Old 07-25-2014, 01:01 PM   #421
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
What do you guys think would look better on Silver Ignition; Gunmetal, SBC or F1 Silver?
I'm leaning towards SBC but not too sure...
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Old 07-25-2014, 01:40 PM   #422
VuDism
NASIOC: AzNSTiImpreza
VuDism's Avatar
BLACK
VuDism is offline   Reply With Quote
Old 07-25-2014, 09:53 PM   #423
VuDism
VuDism's Avatar
Some more
Old 08-03-2014, 12:02 AM   #424
n0thing
Drives: Subaru BRZ
For those with OEM mudflaps, do they provide enough protection with these tires against stone chips to rocker panels/real bumper, especially when you do spirited driving/tracking? Or do you need wider mudflaps like Rally Armor?
n0thing is offline   Reply With Quote
Old 08-03-2014, 12:54 AM   #425
CladMonitor
CladMonitor's Avatar
Drives: 2013 FR-S Asphalt
I don't have them and haven't has any issues But only because I think flaps look a bit .... Off. Look at Rally Amour.
CladMonitor is offline   Reply With Quote
Old 08-05-2014, 04:12 AM   #426
thatWESguy
Power Ranger
thatWESguy's Avatar
Drives: 86
add to the collection
Autofashion | FIVEaxis | Enkei
thatWESguy is offline   Reply With Quote
Old 08-08-2014, 05:58 PM   #427
2much
I wanna go fast
Drives: 2013 FR-S 6MT
Are SBC versions of this exact wheel sold anywhere in NA? 17x9, 35mm offset. I am having trouble finding these, I can only find the 45mm offset version in this size and finish. 5x100, of course.
2much is offline   Reply With Quote
Old 08-12-2014, 10:12 PM   #428
tYtEn86
tYtEn86's Avatar
Drives: FRS
Originally Posted by VuDism View Post
+45 rubs. it pokes in the front and you cannot add camber to tuck the front in without buying coilovers (smaller diameter struts). I believe +45 hits the tie rod at full lock as well.
i run +35 with just RS*R super down springs on stock struts. adjusted camber so the front is flush and does not poke. I do not rub at all. 245/40/17 tires.
Is RS R springs a 1" drop?
tYtEn86 is offline   Reply With Quote
Old 08-13-2014, 08:58 AM   #429
VuDism
VuDism's Avatar
Its a little more than 1 inch. Its about 1.2 - 1.4. There are 2 RS*R springs.. one is called "Downs" and other "Super Downs". I have the Super Downs. I believe the standard Downs are about 1" or less..
Old 08-16-2014, 12:48 AM   #430
D_Thissen
D_Thissen's Avatar
Would these fit stock suspension with out camber bolts? Or on RCE yellows?
Old 08-16-2014, 06:05 AM   #431
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
I've got camber bolts and eibach pro's (1 inch drop) and they fit fine. Sit nicely.
Wise is offline   Reply With Quote
Old 08-16-2014, 07:13 AM   #432
2much
I wanna go fast
how did they fit without the camber bolts? do you know how much you corrected?
Old 08-16-2014, 08:33 AM   #433
Wise
Circle Work Clerk
They poked without the bolts. Now the front is at neg 1.5.
Old 08-16-2014, 12:17 PM   #434
D_Thissen
D_Thissen's Avatar
Right on thanks @Wise. Sorry I was a bit lazy to read through it all lol
Wheel Directory: Enkei RPF1 17x9.0 +45 LevinPhan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 265 06-04-2024 11:13 AM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 04:53 PM
