Drives: Seckksy
sleeping in the 86/ scion frs
have far back do the seats go? do they go in a lying down position? as i tend to have power naps when i go for long drives.
Would you say its comfortable to sleep in? |
#2 |
Cliuless
Drives: Whiteout Scion FRS 2014
7/10 on the comfortable scale. If you're a smaller guy the seats will hug you to sleep on those lonely nights, but if you're a bigger guy they can get a little annoying.
#3 |
Check your owners manual cuz believe it or not there is a section called "Napping in your car". NO Joke these guys thought of everything!
Just don't expect to curl up in the back seat. From Manual: ■When taking a nap in the vehicle Always turn the engine off. Otherwise, you may accidentally move the select lever or shift lever, or depress the accelerator pedal, this could cause an accident or fire due to engine overheating. Additionally, if the vehicle is parked in a poorly ventilated area, exhaust gases may collect and enter the vehicle, leading to death or a serious health hazard. |
| The Following 5 Users Say Thank You to Tcoat For This Useful Post: | #maverick# (08-14-2014), gramicci101 (09-04-2016), mixtape (09-02-2016), Purdue FR-S (08-14-2014), Zaku (09-02-2016) |
#4 |
Drives: 2013 Firestorm FR-S
I'm a pretty small dude and I find the seats to be quite comfortable during the occasional lunch break nap.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
#5 |
Drives: FRS 10 Series
| The Following 9 Users Say Thank You to khan For This Useful Post: | Bearcat86 (09-02-2016), bryanttttttta (08-20-2014), CBR600RR (09-02-2016), D5teph (09-02-2016), FiReStorm2013 (08-14-2014), JD001 (09-02-2016), Mini Cooper S (08-14-2014), mitosis (08-14-2014), xuimod (09-05-2016) |
#6 | |
Drives: 2013 MT Asphalt FRS
If only I had known this sooner -__-' |
#7 |
Yeah - I've been doing this since my '87 Celica - anything with fold-down rear seats. It's usually not quite as simple as the drawing suggests because the rear seat back is not typically flush with the trunk floor in a sports car, but it works.
| The Following User Says Thank You to Dake For This Useful Post: | mitosis (08-14-2014) |
#8 |
Yup - with the rear seats folded down it's like a really nice metal sleeping bag
Ultramarine 2013 Scion FR-S 6MT
#9 |
Reverse Burnouts
Drives: 2013 Argento FRS
i sleep in the trunk with the seat folded up, you know in case a bear, person, or zombie breaks into my car then im safe int he trunk
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
#10 |
Drives: 2017 BRZ PP (White)
I probably sleep in my car more than you might imagine, because my work commute is terrible and since I get all the amenities at work (e.g. shower, free food, laundry etc...), I don't mind it as much. I'm also single and don't rent, so I don't have any major commitments. Maybe at least 3-4 times during the work week. FYI I am not homeless hahaha, I live with my parents to save some money..
Here's what I have found useful and here's how to make your sleep more comfortable should you decide to sleep in your car more often. Please note this isn't a post on how to live in your car, just sleeping. 1) I bought a $30 workout mat from Target. It's well padded and foamy and it does a good job flattening out that weird dip when you fold the seats down. I almost don't even feel that dip in my back now that I have this workout mat. Invest in a high quality one for a better night's sleep! I used to use a simple yoga mat but that was really painful. 2) I use 2 shoeboxes (one bigger than the other) to fill in the gap between the seats. One box is for clean clothes, underwear, socks etc... The other one is for dirty clothes (I also use a zip bag so the stench doesn't come out). 3) I have 3 pillows. 2 to further fill the gap and another that I actually sleep on. At this point the positioning is suuuuper comfortable. 4) Use the sun visors to your advantage. Pull them to the side and hang dark clothes so nobody can see inside your car in addition to having the windshield shade in the front. I don't usually do this because I park in an underground lot. 5) Since you're sleeping on one side of the car, you have a lot more space on the other side for stuff! I tend to put another box of hygiene-related things here, like a shaver, deodorant, cologne, extra contacts solution/contacts, toothpaste etc... 6) Passenger seat I have coats and extra pairs of shoes. If my shoes are stinky, I tend to leave them underneath my car overnight. 7) Leave your window cracked open a bit. For obvious reasons. EXTRA: If you're sleeping for a night, you don't need all this fancy stuff, but it's always nice to have car fresheners You know, in case your bodily functions start acting up all night.
| The Following 2 Users Say Thank You to CBRZY For This Useful Post: | joe strummer (09-03-2016), rennlistuser3 (09-06-2016) |
#11 |
Additional PSA:
In an event where you must get out of your car quickly (e.g. emergency, fire alarm in the parking lot etc...), it's better to sleep on the passenger side of the car. When sleeping at night, it's a good idea to lock the driver's seat forward as well. This leaves an open space for you to easily step into and then out of the car should you need to escape. If you're acrobatic enough, you can use your feet to pull the truck open, pull yourself out using the rear and slide out that way. |
#12 |
So nap while the car is stopped. Got it now.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#13 |
Drives: frs
I would rather pay a cheap motel
| The Following User Says Thank You to Teseo For This Useful Post: | soulreapersteve (09-02-2016) |
#14 |
I've taken a short nap in the car and it was comfortable enough (driver seat reclined as far back as it would go), but I definitely don't want to spend a night in it. If this is something you'll be doing often, I'd consider a hatch or wagon. Fold the seats down, lay out a sleeping bag/blankets and it can be quite comfy.
2022 BRZ Build 2013 FR-S Build |
| 2014 Scion FR-S Pricing and New Features Announced by Scion | DonkeyKonga | Scion FR-S / Toyota 86 GT86 General Forum | 27 | 08-30-2013 10:58 AM |
| Scion Car Show @ Oakbrook Toyota Scion in Westmont | @Art_Mighty | Great Lakes | 10 | 10-10-2012 02:22 PM |
| Scion Ride and Drive- Good Info Inside, straight from Scion District Managers! | clevrname | Scion FR-S / Toyota 86 GT86 General Forum | 29 | 06-16-2012 08:39 AM |
| Scion FR-S Behind the Scenes with Scion VP Jack Hollis scion | UriarteMD | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 19 | 06-14-2011 07:13 PM |
