#463 | |
Boosted Member
Drives: 2013 SWP BRZ Limited
The oil cooler I use is this one: http://www.tomiokaracing.com/index.p...hermostat.html it says 16 row. I really want to resolve this high coolant temp issue (220F just driving stop and go traffic today again) and the next step I am thinking is drilling holes in the front bumper, FB shroud for stock rad/fan set up. My custom TC kit is so tight in their, I am not sure if the thicker Koyo Rad will fit in their without using thin spal fans. Whether its Koyo or stock rad, I still think the issue is air flow and fans. Not the radiator it self.
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12 |
#464 | |
Drives: 2013 Black FR-S
People are not gonna wanna hear this but the koyo and the stock rad saw the same problem with temps at our local racetrack on pretty much identical turbo charged setups. The problem is air flow not core thickness. But I do have a feeling if you get massive airflow increase through the radiator, the KOYO might start to show its superiority. As it stands there is just so little airflow with the bumper beam + FMIC + oil coler etc. |
#465 |
#467 |
Drives: 22RE, FA20, 4G63
#468 | ||
And I think the koyo rad will not fit Also agree with the fans and shroud, dose are vital! And you are correct is the airflow but the bigger the rad the lower flow need to cool ![]() But you HAVE to cool your turbo! Also your engine, I have 20 rows for basically NA... Well have a vortech at 9 psi. For that setup the koyo rad is right but need 20 rows of oil cooler and use 7.5qts. And the SC have his own oil cooler + separate oil pump... Quote:
So can't fit a bigger rad, and the oil cooler + intercooler are on the way... Mmmmm Bigger oil cooler behind fog light? 32 rows? Really looking to solve this issue as I may go Turbo. |
#469 |
Drives: Toyota MR2 Spyder Turbo
The Subaru STi used to come with a mist spray for the intercooler. Would something similar not help?
Also a black intercooler apparently expells more heat... [ame="https://www.youtube.com/watch?v=f1QL9veQaNg"]https://www.youtube.com/watch?v=f1QL9veQaNg[/ame]
#470 |
I like to eat!
Thanks to AVO for doing their R&D homework. My bottom mounted turbo and black FMIC keep my motor cool all the time with no need for a vented hood. I was running the same autocross in Portland Sunday (96 degree heat) as BRZPDX and with the stock cooling system did not see temps anything close to his.
#471 |
#472 | |
#473 | |
| The Following User Says Thank You to mkivsoopra For This Useful Post: | CSG Mike (08-14-2014) |
#474 |
Mr. Cranky Pants
Drives: 2013 Argento FR-S
| The Following 2 Users Say Thank You to Sellout For This Useful Post: | CSG Mike (08-14-2014), mkivsoopra (08-14-2014) |
#475 |
Hot Lava 6MT
Drives: Hot Lava FR-S
#476 | |
Boosted
Drives: Sideways
The only benefit to having it black versus normal color is when the car is stopped or driving slowly such as in traffic or at a stoplight. As soon as you're moving again at a respectable pace the black intercooler has no more effectiveness than a silver intercooler. You probably wouldn't see any benefits at all on a track. Maybe a little at the drag strip right before your launch.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
| any serious benefit Heat Tapes? | Djen | Engine, Exhaust, Transmission | 22 | 02-18-2014 03:20 PM |
| Heat bad for your car? Ways to cool it? | BushMan | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 08-01-2013 10:15 PM |
| Misfire with heat? | bigjake | Issues | Warranty | Recalls / TSB | 2 | 04-28-2013 09:02 PM |
| Do I Need a Heat Shield? | arleewa | Engine, Exhaust, Transmission | 1 | 01-08-2013 06:37 AM |
| Overpipe Heat question | Amadeus | Engine, Exhaust, Transmission | 5 | 12-19-2012 01:18 AM |
