Old 08-13-2014, 10:16 PM   #8065
OneMic
OneMic's Avatar
Drives: FireStorm
Uh Oh! Installed amp & sub using factory Pioneer system. I didn't change a dam thing just added amp and sub. I love it! I recommend using Audio Control LC2i if you plan on doing the same thing.
OneMic is offline   Reply With Quote
Old 08-13-2014, 10:46 PM   #8066
NickDC88
NickDC88's Avatar
Attempting to modify the original pieces of the 3rd brake light and relocate it out of the way of my rear view.
NickDC88 is offline   Reply With Quote
Old 08-14-2014, 01:59 AM   #8067
boonFRS
Drives: 2013 Scion FRS whiteout
Wheels!
boonFRS is offline   Reply With Quote
Old 08-14-2014, 02:23 AM   #8068
WallsAndFoundations
WallsAndFoundations's Avatar
Drives:
Originally Posted by aaron81 View Post
Just finish install GT wing rocket bunnyAttachment 87790Attachment 87791
86s
Dose political bumper stickers doe....
WallsAndFoundations is offline   Reply With Quote
Old 08-15-2014, 02:24 AM   #8069
InspGadgt
InspGadgt's Avatar
Drives: 2015 Scion FR-S (Asphalt)
Had my license plates installed today
InspGadgt is offline   Reply With Quote
Old 08-15-2014, 03:34 AM   #8070
Nickse30
Unnecessary Boost
Nickse30's Avatar
Drives: E30 M3, Evo 8mr, GT 86 Aero kit
Originally Posted by Fancy View Post
just ran into this with mine. Im throwing P0500, C1237, C1464, and C1465.
I removed my front hubs to install extended studs and had driven a little bit after lowering my car. i took it for a final d=tst drive yesterday and lost my speedometer, and power steering, got a cel and the abs and trac lights...
did you get yours fixed? and if so, what did you have to do?
Yes I ended up fixing it myself. The problem was a broken ABS sensor which happens from not removing the sensor b4 pulling the hub. If u pull the hub out with the sensor still in, u will just snap it off. this is for front and rear.
Nickse30 is offline   Reply With Quote
Old 08-15-2014, 01:25 PM   #8071
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
Got the oil changed. Washed it and got my key today Name:  uploadfromtaptalk1408123546203.jpg
Old 08-15-2014, 02:30 PM   #8072
torranosaurus
Drives: 2014 FR-S
Originally Posted by WhiteFRS69 View Post
Got the oil changed. Washed it and got my key today Attachment 88189
Anyone know if I can get a switchblade key made for my 14? Mine is a regular straight key.
torranosaurus is offline   Reply With Quote
Old 08-15-2014, 02:32 PM   #8073
nyfries
Drives: 14 FRS Whiteout
Got it professionally detailed today. Wow it makes quite a difference. Feel more mint than the day I got her!
nyfries is offline   Reply With Quote
Old 08-15-2014, 02:32 PM   #8074
WhiteFRS69
WhiteFRS69's Avatar
You can. The key that is actually on this isn't my actual key. He makes a copy that works with this piece. He just takes the internals out and put it in this
My car is a 14
Old 08-15-2014, 02:58 PM   #8075
Luis_GT
I made noises today
[ame]http://youtu.be/6RMwFg52Cq8[/ame]
Old 08-15-2014, 03:19 PM   #8076
torranosaurus
Drives: 2014 FR-S
My car is a 14
Mine is a 14 as well. I called the dealer and they told me it can't be done. Who is the "he" you speak of?
Old 08-15-2014, 03:22 PM   #8077
WhiteFRS69
WhiteFRS69's Avatar
PM sent
Old 08-15-2014, 07:21 PM   #8078
NickDC88
NickDC88's Avatar
Got the 3rd brake light moved.
