Old 08-08-2014, 04:11 PM   #1
DAN_BRZ
DAN_BRZ's Avatar
Drives: 2013 WRB BRZ Sport Tech
how to increase idle with OFT
Hey, would like to raise my idle about 10rpm, i have perrin mounts and the idle with a/c makes the overpipe rattle against the frame, raising my idle will fix this. How do i go about making these changes?
edit, i figure i would use romraider, just havent done it before and havent found a write up
DAN_BRZ is offline   Reply With Quote
Old 08-08-2014, 04:26 PM   #2
stugray
Drives: 2013 GBS BRZ Limited
Your biggest hurdle will be getting Romraider to work on your particular ROM ID.
Then being capable of writig your ROM using ECUFlash
If you can get that far you will likely have stumbled over the field in RR that you modify to make the change.
I would just tell you but I dont have access to my RR computer from work.
Old 08-08-2014, 10:30 PM   #3
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Why would he need to use ECUFlash if he already has OFT. You can get the definition files from Openflash, load them in RomRaider, pic your rom ID and adjust idle speed target in the following tables.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 08-08-2014, 11:18 PM   #4
stugray
Sorry, you are correct. I missed that he was using an OFT to write as it was only in the thread title and not in the body.
I write OFT files with a tactrix.
Old 08-14-2014, 03:01 PM   #5
DAN_BRZ
DAN_BRZ's Avatar
thanks for this, do i need to change the table for target "A" threw to "F" or do i i only need to change one??
Old 08-14-2014, 04:43 PM   #6
Kodename47
Kodename47's Avatar
Drives: UK GT86
All. The modes all are for different circumstances so for consistent idle, do them all.
.: Stealth 86 :.
Kodename 47 DJ:
The Following 2 Users Say Thank You to Kodename47 For This Useful Post:
Apoc (08-15-2014), DAN_BRZ (08-14-2014)
how to increase hp staying n/a Sitha@ft86club Northwest 20 02-27-2014 03:53 PM
HP increase ravenblackfrs Forced Induction 35 11-19-2013 05:05 PM
TRD air filter and HP increase FRiSson Engine, Exhaust, Transmission 2 02-10-2013 12:59 AM
Price Increase for FR-S? chanomatik Scion FR-S / Toyota 86 GT86 General Forum 18 01-25-2013 12:30 AM
Price increase on FR-S Dark_Angle Scion FR-S / Toyota 86 GT86 General Forum 35 06-05-2012 11:33 AM
