Old 05-08-2014, 12:04 AM   #435
Hadouken
Red Rocket
Hadouken's Avatar
Drives: 2014 Scion FRS
Thanks homie. So that yellow just goes right over the reflector huh? Should I even use painters tape? Because doesn't it just go behind the housing anyways? Btw your headlights look sickkk... @ck-GT86
Sent from my SGH-I747M using Tapatalk
Hadouken is offline   Reply With Quote
Old 05-08-2014, 02:06 AM   #436
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
Hmm...I suppose you could, I forgot the reason why I masked it off. Might have been because I wasn't sure how much the housing covered up the chrome parts. Clean up the reflector real good, use some mild soap, and make sure you don't sand it. The spray might foam up a bit, leave it in the sun and it'll go away. And it's important you apply that with light coats only. It wasn't until several, several light coats when I sprayed a little heavier.
Thanks for the compliments!
.ck
Sent from my HTC One using Tapatalk
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
Old 05-08-2014, 04:01 AM   #437
Hadouken
Red Rocket
Hadouken's Avatar
@Honeydew hello I was just wondering how you did those chrome lines in your headlights? They look awesome!! Did you just use painters tape?
Old 06-30-2014, 03:18 AM   #438
franchize
franchize's Avatar
Drives: Subaru Brz
What kind or paint do i use?
franchize is offline   Reply With Quote
Old 07-03-2014, 04:25 PM   #439
TheLaughingMan
TheLaughingMan's Avatar
Same question
TheLaughingMan is offline   Reply With Quote
Old 07-03-2014, 07:13 PM   #440
e11wa
Drives: 86GTS
I used high temperature engine enamel
e11wa is offline   Reply With Quote
Old 07-07-2014, 11:37 PM   #441
coupeae86
Drives: 2013 FRS 1986 Corolla GTS
Just did my housings using a black chrome aerosol...
coupeae86 is offline   Reply With Quote
The Following User Says Thank You to coupeae86 For This Useful Post:
hmong337 (12-19-2014)
Old 08-16-2014, 06:03 PM   #442
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Here's mine during. I also added RGB demon eyes.
The Following User Says Thank You to boredom.is.me For This Useful Post:
raven1231 (08-19-2015)
Old 12-01-2014, 03:34 PM   #443
UtahSleeper
UtahSleeper's Avatar
Drives: 80 Corolla 88 Celica Alltrac 13 FRS
Bump and question.
Has anyone tried using the black chrome spray paint from auto zone? I am wondering if that could potentially be used on the reflectors so you can have the black but not lose the high beams.
UtahSleeper is offline   Reply With Quote
Old 12-19-2014, 01:37 AM   #444
Mikeez
Engineering Student
Drives: Scion FR-S 2015
Which paint can should I use?!? :$ Canada here, I'm limited
There’s no time to stop for gas, we’re already late
Mikeez is offline   Reply With Quote
Old 12-19-2014, 02:30 AM   #445
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Exactly the looking wanna go for. I'm just too ***** to rip apart the headlights.
hmong337 is offline   Reply With Quote
The Following User Says Thank You to hmong337 For This Useful Post:
DAEMANO (01-10-2015)
Old 01-11-2015, 03:21 AM   #446
k.houan
k.houan's Avatar
Drives: BRZZZ
For you guys that have used Krylon Fusion, is sanding required? Did you use a adhesion promoter? Any problems with heat affecting the paint? Im trying to decide if I need to go with a high temp paint or if Fusion paint would work ok on my brz. Aiming for maximum longevity.
k.houan is offline   Reply With Quote
Old 02-23-2015, 11:39 AM   #447
SON1C
SON1C's Avatar
Drives: 2015 Series Blue BRZ WRB
incredible writeups, great work!
SON1C is offline   Reply With Quote
Old 04-18-2015, 04:42 PM   #448
Jav
Drives: 2014 Stormtrooper FR-S
Thanks for the writeup!
Originally Posted by Jav View Post
Blacked Out Headlights
I decided to blackout my headlights & paint the ring around the projectors.
This is the link for the DIY thread
Jav is offline   Reply With Quote
The Following User Says Thank You to Jav For This Useful Post:
HID Headlight Upgrade KIT - 1st MOD completed SpecPer Exterior Parts - The Rest 76 08-03-2012 11:13 AM
Is Anyone Else Tired of SOA Information Blackout geb2391 BRZ First-Gen (2012+) — General Topics 23 04-21-2012 10:37 PM
Headlight Swap Question nogaroblues4 Scion FR-S / Toyota 86 GT86 General Forum 9 02-07-2012 03:45 AM
headlight condensation MRZ415 Off-Topic Lounge [WARNING: NO POLITICS] 1 01-23-2012 03:24 AM
TRS headlight mod RRnold Other Vehicles & General Automotive Discussions 0 12-24-2011 05:20 PM
