Pat.Thornton
Old 08-14-2014, 03:23 PM   #85
ravenstig
Drives: 2013 FR-S, Raven Black
Originally Posted by tunami View Post
I took a better video tonight of the problem area. Is there a fix for this?
There is a fix: replace the entire clutch assembly. But don't worry, it should covered by power train warranty.
I just got my car back from the shop today b/c my clutch was making the exact same noise. My throwout bearing snout was already scarred from the throwout bearing not sliding properly on it. I think someone at the factory (or maybe the clutch mfg?) installed the throwout bearings wrong, or at the very least forgot to lube it properly.
Last edited by ravenstig; 08-15-2014 at 05:44 PM. Reason: fixed image link and corrected jargon (throwout bearing sits around a snout, not in a shunt)
ravenstig is offline   Reply With Quote
The Following User Says Thank You to ravenstig For This Useful Post:
Sigh-on-Rice (08-14-2014)
Old 08-14-2014, 06:04 PM   #86
tunami
tunami's Avatar
Drives: 2013 FR-S 6spd Whiteout
I just got my car back from the shop today b/c my clutch was making the exact same noise. My throwout bearing was already scarred from not sliding properly in its shunt. I think someone at the factory (or maybe the clutch mfg?) installed the throwout bearings wrong, or at the very least forgot to lube it properly.
Crazy. Did you go in knowing that was the issue, or did they find it? I am going to have to make an appointment.
tunami is offline   Reply With Quote
Old 08-15-2014, 05:37 PM   #87
ravenstig
I didn't know exactly what was going on when I took it in, but I was close. Just going off the sound I was pretty sure that it was being caused by some kind of metal-friction issue . Based on what I've read in this thread and a few other posts I figured it was being caused by a poorly lubed clutch fork.
When I took the car in they did not hear the noise at first, and thought I was just hearing the HPFP crickets. So I told them to drive around because it mostly just makes the noise when the transmission is warm. Approx. 10 mins later the guy came back and was like "uhhh yea, you were totally right. the mechanic drove it for like 2 minutes before he heard your clutch dying. you're gonna need a whole new clutch assembly"
EDIT: I will also say that now that i have the replacement clutch, i probably should have realized that something was not right w/ the original assembly. The action of the new clutch is significantly smoother.
tunami (08-16-2014)
Old 08-15-2014, 08:00 PM   #88
Tainen
Drives: First SWP BRZ-L
ugh. I have this issue and always just sort of ignored it. only have 6k on the odo, figured it was just a little stiff for whatever reason.
I wonder if I haveto take my track numbers off my windows before I take it in or they'd not warranty it. :/
First white BRZ in the country
Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers
Tainen is offline   Reply With Quote
The Following User Says Thank You to Tainen For This Useful Post:
tunami (08-16-2014)
Old 08-16-2014, 10:48 AM   #89
ravenstig
Even though this is, afaik, pretty clearly a mfg defect (and not an abusive driving issue$, I would def take the #s off just to be safe.
Old 08-19-2014, 11:37 PM   #90
aghuman
aghuman's Avatar
Drives: 2013 Asphalt FR-S
I just had the exact same issue pop up for me yesterday. Stock DD, no tracking and mainly highway driving at 59k km. I'll be taking it in to the dealer tomorrow afternoon and will let you guys know how it goes. I also hear the clanking sound as mentioned in an attachment earlier in the thread...sort of sounding like 2 metal plates hitting each other. I always assumed this was normal until I read that as an issue. Is this something that other people have brought up with dealers as well?
Additionally is there anything in particular I should bring up or mention as they are doing the diagnosis?
As a side note, the first time I took my car in for its first oil change...i just happened to be walking outside when I noticed a mechanic stalling my car 5-6 times in the time it took for me to process the whole thing and run to the car and stop him. I never went to that dealer again obviously but all they said was stalling doesn't do any harm to the car or clutch which I found to be a load of bs. This was just in the 30-45s I observed him so I don't know what else happened at before that.
Nonetheless I had them document that the mechanic stalled the car several times, just wondering if anyone things it's worth bringing up with this issue and if so, how should I tie it in? Cause I see a variety or patch fixes (Lube/Grease) to full out clutch assembly replacements. Is this just dependent on dealer diagnosis or how you present the issue?
Thanks for the input in advance as always fellas
aghuman is offline   Reply With Quote
Old 08-21-2014, 04:36 PM   #91
gonzo
Drives: frs
My dealer supposedly lubed the clutch fork after I specifically asked them to do that. Noise didn't even go away for a second. Mechanic at dealer then said Toyota told them the squeak is normal and that there isn't a fix for it. He refused to replace the clutch since it'll "just come back."
gonzo is offline   Reply With Quote
Old 08-21-2014, 04:37 PM   #92
gonzo
Drives: frs
The best part is that he had me sit in another frs also at the dealer for warranty work. He told me to press the clutch and it squeaked. Then he says "see? All of them do it it's normal."
Rofl.
Old 08-21-2014, 08:35 PM   #93
tunami
tunami's Avatar
@gonzo what dealership was that?
Old 08-22-2014, 04:43 PM   #94
SC David
Bloberator
Drives: 2013 Asphalt FR-S 6MT
Originally Posted by gonzo View Post
Agreed. I'm taking mine back since the noise slowly came back after I adjusted my clutch pedal higher (previously had it adjusted really low).
Here's a video of mine taken today:
Can anyone with a replaced bearing confirm this is the same noise? Could this have been caused by adjusting the clutch pedal grab point too low?
I just passed 20k miles and the bottom-of-the-clutch travel squeak just appeared, exactly the same as in your video. The clutch feels a little crunchy at the bottom of its throw, but it can be fully engaged without pressing it down that far, so I was thinking about simply installing a clutch stop or adjusting it. Nice to see this thread and learn that it's a common problem.
I'll be taking it into the dealership, and I'll post the results. Hope my visit isn't anything like yours...
SC David is offline   Reply With Quote
Old 08-24-2014, 11:40 AM   #95
philstar
philstar's Avatar
Drives: Argento FR-S
yeah I cant stress this enough..
bring it to the dealer, the more reported cases, the better chance of them making a TSB and finding a permanent fix
philstar is offline   Reply With Quote
Old 08-24-2014, 11:42 AM   #96
philstar
philstar's Avatar
Also a friend of mine brought his FR-S in for the clutch squeak issue.
The throwout bearing was replaced and the clutch fork was lubed, the noise disappeared for several more 1000 miles but it is starting to make the noise again it looks like.
Old 08-25-2014, 12:15 PM   #97
shellslinger
Drives: Whiteout FRS
I just got this issue this morning, really annoying noise. I'm going to bring to it to the dealer this weekend
shellslinger is offline   Reply With Quote
Old 08-25-2014, 01:35 PM   #98
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
I had this problem up until I did a brake bleed and a track day. Not sure what solved the problem as I haven't heard this noise since.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Loud 'Squeak' Noise From Clutch? Brndn704 Issues | Warranty | Recalls / TSB 23 07-20-2020 09:58 AM
Upgraded Clutch Squeak Rybot Issues | Warranty | Recalls / TSB 116 10-09-2019 03:10 PM
Clutch pedal adjustment gone wrong? Clutch issues. PulpBrah Engine, Exhaust, Transmission 12 03-06-2017 05:08 PM
Clutch Squeak CatDaddysBBQ Issues | Warranty | Recalls / TSB 4 07-14-2015 07:44 AM
Clutch pedal squeak. merino_frs Engine, Exhaust, Transmission 1 08-25-2014 02:00 AM
