go_a_way1
Old 08-16-2014, 12:11 AM   #785
Poodles
Drives: 2015 Series.Blue
Originally Posted by Sellout View Post
That's the exact opposite of my experience on my DSM. 3 years at the 300-350 hp level and a few tablespoons of oil poured out of the FMIC when I removed it. Looked inside and saw a pretty heavy coating of oil everywhere.
This is on an engine that never had a questionable compression test.
More likely a worn out turbo seeping oil past the seals in that case (full turbo failure will quickly fill your IC with oil)
Shouldn't be an issue with a Rotrex though.
Old 08-16-2014, 12:27 AM   #786
fenton
Originally Posted by Calum View Post
I've heard from a few people that the 94 runs worse than 91. It would be worth logging a couple tanks to verify.
The 94 from husky is much better than 91 vpower. 94 octane is 94 octane...it just uses some ethanol to get there. I have no problems running full timing on 94 but if you switch to 91 it will pull timing. They can't use more than 10 percent ethanol in regular fuels.
fenton is offline   Reply With Quote
Old 08-16-2014, 01:19 AM   #787
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
Or just maybe it came down the black oil trail on the inside of the turbo inlet pipe that started right at the crankcase vent connection...
But hey don't take my word for it. Your single case where the crankcase vent didn't cause the intercooler to fill with oil clearly trumps the real world experiences of everyone else who has had an issue.
Sellout is offline   Reply With Quote
Old 08-16-2014, 12:41 PM   #788
BrianBlueBRZ
Drives: 2014 BRZ
I don't have this supercharger but I just read through the installation manual online to pre-prepare and it sounds like it's really confusing or is it only because I don't have all the stuff in front of me??
BrianBlueBRZ is offline   Reply With Quote
Old 08-16-2014, 12:57 PM   #789
CSG Mike
CSG Mike's Avatar
You just need the car and the parts in front of you. Take your time and you'll be just fine.
If you're still unsure, have a local shop perform the install for you; if anything happens, they'll be liable.
BrianBlueBRZ (08-16-2014)
Old 08-16-2014, 01:28 PM   #790
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
It may look confusing, but once you start it really isn't.
I have NEVER installed an SC or turbo in any car before and I was able to install everything without any issues... including the Ecutek flash which was a first for me too.
I started early Saturday morning, took my time, did an oil change, installed the JR Oil Cooler Kit, pulley kit, DSS driveshaft, and took pics throughout the process... Ultimately finishing late Sunday morning...
The owners on here are also willing/able to help with any questions you have throughout the install. We are all pretty active forum members and one of us will likely help/answer any questions you have.
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Old 08-16-2014, 02:30 PM   #791
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Close to the refineries (folks like you and I) yes it's "close" but still not 94. Anyhow the further away from creation point it's less productive fuel. Transport of gasoline has a negative effect from agitation, ultimately numbs fuel to simplify understanding.
Old 08-17-2014, 12:44 AM   #792
K-NoMs
Drives: 2015 BRZ Series.Blue in WRB
Im new to the FI thing, was curious to know would i need extra cooling even if i drive in little to no traffic, and only about 20-30 miles a day? I apologize for my lack of knowledge and undoubtedly stupid question. Any advice or answers would be greatly appreciated.
K-NoMs is offline   Reply With Quote
Old 08-17-2014, 12:49 AM   #793
CSG Mike
CSG Mike's Avatar
Nope, you'll be just fine
K-NoMs (08-17-2014)
Old 08-17-2014, 01:02 AM   #794
K-NoMs
So just the base supercharger will be all i need? If so that will fit into my budget so much better
Old 08-17-2014, 01:06 AM   #795
Poodles
Or you're ignoring that you really did have issues as that's a clear indicator of an engine on it's way out.
For the naysayers that PCV doesn't do anything: http://www.carcraft.com/techarticles...uum_pump_test/
Old 08-17-2014, 01:52 AM   #796
CSG Mike
CSG Mike's Avatar
The oil cooler is nice to have, but not necessary at all for just street driving.
Old 08-17-2014, 02:44 AM   #797
K-NoMs
Last question, i have a full exhaust system from speedfactory, will those parts work with the JR kit?
Old 08-17-2014, 02:54 AM   #798
Sellout
Mr. Cranky Pants
Sellout's Avatar
A Moroso vacuum pump is comparable to a PCV system now? Wow.
Would you like to discuss the horsepower gained from the evacuated crankcase (on a motor with a third of the piston underside surface area of that rat motor) and how that compares with the horsepower lost from the intake system being restrictive enough to allow a turbocharger to draw the kind of vacuum it would require to actually evacuate the crankcase? Because we could do that...
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
