Old 08-15-2014, 11:02 AM   #3431
FR-S Matt
Originally Posted by Jyn View Post
I've been down the F/I path. It's one of those things where, going through it, I hated the headaches it caused, but looking back on it now, I enjoyed the experience. Kinda like having a crazy ex, I suppose
On another note, just dropped off my car at Round Rock Scion for it's first oil change at 5k and get a TRD quick shifter installed. I was too lazy to mess with it on jack stands.
I'm due for oil change #3. I want my Fumoto valve on though.
Old 08-15-2014, 11:04 AM   #3432
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
Those Fumotos look super convenient. I may get one after my 3 oil changes, but I've been too worried about scraping/cracking it when I'm lower.
Jyn is offline   Reply With Quote
Old 08-15-2014, 11:27 AM   #3433
FR-S Matt
It doesn't hang low enough at all. Your rear exhaust connections would hit a speed bump before the valve would. If your valve hits anything, you probably broke an axle. Even with my 1.6" drop, that valve will be fine.
Old 08-15-2014, 11:29 AM   #3434
Jyn
Noob
Jyn's Avatar
Thinking of going air. It'd be hilarious (in retrospect) to park, lay frame, then see a puddle of oil when I air up and leave
But good point on the rear connections. I'll probably just go ahead and get one after my 3rd oil change anyway!
Old 08-15-2014, 11:42 AM   #3435
Scottemad123
Drives: 2014 SWP BRZ Limited
Could do the top route as well if you go with the pump option, may do that for the apartment, slight cleaner, but more expensive.
Scottemad123 is offline   Reply With Quote
Old 08-15-2014, 11:56 AM   #3436
FR-S Matt
I got the one with the nipple connection and the clear hose. Makes it a lot cleaner. Turn the valve and go back inside for an hour.
Old 08-15-2014, 12:48 PM   #3437
Jyn
Noob
Jyn's Avatar
I'm not a fan of extracting oil from the top - would prefer to let gravity do its thing in getting all the filament and shaving out. Plus, cheaper
Old 08-15-2014, 01:21 PM   #3438
X Factor
Drives: 2013 Red BRZ Limited
Carb Kit
This is why I'm basically going to get the carb kit from JR and leave it at that when it comes to power. Seems to be pretty reliable and just enough HP.
What are you referring as "the carb kit"?
X Factor is offline   Reply With Quote
Old 08-15-2014, 02:37 PM   #3439
Scottemad123
Jackson Racing sells an off the shelf tuned kit that is CARB legal (emissions standard in California) that is an off the shelf "safe" tune, keeps stock exhaust components, and has a good amount of abuse by the counterspace garage guys. Obviously FI always has risks, but the kit so far hasn't had much in the way of problems, other than some small install issues that people have had. No Forced Induction is without problems, even their kit I'm sure. But so far it seems solid, and would meet any potential goals I'd be going for.
I am sad @frs-Matt isn't going to S/C still
Old 08-15-2014, 02:40 PM   #3440
FR-S Matt
That decision isn't final. I just got promoted at work so things may swing in my favor. It's a safe amount of horsepower for it to not be risky with the car.
The Following User Says Thank You to FR-S Matt For This Useful Post:
Scottemad123 (08-15-2014)
Old 08-15-2014, 02:44 PM   #3441
Scottemad123
Awww Yisssss
The Following User Says Thank You to Scottemad123 For This Useful Post:
FR-S Matt (08-15-2014)
Old 08-15-2014, 06:24 PM   #3442
Jyn
Noob
Jyn's Avatar
YOOOOOOO quick shifter is the TITS
Old 08-15-2014, 07:11 PM   #3443
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
just installed my fumoto on my FJ.. will say that it when changing the oil I again realized why I invested in a fumoto. man those things are convenient.
not sure how much it sticks out on the Fr-s, but I got one for it too. only at 8k miles, so won't need it till probably the end of the year
86-tundra is offline   Reply With Quote
The Following User Says Thank You to 86-tundra For This Useful Post:
Jyn (08-16-2014)
Old 08-16-2014, 11:57 AM   #3444
86-tundra
Troll Hunter
86-tundra's Avatar
I'm moving to a house in cedar park next week, does that make me an old man?
I just wanted the garage :'(
