Old 08-13-2014, 10:32 AM   #1149
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by ATL BRZ View Post
Fingers crossed that Project CARS includes Road Atlanta as part of its 80 in-game tracks!
Forza never really got the elevation drop through turn 12 quite right.
I think Forza 5 did a lot better job that Forza 4 at getting the elevation drop right.
Old 08-13-2014, 10:47 AM   #1150
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Never played FM5 and never will, because of this...
[ame="https://www.youtube.com/watch?v=FKJQW8m9CCY"]Playstation 4 announcement & X-Box One owned, Kaz Hirai gif compilation - YouTube[/ame]
Old 08-14-2014, 10:28 AM   #1151
ATL BRZ
ATL BRZ's Avatar
I've been itching to finally do something about my stock midpipe as it's 2.1 inches, stamped and notched all over.
I could get the made-to-order Works 2.5" midpipe that's coated aluminized steel for $399 to match up with my axleback,
OR
I could get a new full 2.5 inch t304 stainless resonated catback from Tsudo instead for $380 shipped via Speed Element.
I searched and found that @glamcem removed a Tsudo catback and switched to a different one thinking it wouldn't fit with the DWL diffuser but I'm pretty sure it will fit without any major clearance issues. Especially considering where the stock midpipe comes in past the subframe:
The Tsudo midpipe comes in at the same spot and should clear the diffuser ok if I lower the leading edge enough. The midpipe may rest on it like the stock mp does. I can also grind a bit of material off the diffuser if necessary. The Tsudo muffler is tucked in nicely and doesn't hang low enough to interfere with the diffuser.
My Works ABM axleback will be for sale once this new catback is installed.
Old 08-14-2014, 12:16 PM   #1152
sonnydelight
sonnydelight's Avatar
Drives: 2013 Scion FR-S - Whiteout
Yours is definitely one of my favorite 86's. I need to get down to Road Atlanta and run with you guys. CMP is fun, but I'm ready for something new.
sonnydelight is offline   Reply With Quote
Old 08-14-2014, 12:22 PM   #1153
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Heavy muffler looks heavy. If making a change, I would look to a lightweight single muffler. Definitely get a full 2.5" or bigger setup on the car from the header back. Do you have the stock overpipe as well?
Old 08-14-2014, 12:50 PM   #1154
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
OR
Tsudo was OK especially for the price but I would definitely recommend you Invidia Q300, I've also seen some others and found them pretty loud and Q300's connection point is better for those who are planning to lower their cars more than 1.5" IMO
Tsudo was also a bit louder compared to Q300 and lastly Q300 looks a bit better (not that I care about the looks but it's an added bonus)
glamcem is offline   Reply With Quote
Old 08-14-2014, 01:10 PM   #1155
ATL BRZ
ATL BRZ's Avatar
I have a 2.5" SS overpipe from PLM and a 2.5" SS HFC and resonated front pipe from MagnaFlow.
The catback is advertised to be significantly lighter than the stock 38lb catback, but the axleback section is likely a bit heavier than my current 15lb Works axleback with a small canister muffler.
I'm going with the Tsudo because it's cheaper and is made of better materials versus getting the Works 2.5" midpipe made to order. I really can't justify the $680 price of the Q300 knowing my main objective is to make everything 2.5" headerback and keep costs low without deleting the muffler or resonators. If I didn't have to stay under the 98 db limit at AMP where I frequently track the car I'd consider getting the Tsudo race catback which is essentially the same but with a centrally fed dual-exit muffler delete. It would probably be droney on the street (like all dual-exit muffler deletes that don't have resonators) and too loud for AMP.
Old 08-14-2014, 01:21 PM   #1156
Lawn_Mower
Lawn_Mower's Avatar
Drives: GTI, BRZ
Let me know, I'd more than likely pick the ABM up from you.
Lawn_Mower is offline   Reply With Quote
Old 08-14-2014, 01:22 PM   #1157
glamcem
glamcem's Avatar
The catback is advertised to be lighter than the stock catback (38 lbs total), but the axleback section is likely a bit heavier than my current 15lb Works axleback with a small canister muffler.
trust me I was on the same boat and now am glad I switched to Q300 it's just a better exhaust and well worth the price difference ($250) if you ask me..and one thing to mention, I was planning to keep my OEM catback and I would definitely keep it if it wasn't for the ID (2.5") I don't really care about the "boxer rumble" or the loud exhausts.. after a while Tsudo started giving me some drone on the highway and that was with the OEM header, I was a bit surprised because Tsudo was supposedly one of the quieter exhausts in the market according to the reviews I read here and there.. I have no drone with Q300 and I have catless FP..
FYI, thmotorsports have 5% off if you plug in the coupon code "Invidia" which cuts down the cost $650 shipped
Old 08-14-2014, 04:31 PM   #1158
loogs
Drives: on cruise control
Personally the blocks aren't worth the money and time to install since I'm running E85 most of the time and they cause significant top end power loss when tuned for E85: http://www.ft86club.com/forums/showt...81#post1693281
So if you want the strongest top end power while NA you might want to sell the blocks and put that money into a flex fuel kit to compliment a catless header.
you seem like a smart guy. can you decipher this Dyno sheet for me?
loogs is offline   Reply With Quote
Old 08-14-2014, 04:57 PM   #1159
ATL BRZ
ATL BRZ's Avatar
Looks like you're seeing gains with an E85/Gasoline blend yielding 55% E content. Who's tune is it? I'm guessing Visconti?
You should post that in the Vishnu tuning BPB thread: http://www.ft86club.com/forums/showt...t=62471&page=6
Last I heard Shiv is still not having any success making power with BPB and E85.
Old 08-14-2014, 05:24 PM   #1160
ATL BRZ
ATL BRZ's Avatar
Ordered a few more items for the car this afternoon.
Shorai LFX BMS01 battery charger to maintain and internally balance the cells in my new battery.
MTec shifter springs: I've been wanting a tighter, more direct shift feel as I've been having rare issues on track with quick 5-4 and 3-2 downshifts finding the lower gear with certainty.
Whiteline KDT925 Rear Differential Cradle and support outrigger bushings. I've been noticing the sloppyness of the stock rubber diff bushings more and more since installing the rear subframe lockout bushings. I've read these diff bushings are a nice compliment to liven up the rear end of the car and I've been meaning to get them for a while now.
I figure the shift springs and diff bushings can go on with the new catback all at once on the lift to make things easier.
Old 08-14-2014, 05:40 PM   #1161
buddy32
Drives: WRB Subaru BRZ Limited
Might as well just take the jump and get that JR kit. :p
Then everything can go on at once!
buddy32 is offline   Reply With Quote
Old 08-14-2014, 06:03 PM   #1162
ATL BRZ
ATL BRZ's Avatar
Damn the peer pressure for boost pressure is strong in this thread!
jdl turbo, mazworx, racecomp engineering, track build, verus engineering
Wnt3d's 86 - Turbo E85 Daily/Track Build wnt3d Member's Car Journals 77 07-17-2017 03:35 PM
No Limit Motorsport Full Blown BRZ Build No Limit Motorsport Member's Car Journals 16 07-08-2014 12:46 PM
