Old 08-17-2014, 09:05 PM   #15
mikeTee
Yup.
mikeTee's Avatar
Drives: MT Subaru BRZ '13
Originally Posted by cnk View Post
Don't think that includes the Sat radio antenna though. Not an issue if you don't need sat radio, but I'd like to retain the antenna if possible.
Yeah it's going to have to be a USDM part for a direct replacement, 86321CA610 is the best thing I can think of based on the post earlier but I can't seem to find anything with that part number via Google. It especially sucks for us SWP and classic WRB owners as we're going to have to get it custom painted for an exact color match as they aren't 2015MY colors. They probably don't even come unpainted either.
mikeTee is offline   Reply With Quote
Old 08-18-2014, 11:14 AM   #16
BoxRZ_86
BoxRZ_86's Avatar
Drives: 2013 Subaru BRZ Limited SWP
Originally Posted by btoast View Post
While we are on this topic, does anyone happen to know the part number for the BRZ sharkfin?
Went to Subaru and they gave me this part number. 86321CA610W6, its unpainted and retails for 186.45 but I found it for cheaper online. I hope to get one soon.
BoxRZ_86 is offline   Reply With Quote
Old 08-18-2014, 11:20 PM   #17
btoast
If you don't mind, please keep us posted. I was hoping it would be painted, but I am interested to see some pics when you get it and to hear if it is a direct plug-and-play swap for you.
btoast is offline   Reply With Quote
Old 08-18-2014, 11:52 PM   #18
cnk
Drives: '13 DGM BRZ Limited
OK. . found a link for all the antenna stays. . no clue on which color each one is though.
http://www.xtremevwparts.com/?p=cata...str=86321CA610
I sent an email to ask them if they could tell me which one was DGM at least. Will post back if I get a response.
Old 08-18-2014, 11:57 PM   #19
mikeTee
Yup.
mikeTee's Avatar
Well based on what we got so far:
86321CA610W6 - Unpainted
86321CA610V2 - Crystal Black Silica (D4S)
86321CA610B5 - ???
86321CA610E4 - ???
86321CA610EN - ???
86321CA610RL - ???
86321CA610TQ - ???
I'll see if I can match it up with any color codes and update this post.
Since MY2015 has 6 colors and there are 7 options, it makes sense for one of them to be unpainted.
Unmatched are:
WR Blue Pearl
Crystal White Pearl
Dark Gray Metallic
Lightning Red
Ice Silver Metallic
Old 08-19-2014, 12:29 AM   #20
nigel-jdmparts
nigel-jdmparts's Avatar
Drives: 86
We have Modellista one C7P (Painted version) in stock.
http://nigel-jdmparts.com/toyota-86-...-sport-antenna
nigel-jdmparts is offline   Reply With Quote
Old 08-19-2014, 01:19 AM   #21
cnk
Found this is off the Retail Accessory Guide effective May 14, 2014 for the Australian market. Link here: http://www.subarutoowong.com.au/broc...ccessories.pdf
WU - Satin White Pearl
B5 - Galaxy Blue Silica
S3 - Sterling Silver Metallic
EN - Dark Gray Metallic
RL - Lightning Red
PG - WR Blue Mica
TQ - Ice Silver Metallic
E4 - WR Blue Pearl
So the updated list looks like this:
86321CA610B5 - Galaxy Blue Silica
86321CA610E4 - WR Blue Pearl
86321CA610EN - Dark Gray Metallic
86321CA610RL - Lightning Red
86321CA610TQ - Ice Silver Metalli
Old 08-19-2014, 01:32 AM   #22
mikeTee
Yup.
mikeTee's Avatar
If that's the case, W6 has to be Crystal White Pearl then. I thought Galaxy Blue Silica was discontinued? But I do trust the that the B5 paint code is in fact GBS but then it makes me wonder why there's no antenna for Satin White Pearl (WU)... Anyways, I guess the final result is:
86321CA610W6 - Crystal White Pearl (K1X)
86321CA610B5 - Galaxy Blue Silica (Now known as Galaxy Blue Pearl) (E8H)
86321CA610E4 - World Rally Blue Pearl (K7X)
86321CA610EN - Dark Gray Metallic (61K)
86321CA610RL - Lightning Red (C7P)
86321CA610TQ - Ice Silver Metallic (G1U)
EDIT: Just realized that all of the 7 colors above are available for the 2015 WRX, which leads me to believe that the color options are specific to the WRX. This is why GBS is available even on a 2015MY part versus SWP. I believe the WRX and BRZ share a common part number for the antennas, so for those who have a GBS BRZ wanting to have a factory paint matched shark fin antenna, you guys lucked out.
Old 08-19-2014, 01:59 AM   #23
mrxchris
Drives: '13 Whiteout FRS
Modllista, TRD, Beatsonic (FDA43 or FDA9), VG Sharkfin Antenna, Sharkfin from vendor
mrxchris is offline   Reply With Quote
Old 08-19-2014, 11:42 AM   #24
BoxRZ_86
BoxRZ_86's Avatar
I should have mentioned in my original post that in order to get the part number I had to take the VIN number from a Crystal White Pearl BRZ, Blue series to be exact. The parts guy told me its unpainted but it could also very well be White like you suggest.
Old 08-20-2014, 02:45 PM   #25
Pyrefyre
Drives: 2013 Subaru BRZ Black
Was it plug-and-play? Or did you need a new harness like mentioned above for the FR-S?
Also, what did it cost?
Yes it was plug and play. Simply pull the roof liner, use a 22mm wrench and take the lock nut off, unhook the harness and pull out from the top. Then the new one goes in.
Any idea what part number for a DGM colored shark fin is? I tried searching for 61K instead of V2, but got nothing. I did find a couple sellers of V2 for around $140-150 though.
I don't know the numbers for the other colors, I just told my parts department guy that I needed one for my black brz.
Where did you order it from if you don't mind me asking?
I ordered directly from my Subaru parts department. I use my SiriusXM daily because FM and HD radio reception sucks where I am stationed, NO stations I like.
Pyrefyre is offline   Reply With Quote
Old 08-20-2014, 02:47 PM   #26
cnk
No worries. If you read the rest of the thread, I identified the codes already.
Old 08-20-2014, 05:05 PM   #27
914_WHITE_FRS
914_WHITE_FRS's Avatar
Drives: White 2013 Scion FR-S
Modellista is the best shark fin but goddamn 260+ dollars for a fucking shark fin? jeesus >=(
914_WHITE_FRS is offline   Reply With Quote
Old 08-20-2014, 05:58 PM   #28
itsibarra
itsibarra's Avatar
Drives: Supercharged Car
Originally Posted by subiestyle View Post
Besides the TRD and Beatsonic, what other antenna options are there for plug and play (no modification)?
Originally Posted by mrxchris View Post
These are pretty much all. One more would be TOM's.
itsibarra is offline   Reply With Quote
FS: Beatsonic WRB SharkFin BRZ humanshield Audio/Visual, Electronics, Infotainment, NAV 4 07-26-2014 07:14 PM
LF: Beatsonic Sharkfin sixthree Canada Classifieds 2 04-19-2014 12:10 PM
Scion FR-S options:what options did you have dealer installed? Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 42 01-06-2014 01:35 AM
Bushing upgrades, geometry options and other component options? der_rainman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-26-2013 12:53 PM
Gearing Options and Diff options airboy808 Engine, Exhaust, Transmission 26 12-25-2011 01:11 PM
