#85 |
Drives: 2000 Corvette
In the case of a late model car like this, I would absolutely rather buy a used car with no stories than have to worry if the dealership that screwed up something as simple as an oil change, is actually capable of swapping a long block without messing something else up. Probably won't be a lot, but I'd ask for some diminshed value.
#86 |
Drives: 2015 FRS
Yes. You missed the day they taught sarcasm at school.
2015 FRS M6 Argento, 2014 Audi Q7, 2012 Audi A5 (Traded),2012 VW CC, 2010 Mercedes S550
| The Following User Says Thank You to FRS Dad For This Useful Post: | HunterGreene (08-14-2014) |
#87 |
I was the instructor. I know for a fact you were absent.
Good luck with this: WTS: 2013 Scion FR-S, 23K miles. First oil change at 8K with 5 quarts of ATF, only driven for 2 hours before actual oil used. Asking 18K, willing to accept 10k. |
#88 | |
Drives: 2015 FRS
DOV would be a stretch.
#89 |
Drives: 2014 Firestorm FR-S 6MT
#90 | |
Drives: sentra ser
Well this was said : Since I was over 10 miles away they wanted to tow it "because it may do damage to the car" Im assuming they were worried about the engine. Im also assuming they know potencial domage transmission fluid could do the engine but maybe they dont know ? Maybe you do know but you said an extended warranty isnt unreasonable. So that being said, personally would prefer cash over an extended warranty and I gave 2 arguments so he can get the most of it. To get a clear picture, we need to know from a good source if transmission fluid can "destroy" or harm this engine on the long run. |
#91 |
Drives: 2015 FRS
Wrong guy. I've never been to truck driving school.
#92 |
Drives: FRS
Waiting for someone knowledgeable in fluid dynamics to speak up.
#93 |
Drives: 2014 scion frs asphalt
stop fighting over the internet. give the guy advice and move on
#94 | |
Drives: 2015 FRS
I think you have two options before you: 1) Have the engine torn down, the parts cleaned and inspected by a Subaru tech, and have the area Subaru factory rep sign off on the reassembled engine. 2) Take it on faith that no permanent harm was done, have the shop do a couple of short interval oil and filter changes and accept the extended warranty. Option one just seems horribly invasive and is likely to turn up nothing, plus it'll tie the car up for a couple of weeks. Let me follow up with my brother tomorrow. He's a great tech and his advice is always spot on.
#95 |
Drives: EVO X
#96 |
Drives: 2015 FRS
Well I hope you're all happy now. The Internet Police just showed up. Nice work everyone.
#97 |
#98 |
Drives: 2015 FRS
Okay, I did some research on this. Apparently ATF is thinner than motor oil, and it is a common practice on higher mileage engines to run a mixture of ATF and oil for a short period to clean sludge out of the engine, then do a couple of regular oil changes to flush any remaining ATF out: This was posted in response to a guy who had accidentally used ATF instead of motor coil.
"Actually, people used to put 'some' transmission fluid in the engine oil right before an oil change because trans fluid helps clean the gunk out. I wouldn't keep it in there but I wouldn't have any problem with driving it for a couple days then getting an oil change." Source: ASE Master Tech for 22 years. So it doesn't seem like the two fluids are totally incompatible. If they mix together readily then they can be flushed out together as well.
| Dealer Service Center Oil Change Nightmare | FRS-Texas | Engine, Exhaust, Transmission | 28 | 08-15-2014 04:27 PM |
| Dealer service 5/13.... | Tromatic | Software Tuning | 4 | 05-13-2014 02:26 AM |
| Best Scion service center in LA area? | G.I.Choe | Southern California | 12 | 04-18-2014 11:47 PM |
| First Dealer Service | Umbie | BRZ First-Gen (2012+) — General Topics | 7 | 12-12-2012 09:50 AM |
| First Engine Oil change, DIY or Service? | davey90 | AUSTRALIA | 25 | 09-13-2012 01:56 AM |
