Old 08-15-2014, 02:20 AM   #29
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
What would be the reason for one to choose the Carrillo rods over the Manley rods?
Darryljr11 is offline   Reply With Quote
Old 08-15-2014, 02:43 AM   #30
abraxis
Drives: many
Among other reasons, I believe the H-beam should be stronger than the I-beam which is lighter. Not to say the Manley is weak at all. Carrillo has been producing quality race stuff for a long time and they tend to have immaculate attention to detail.
abraxis is offline   Reply With Quote
Old 08-15-2014, 03:22 AM   #31
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Interested in this and the TB!
Carlitoz3 is offline   Reply With Quote
The Following User Says Thank You to Carlitoz3 For This Useful Post:
MAPerformance (08-15-2014)
Old 08-16-2014, 12:22 PM   #32
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
I believe it is actually the other way around. H beams are lighter, but an inherently weaker design. I beams tend to be heavier, albeit naturally stronger. That said, Carillo's are still very strong H beams, and I don't think anyone currently makes enough power on an FA20 to really even realize the strength limitations on those rods, much less a high quality I beam.
Sincerely,
Zach
Old 08-16-2014, 04:06 PM   #33
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
Originally Posted by gramicci101 View Post
Will you be coming out with upgraded head/valvespring packages to match the awesome new short block?
Originally Posted by MAPerformance View Post
Yes sir! That is absolutely in the works.
A long while back, Ferrea stated that they would be making a valve set and maybe a cam set for the FA20. Do you plan to consider these as choices for a build?
My cars always dress formally. They all wear black tires.
Black Tire is offline   Reply With Quote
Old 08-16-2014, 05:46 PM   #34
mike the snake
I think you might have it backwards. I beams are lighter, H beams are heavier.
[ame]http://www.youtube.com/watch?v=fszNIRbS8yw[/ame]
Sincerely,
Zach
The Following User Says Thank You to mike the snake For This Useful Post:
Darryljr11 (08-16-2014)
Old 08-16-2014, 06:04 PM   #35
Darryljr11
Darryljr11's Avatar
Drives: Scion FR-S
was about to post that
Old 08-16-2014, 06:12 PM   #36
DeliciousTuning
That would be true if both rods had the same thickness, material etc. However, the H beams I've seen have had much thinner walls, and were a lot lighter. If manufacturers of H beams made them to the same thickness as the standard I beam offerings then yes, they'd be both heavier and stiffer, but they generally do not. I have yet to see an H beam offering for a Subaru that is heavier than a comparable I beam offering :P
In any case I don't go to Summit for engineering enlightenment
A little bit more data as well: http://forums.nasioc.com/forums/show....php?t=1902135
Sincerely,
Zach
Old 08-16-2014, 08:19 PM   #37
mike the snake
I apologize, I simply did a quick query and found that video that stated the opposite of what you had said.
The Summit video did speak generally and seemed informative though.
Sincerely,
Zach
Old 08-16-2014, 08:23 PM   #38
Darryljr11
Darryljr11's Avatar
Drives: Scion FR-S
MAPerformance could maybe give the weight of both rods in their short block offering versus the stock rods?
The Following User Says Thank You to Darryljr11 For This Useful Post:
Lawnik (08-16-2014)
Old 08-16-2014, 08:56 PM   #39
DeliciousTuning
What is going to be a big improvement in general over stock is the fact that just about any aftermarket rod you get is going to be either forged or billet machined from a forged blank. Not only should this be lighter than stock regardless or H or I beam, it will be much stronger and fatigue resistant.
On a side note, I am noticing a interesting trend among failed motors. Seen 2 at Infamous now that came in blown with really terrible bearing wear. Common link was both a lightweight flywheel and lightweight crank pulley. I was skeptical until I read of yet another one on Facebook today, car was relatively stock except for a lightweight flywheel and crank pulley; motor just gave out. It is a bit interesting.
But hey, that's getting off topic.
Sincerely,
Zach
The Following User Says Thank You to DeliciousTuning For This Useful Post:
andrew5826 (08-16-2014)
Old 08-16-2014, 09:27 PM   #40
Killianti
Killianti's Avatar
Drives: 2013 WRB BRZ 6MT
Sincerely,
Zach
The engines most likely to give out are the ones owned by enthusiests.
Killianti is offline   Reply With Quote
Old 08-17-2014, 10:49 AM   #41
xwd
I think as time goes on we'll find the common links to motor failures. It would be a bit odd because the EJ doesn't really have any issues with lightened flywheels and pulleys. It is a different engine though so you never know, if something throws things out of balance a little bit. Could even be flywheels not being completely balanced correctly.
Anyways, always good to see more component options for the engines. I would also agree any aftermarket rod is going to be way better than stock and likely beefy enough people would never break them on this engine.
Old 08-17-2014, 06:51 PM   #42
Darryljr11
Darryljr11's Avatar
Drives: Scion FR-S
Then I beam it is!!!
WTB: FA20 Short Block or Blown Long Block The Racers Line Want-To-Buy Requests 1 06-29-2014 05:21 PM
Fa20 with Fb25 block. jet86 Engine, Exhaust, Transmission 49 04-23-2014 06:21 PM
FA20 oem Short Block 3k miles Area51 Engine, Exhaust, Bolt-Ons 29 09-13-2013 01:01 AM
WTB: short block or long block DOTman05 Engine, Exhaust, Bolt-Ons 2 07-14-2013 06:48 AM
