| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#29 | ||||
Drives: Nevermorange FRS
Good info on the Pennzoil: http://www.stealth316.com/2-pennzoil-synchromesh.htm Quote:
2: Amsoil Synchromesh says right on the darn bottle: Applicable in Honda transmissions: Quote:
2a: Redline was contacted via Email (not me personally) and they said don't use the Redline MTL in the Honda boxes, use the MT90. Well, same result with both in D-Boxes. CRUNCH!! 3: Ok, since people here don't use Honda D-Boxes it's worth noting that if you browse the S2k boards or talk to guys who race Honda with B or K-series boxes you'll find many of them have good experiences with MT90/MTL/Amsoil, but then again others do not. It's a real crap shoot. Personally, I've instructed students at the race track who are shifting like they're trying to win the INDY 500 all the while I'm cringing in the passenger seat! Ladies and gentlemen, unless you're actually competing, don't abuse your transmission! Shift with the fingers, not with the palms. As for wear rates and the life of the transmission, I think the breaking down of the fluid from time/heat and elongated change intervals are the biggest factors outside of shifting-like-an-allstar. The breaking down of the fluid can affect the bearings. I can drive a transmission with a "3rd gear crunch" for 100k miles (I could theoretically drive without synchros) but if a bearing craps out at 50k there's not much you can do to avoid the repair. So Bristecom, would you agree in this approach? Only Daily Driven: OEM fluid and treat your transmission with respect Occasional Track days: OEM fluid and treat your transmission with respect but change fluid sooner than manual recommends. Heavy Track use: Lab test OEM for breakdown, shear and high-heat characteristics, change often. OR Use Synthetic/Pennzoil/Torco or whatever else and change often... and treat your transmission with respect. Racing: Use whatever fluid helps you bang through the gears the fastest to gain every 1/10th of a second possible!! |
#30 | ||||
Drives: 2017 Subaru BRZ PP
A good example is to look at the Mitsubishi Evo owner's manuals. They used to always require GL-4 oils but for the Evo X, they require a new GL-3 oil! Oh no, they must be digressing backwards for some reason!
Toyota + Subaru =
![]() Last edited by Bristecom; 06-21-2012 at 09:38 PM. |
#31 |
Getting the right transmission oils has almost become a pet peeve of mine because some people are so ignorant about it. For example, some dumbass on Wikipedia insists that the Evo X MR uses ATF in the transmission and keeps changing my entry. It DOESN'T! It uses a special synthetic oil made by Castrol for Mitsubishi for this specific transmission that is nothing like ATF. So people that read this info on Wikipedia and believe it are going to put ATF in their $10,000+ twin clutch transmission and totally F it up. Grr, why are people so stupid?
Toyota + Subaru =
#32 |
Drives: Scion fr-s,Lexus is250,4-runner
#33 |
Drives: 2013 hot lava FRS
I had a MY2000 Honda S2000. I had problem shifting from 1st to 2nd, will always grind no matter at what rpm, will grind once or more per week. Then I start switching tranny fluid. From amsoil, redline, Honda MTF, all of them show no different, especially winter driving(I am in Canada and yes I drive it in the snow too), the car won't shift into 2nd gear until the fluid warms up. I switch to GM SM FM at the end since I saw a lot of good write up, and I could say it is the best fluid for that tranny since the grinding is completely gone, could shift into 2nd in any temp, shift smoother than any other S2000 that my friends had(both AP1 and AP2), and the best part I had been using that fluid for over 80k and I track the car, the tranny gives me no problem. ( of course I did fluid change once or twice a year)
2013 FRS
2000 S2000 2004 RSX-S 2002 RSX |
#34 |
Drives: 1983 Corolla Levin
Mostly, Toyota say GL-3 75w90 for the gear oil. But I did see one part of the Toyota repair manual that listed GL-4 or GL-5 75w85 oil (maybe a mistake). For the Lexus IS250 (similar box) Toyota list GL-5 75w90.
I know of one case where 2nd gear couldn't be selected in cold weather. I will look into using a thinner oil. It seams like an American thing to me, saying one oil is bad and the other brand is good. It's like what football team you go for... total waste of time also. Better to talk about spec and oil thickness. For my own cars (old T50) I use auto trans oil to thin it out, or even 100% ATF sometimes, if the syncros are worn and I think it needs this. For a customer car I'm looking for the proper solution, a GL-3 spec oil a bit thinner for winter. However, a new car should be giving a few weeks to wear in before changing stuff. |
#35 |
Drives: 2013 BRZ Limited
#36 |
Drives: 2014 FRS
Personally I don't think it makes a lot of sense to assume if oil X works well in car N that it will work in yours (unless those 2 transmissions have a lot in common).
I've been using Motul in our FR-S transmission for a few thousand miles. It never really grinds (nor did it before), however it is occasionally difficult to slide into gear. The previous owner (a long time friend) wasn't too happy with the shifter feel so he installed Motul 300 in an attempt to make it smoother. He reported a better feel overall, but it never really resulted in 100% smooth shifting. Now that I own the car, I really like the feel as it is. It's not buttery smooth, it's a bit notchy, but never has been particularly difficult to shift in normal or spirited driving. FWIW, here's the frs/brz transmission oil change guide he wrote. |
#37 |
Drives: 2014 BRZ Limited, 2013 Focus ST
So, what fluid was decided upon? I read this whole thread and I have no idea what I'm even looking for, lol.
#38 |
Drives: 2014 Suburu BRZ -4300 MILES.
Gear Oil Info:
How does everyone feel about this information?
Commonly available lightweight synthetic manual transmission oils: Good match for the Aisin trans based on kinimatic viscosity and additive package... Type Viscosity Popular “lightweight” Synthetic manual transmission oil - Listed in Centestokes @ 100 degrees Centegrade Redline MTL (cSt@100*C 10.6) BG Syncroshift II (cSt@100*C 8.19) [as tested by Blackstone Labs] Pentosyn MTF-2 (cSt@100*C 7.7) Royal Purple Syncromax (cSt@100*C 7.7) Joe Gibbs MTF (cSt@100*C 9.2) Listed here are more common oils. These are thicker than those above and typically not as effective for grinds (in cold temps) but may be a good match for elevated temperatures and/or track conditions If you regularly see those: Specialty \'\'mid weight\'\' oils: -Redline MT-85, cSt@100*C 12.0 (we use this in our shop car. Its a good balance between a \'\'thin\'\' or \'\'standard\'\' weight gear oil. Allows for smooth shifting in colder weather, but the higher viscosity its providing film thickness as we attend many track events with our shop car.) 75w-90 weight gear oil: By far what most cars call for. Also the standard factory GL-3 fill in the FRS, 86 and BRZ. Some specialty options: -Redline 75w-90NS, cSt@100*C 15.6 -Motul Gear 300 Other gear oils: AMSOIL Severe Gear and Long Life, Redline MT-90, Redline Lightweight Shockproof (not likely needed by any common FRS/BRZ owner) are going to be too thick or with the wrong additives to recommend for this trans. Ray Gunnz SoundGroove Records 2014 BRZ STOCK except for GReddy cold air induction. |
#39 |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
FWIW I'm using Miller's Motorsport CRX 75W90 NT gear oil in my trans and diff, no noises or grinding and around 14 track days, just nice, smooth shifts. It incorporates Nanotechnology additive chemistry to significantly reduce internal frictional and power losses and outperforms other gear oils and other leading gear oils in several categories.
Here's an article from Race Car Engineering about Miller's gear oil: http://performanceracingoils.com/PDF..._the_Gears.pdf |
#40 |
Ty friend.
#41 | |
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523 Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car www.makesmodels.com www.camautomag.com |
#42 |
Drives: 2016 Subaru WRX
Anyone used Lucas gear oil?
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD |
| Automatic Transmission | devinclfalcons | Engine, Exhaust, Transmission | 60 | 04-29-2014 09:42 PM |
| HKS SEQUENTIAL TRANSMISSION for the 86 | ESBjiujitsu | Engine, Exhaust, Transmission | 20 | 10-30-2012 05:28 AM |
| Transmission? | Pplater | AUSTRALIA | 1 | 06-05-2012 07:17 AM |
| topspeed difference between manual transmission and automatic transmission | torquemada | BRZ First-Gen (2012+) — General Topics | 51 | 05-04-2012 07:54 PM |
| Which Transmission ? | gatchaman | Engine, Exhaust, Transmission | 15 | 10-29-2009 12:48 PM |
