of expansion of input shaft and clutch spline hub. (but i no iz scientisticle)
Anybody running Exedy stage 2 clutch? 14BRZ Engine, Exhaust, Transmission 65 05-26-2020 12:21 AM
Exedy Stage 1 Clutch (300RWHP) & Lightweight Flywheel - $400 shipped STS-V Transmission and Driveline 8 10-04-2014 10:43 PM
Exedy Stage 2 Clutch alpine Engine, Exhaust, Transmission 21 09-09-2014 12:24 AM
Exedy stage 1 clutch/flyweel - Flywheel weight? wparsons Engine, Exhaust, Transmission 5 01-03-2014 11:58 AM
