Old 08-19-2014, 01:34 AM   #673
8686
8686's Avatar
Drives: 86
Dear @DeliciousTuning
I placed my order last Wednesday for Innovate complete kit tune. When you expect to ship.
Thank you
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 08-19-2014, 07:46 PM   #674
Calum
That Guy
Drives: 2013 asphalt FRS MT
I just installed NA tune 5.33. It replaced 5.19. What changes were made between these versions?
Old 08-20-2014, 11:52 AM   #675
TT51
TT51's Avatar
Drives: 2013 Scion FR-S Track Car
Hi Bill,
<Text originally sent in an email>
I have been working on the planning for next year's NASA TT competition. Looks like I have the TTD AZ Regional Championship sewed up for 2014. Thanks for all the great work that helped make it possible. I am heading to Road Atlanta next week for the NASA East Nationals event and will have just two west coast events left after that for this year. My plan is to build the car to compete in TTC next year so that will leave me with a new set of points to work with.
The car is currently maxed out on points and HP for TTD so the move up will allow me to make quite a bit more HP. I will be shooting for a maximum of around 235 RWHP (DynoJet) while staying NA. I don't have enough points to go with FI and I also just like to be different!
So I am looking for advice and guidance. Do you think it is possible to get to 235 RWHP in NA trim? I have read up on and followed your comments about the JDL EL Header. I will be able to do anything I want to the exhaust. Do you think the JDL is a good choice for me? If so, I think I need to get an order in now! I have removed the AC, have a lightweight flywheel/clutch (ACT), carbon fiber driveshaft, E85 Tune, and will have points to replace/modify the airbox & filter. I plan on using JDL catless overpipe and front pipe with no muffler(s).
I still don't think these mods are enough so I was very interested to read about the cams you are working on (Michelle's car I assume?). Are these going to be available any time soon and if so, are they optimized or suitable for NA use? Any other suggestions on how to maximize the NA potential of the FRS? If the cams aren't right or will not be available, can you estimate how much HP to expect with the mods I have mentioned? I can use weight reduction points instead of the cams if necessary.
I hope to have all the changes made in time to use the car in the first event the second week of January. I know some of the parts have a long lead time so I was hoping to start ordering as soon as possible. I really trust your advice and look forward to hearing your thoughts.
Cheers,
Hal Dunn
Yuma, AZ
2013 Scion FR-S
NASA TTD #51
The Corkscrew at Laguna Seca
TT51 is offline   Reply With Quote
Old 08-20-2014, 01:14 PM   #676
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Updates
1. Intake and Exhaust Cam overlap for smoother power delivery especially in the mid power range.
2. More power in the mid-top end for better power between shifts and faster 1/4 mile times
3. Smoother power delivery by refining A/F ratios and timing values across the powerband
Sincerely,
FONT=verdana]Delicious Tuning[/FONT]
The Following User Says Thank You to DeliciousTuning For This Useful Post:
Calum (08-20-2014)
Old 08-20-2014, 02:39 PM   #677
8686
8686's Avatar
Drives: 86
Dear @sales@delicioustuning.com
Can you pm me the tracking number for my order.
Thanks
Old 08-20-2014, 05:05 PM   #678
DeliciousTuning
Thanks
I checked delivery. You will receive your package tomorrow around noon. If you do not receive it let me know.
Cheers,
William Knose
8686 (08-20-2014)
Old 08-21-2014, 09:50 AM   #679
FR-S Matt
So if I've got an OMNI 2.5 bar sensor already, is that sufficient for tuning on the C30 Kraftwerks kit? Install day is coming soon, but I need to find a tune!
Old 08-21-2014, 11:58 AM   #680
DeliciousTuning
Thank you
Packaged delivered today.
8686 (08-21-2014)
Old 08-21-2014, 11:59 AM   #681
DeliciousTuning
Are you planning on running E85 at all or just 91 octane?
You will need larger injector with E85 but on 91 octane you will be fine ont he stock injectors.
Cheers,
William Knose
Old 08-21-2014, 12:30 PM   #682
FR-S Matt
Cheers,
William Knose
93 octane. I may dive into the E85 world at a later point with larger injectors and flex fuel.
Old 08-21-2014, 04:09 PM   #683
8686
8686's Avatar
Drives: 86
Recived. Thank you. I also got my car back from the shop today.
Unfortunatly I am traveling tommorow for 3 weeks. So the car have to wait until I come back.
The Following User Says Thank You to 8686 For This Useful Post:
Old 08-25-2014, 06:59 AM   #684
maziar
Drives: Toyota GT86
If i order ProECU Cable Kit + License and EcuTeK RaceROM Upgrade
should i install ecutek program and add license then send you Dongle ID and Registration Code for you to send me EcuTeK RaceROM Upgrade ? or not ?
And how much time does it take to send me the kit ? (i live in canada)
Sorry for my bad english
maziar is offline   Reply With Quote
Old 08-25-2014, 06:48 PM   #685
DeliciousTuning
You can order everything at once if you like, as we package everything together for you and apply the correct dongle ID and registration code to your order if you order everything from us.
To send to Canada it usually depends on customs. We have seen usually about 3-5 business days via USPS but on occasion it can take up to 3 weeks if it get stuck in customs.
We use USPS because it usually is the fastest way to get things to orders placed in Canada.
Cheers,
William Knose
maziar (08-26-2014)
Old 08-25-2014, 06:59 PM   #686
Calum
That Guy
Cheers,
William Knose
Just an FYI; When a package is shipped via USPS it gets handed off to Canada Post at the border. Canada Post doesn't charge a brokerage fee as UPS, Fedex, etc. do. Even if the price of shipping something to Canada appears less with a courier, unless the shipper pays the duty and taxes on their end, the customer will always pay more in the end with a courier.
The Following 2 Users Say Thank You to Calum For This Useful Post:
DeliciousTuning (08-25-2014), maziar (08-26-2014)
Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 24 09-20-2013 03:04 PM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 05:58 PM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 05:55 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 01:34 AM
Delicious Tuning and HG Motorsports: 86Fest Only Special - Take $100 off EcuTeK DeliciousTuning Announcements, Contests, Giveaways 5 08-26-2013 02:33 PM
