Sam Strano
Old 08-14-2014, 03:55 PM   #1359
Quentin
Drives: ‘16 4Runner, ‘19 Corolla HB
Weight gain will be marginal. Driver weight differences will be on the same order as the weight added by the aero kit. The whole bumper cover on my old 2.5RS was probably 10lbs or so. Exhaust may be lighter than the standard one to cancel out the difference (I doubt it, but who knows.)
Quentin is offline   Reply With Quote
Old 08-14-2014, 04:38 PM   #1360
renfield90
The Stig's German cousin
Given the limited numbers and extra cost, no way the RS 1.0 stays classed with the base model. The SAC hasn't forgotten the lessons from the MSR and Z0K so quickly. And if they have, well, TTD looks inviting...
The Following User Says Thank You to renfield90 For This Useful Post:
Kido1986 (08-14-2014)
Old 08-15-2014, 11:58 AM   #1361
BRZ21
i kill cones.
BRZ21's Avatar
Drives: around cones in a parking lot
Originally Posted by edj View Post
no. only factory options available in the USA.
What about trd springs? I'm pretty sure they're an option now.
If they are, are they allowed?
2013 SSM BRZ Limited 6MT
BRZ21 is offline   Reply With Quote
Old 08-15-2014, 12:35 PM   #1362
mrazny
Drives: BMW 135i, soon to BRZ
no, then no, also no
mrazny is offline   Reply With Quote
Old 08-15-2014, 03:22 PM   #1363
Jawnathin
Drives: Toyobaru FRZ
Originally Posted by Laloosh View Post
I then remembered that I can get some extra play out of the top of the sturt by loosening the 3 bolts and jacking up the hub. I took measurements before and after and I was able to gain an extra .2-.3 of negative camber on the front per side. Final camber settings are -1.2 Drivers side and -1.4 Passenger Side. Still on the stock shocks and stock bars.
Would this have the same effect as pushing the top of the strut inward while the 3 bolts on the top are tightened?
Jawnathin is offline   Reply With Quote
Old 08-15-2014, 04:27 PM   #1364
renfield90
Yes, but how much weight can you realistically exert on your own? Using a jack allows you to leverage the weight of the car and hold it in place while you tighten.
Old 08-15-2014, 04:42 PM   #1365
Laloosh
Laloosh's Avatar
Drives: 2014 BRZ
I agree 100%
Laloosh is offline   Reply With Quote
Old 08-15-2014, 08:28 PM   #1366
Jawnathin
Well, if you have two people doing the install, one can push in while the other tightens the nuts.
I figure the camber gained will be based upon the amount of play in the holes where the top hat studs go. Even if you can apply 500 lbs of force vs 50lbs, as long as the studs on the top hat are as close inward as the mounting holes will allow, that'll be your max camber gained.
If you think differently, I'd like to understand that. Just trying to see what difference it'll be from what I've done already using two people. Not hard to loosen the 3 nuts and use the jack if its better.
Old 08-16-2014, 11:21 AM   #1367
xwd
I tested those methods on my WRX which has the same front suspension. There are no bushings or anything so having a friend push is just as good as using a jack, the jack just lets you do it by yourself.
Agree on the RS 1.0, I'm not sure they'll even class it and if they do it'll get stuck in BS.
Old 08-17-2014, 12:31 AM   #1368
renfield90
The real question becomes "is 50 pounds truly enough force to move that strut to the ultimate max camber position?" The answer to the question is irrelevant if you're using 500 pounds. Every fraction of a millimeter matters here and I don't like leaving anything on the table.
Old 08-17-2014, 06:21 PM   #1369
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
I hope I can drive somewhere close to what I did at today's private pre-nat TnT. My car is on fire
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 08-17-2014, 09:27 PM   #1370
stevo874
Drives: 2013 BRZ, 1994 Miata
For those who have run the 235/45-17 Dunlop ZII. What kind of tire pressures were you running?
stevo874 is offline   Reply With Quote
Old 08-17-2014, 09:33 PM   #1371
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
I ran them on my GTI, does that count?
I'm running that size, but different brand of tire (and also 225s up front), with only crash bolts. 35.5 psi front and 36 rear felt really nice last time out.
bimmer635csi is offline   Reply With Quote
Old 08-17-2014, 09:37 PM   #1372
marc615243
marc615243's Avatar
Drives: 2014 SWP BRZ Limited
I just got a set of these and am curios as well, I am new to autocrossing so I am trying to absorb as much info as I can before each run
marc615243 is offline   Reply With Quote
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
